      11-27-2017, 10:24 AM   #67
faloppi88
Drives: 2021 M5C
Originally Posted by onfireX5 View Post
Either should work, but I would use the 275/315 combo unless you measure snow in feet instead of inches.
Chicago area, so usually just inches, and if it's a 1 ft plus type of storm, my work situation is flexible and I can stay off the roads.
So this setup won't be to tall?
      11-27-2017, 11:31 AM   #68
onfireX5
Drives: F90M5,F85X5M
29" vs 30.7"......I would do the 35 aspect ratio instead and be 0.40" shorter. than stock.
      11-27-2017, 11:44 AM   #69
faloppi88
Drives: 2021 M5C
Yeah unfortunately without moving to run flat, can't get the 315 width in anything shorter than 40, which then impacts what can be matched on the front, and they don't offer 325 in the non run flat, at least from what I can find on tirerack.
I see in another thread some guys going with the Yokohama Bluewinters 295/35 (285s are sold out) and 325/30, but I'm concerned that the delta between front and back is too much.
      12-06-2017, 06:50 AM   #70
robcan
robcan's Avatar
Drives: 2021 X5 M50i
2021 X5 M50i  [0.00]
18s?
I know this might get me flamed, but as I live in VT during the winter, I’d really like to get 18” rims on a 2018 x5m. Is that possible? Tire rack says 19, bmwusa.com says 20 or 21. Thanks
2021 X5 M50i
RIP - 2018 X5 5.0 MSport
2013 550i xDrive MSport
2008 535i xDrive
2001 Audi A6 2.7T
      12-06-2017, 07:10 AM   #71
Bluesummer
Bluesummer's Avatar
Taiwan
588
Drives: slower than Ayrton Senna
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
Sorry if this is unrelated. What tire pressure are you guys using for the 21''?
IG:d.violet.m3
      12-06-2017, 07:41 AM   #72
trev230
trev230's Avatar
351
Drives: 2022 M5C
I'm at 36 psi cold. Anything less and the outside edges of the fronts start wearing badly.
      12-06-2017, 10:06 AM   #73
Alberta
Alberta's Avatar
2038
Drives: F90
No , it won't fit.
My 19" winter wheels I had for my previous E70 X5 don't fit because of the front brake caliper being to big.
I didn't try the back ...
      12-06-2017, 03:36 PM   #74
gan23
Drives: X5M '18 XM’23 X5 50e 24
The only ones having found a 19"kit working that I know of are these guys
http://f15.bimmerpost.com/forums/sho...1#post21098091
Originally Posted by andrew71 View Post
I have fitted my 19" OEM F15 winter wheels / tyres, there is a good 1/2 inch of clearance over the front brake callipers (more on the rears). BMW said they wouldn't fit, but I think they just go off the parts list and never try these things.
http://f15.bimmerpost.com/forums/sho...0&postcount=39
Originally Posted by aas5 View Post
Just to close the loop on this. I got my 2017 x6m in March and my 19' winter wheels that I used for my 2014 x6m fit fine.
Maybe those OEM F15/custom kits had a special design making it possible to clear the calipers. Otherwise, the minimum is 20".
Others have chime in that the winter kit 298M from the earlier generation in 19" (E70M) didn't clear the calipers.
      12-06-2017, 11:08 PM   #75
Bluesummer
Bluesummer's Avatar
Taiwan
588
2017 BMW X5M  [0.00]
2015 M4  [0.00]
2011 E82 135  [0.00]
2011 M3  [0.00]
2007 335  [0.00]
I have mine set at 38 cold during winter here in CA. I was mad to find out that my dealer had my tires at 36 hot
IG:d.violet.m3
      12-08-2017, 08:54 AM   #76
Omar@VelosDesignwerks
Omar@VelosDesignwerks's Avatar
Drives: Different Ones
Originally Posted by ericliuhc View Post
Im getting my 22 " wheel soon. It comes with Pireli 295/30 335/25. Is it any other size choice ?It is hard to find the tires.
F86
Hey!
yes we have done several sets on this exact combo. Assuming a 22x10.5 & 22x12 Wheel. Pirelli may have discontinued this size but Vredstein has a nice solution
What size is your set?
      12-23-2017, 02:02 AM   #77
Montesquieu1748
Montesquieu1748's Avatar
Germany
115
Drives: ‘18 X5 M Azurite Black AB FML
Originally Posted by remmib View Post
Isn't the OEM 21" rears 325 too? You typed 315/30/21.
Wow! Sorry to get off topic, but almost 29,000 posts! That’s is like 6 posts a day for 12years!
Incredible dedication to BMW.
      03-07-2018, 05:51 AM   #78
sworks335i
sworks335i's Avatar
Drives: 2015 F85 X5M
2010 BMW M3  [0.00]
JNoSol Those who have done DWS 06's, where did you have them mounted and balanced at? Dealership? Indy? Tire Shop?
Trying to figure out if the dealership will give me trouble for putting a different tire size on the beast.
      03-09-2018, 11:30 AM   #79
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
I mounted at my dealer, but half the time i use Discount Tire Direct.
      03-09-2018, 11:37 AM   #80
sworks335i
sworks335i's Avatar
2010 BMW M3  [0.00]
Thanks JNoSol My dealership seems difficult so hopefully they don't throw a fit about it.
      03-26-2018, 10:07 AM   #81
sworks335i
sworks335i's Avatar
2010 BMW M3  [0.00]
JNoSol What pressure are you running your DWS 06's?
Did you do the stock 20's pressures at 36 all around or did you follow a 50i spec of 33F / 36R?
      12-22-2018, 04:57 PM   #82
Davegsu
Drives: 2007 Z4 M Coupe
New wheel and tire questions
Just got some new to me Style 215 rep's for the X5. Got a great deal on them and they came with some new but very cheap tires. Getting some road noise from the cheaper new tires that came with. Any suggestions on replacements down the road? Here's the current setup: Fronts 275/40/20's, Rear 285/35/20's. I know very little about the tire game and am open to suggestions. These new tires are NRF's by the way.
      12-22-2018, 10:07 PM   #83
Nuckle
Drives: 2023 Defender X
You have those tires on an X5M?
      05-01-2019, 05:26 AM   #84
X5e70owner
England
Drives: X5 e70
Hi all, I have X5 e70 with 275/40/20 fronts and 315/35/20 rears
Any know if 295/35/21 fronts and 325/30/21 rears would fit? I seen some on eBay I like but not seem if the size will fit
      05-01-2019, 05:29 AM   #85
X5e70owner
England
Drives: X5 e70
      05-01-2019, 06:35 AM   #86
Gtz1wickedest
Gtz1wickedest's Avatar
Drives: 2020 BMW X5
No your comparing 20 inch wheels to 21 inch wheels the last number represents the size of the rim
      05-01-2019, 06:38 AM   #87
X5e70owner
England
Drives: X5 e70
Yes . The ones I'm looking at are 21 inch rims , but wasn't sure if that would fit as have seen 22 inch rims on e70s. So asking if they would fit mine
      05-01-2019, 10:35 PM   #88
Gtz1wickedest
Drives: 2020 BMW X5
Oooo okay no they won't work. It will be off by a lot for 21 inch you'll need 285/35/21 325/30/21
tire size f85, wheel size, x5m tire, x5m wheel and tire size
