      02-05-2023, 01:05 PM   #1
dentprotony@gmail.com
Drives: 2018 f85
*** Front Driveshaft Safety Shield ***
Hey fellas, as promised i put a lot of effort, time, research, and tears into this little project, that could hopefully save someone their engine or transmission.
It seems to be fairly common for a front driveshaft to blow up at the tcase ujoint at speed and severely damage transmission housing/tcase splines, or, when the front ujoint goes, driveshaft would hit the oil pan inevitably leading to oil loss and, if not caught in time, oil starvation/severe engine damage. All this results in towing bills, interrupted family/business trips, weeks at the dealership awaiting repairs, and ofcourse thousands in damages as well.
A couple months ago i was asked to maybe come up with a solution similar to a driveshaft loop on race cars, so I thought hell why not, i got under my f85 and was stunned by the lack of space, or the lack of possible mounting points given the layout of the f85 chassis plus having exhaust in the way, tcase crossmember, and an abundance of metal shielding towards the front of the driveshaft flange. So i went to town with cardboard and my stapler lol. Later on Myself and a couple of super helpful and creative guys at the local machine shop made a mock up out of thin aluminum to confirm angles and overall fitment, we had to redo this 4 times, but here we are with yhe finalized design and fit !
Initial goal was to have something that would utilize factory mounting points, be simple to install and function, as well as reversible if needed to remove upon trade in or any service work. This driveshaft shield is made out of 3/8” 5952 aluminum plate, and installs in the transfer case brace factory hole (will need to be enlarged just a little), bolts up to the front crossbrace and uses factory hope there, and also requires drilling two mounting holes in the aluminum engine belly pan for a solid mount/install. Top piece is installed first over the driveshaft, then you pretty much slide the bottom piece in , install bolts into the factory bolt holes, and after that youre ready to drill two holes in the belly pan. Overall install shouldn’t take longer than 30 minutes, also should prevent driveshaft from hitting things if either one of the ujoints gives up the ghost. Sleeve is made to be pretty tight around the driveshaft, so if ujoint breaks, it stays inside the loop with minimal travel, making a lot of noise. I currently placed a bulk order of 16 pieces where 4 pieces were already called for. I will have more made depending on how this takes off, i am also super close to having the HD driveshaft made using SKF replaceable ujoints, fully balanced, with longer splines and high quality pipe with minimal runout. Hopefully will have this part ready in the next couple weeks, definitely getting there 100%.
Please let me know what do you think of this piece, and if anyone would be interested in placing an order with me. I am trying to finalize the cost with the shop, so hopefully with material, hardware, and labor to make both halves, i should stay in the ballpark of 340-380 a piece shipped, will take a few more days to confirm the cost , also, the hardware in the pictures will be changed up just a little, this was my personal test piece , i also had it painted flat black, normally these would come as a plain aluminum part ready to install.
PS F15 safety piece will be available shortly, ill have to look into plastic trim that is in the way and proper way to make everything work together for a clean and efficient install
mvrt44.00
Chilled278.00
      02-05-2023, 01:08 PM   #2
Drives: 2018 f85
Heres a few pics i was able to find real quick as an example of the damages the driveshaft can cause if the ujoint blows up
      02-05-2023, 04:12 PM   #3
mstgeer
28
Drives: 017 F85 Donnington Grey, Arago
I'm in for this and the front drive shaft.
      02-05-2023, 04:29 PM   #4
Drives: 2018 f85
Got you on my list. As many people as i got contacting me, i will probably double my order with the machine shop lol
mstgeer28.00
      02-05-2023, 05:52 PM   #5
cncmastr
cncmastr's Avatar
Drives: E46 ZCP, F85, E70, G07
2018 X5 M  [0.00]
2020 M2 CS  [0.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [0.00]
Awesome! Sign me up!
I love how it looks OE.
      02-05-2023, 08:00 PM   #6
Stamps
Drives: 2017 F85
This looks well done. Nice work.
As a dumb sales guy I’m hoping this question doesn’t come off sarcastic, but how do you connect the two pieces?
I see 4 nuts and bolts, but I’m not sure how one would be able to install like the picuters in the absence of some child labor (tiny hands). Maybe the scale has been lost on me.
(Edited because I can’t spell)
      02-05-2023, 08:46 PM   #7
Drives: 2018 f85
Good question, there are nutserts (rivnuts) pressed into the top piece. They have threads in them, then you screw 4 bolts 2 per side and connect both pieces
      02-06-2023, 02:06 PM   #8
zeroping
Drives: X5M
+1 for this and front shaft.
      02-06-2023, 03:28 PM   #9
Drives: 2018 f85
Got you on my list, I already doubled my order with the machine shop this morning 👍
      02-06-2023, 05:45 PM   #10
iam_tylerbrown
Drives: E46 M3, '17 X5M
Great idea! Execution of design looks good in the photos.
      03-17-2023, 08:23 PM   #11
Drives: 2018 f85
Fellas finally some good news!!!! these are finally in stock, i will start shipping them out this week !!!
Search this Thread:
Advanced Search
Copyright ©2000 - 2023, vBulletin Solutions Inc.
