02-02-2023, 08:33 AM | #221 | |
Rep 84
Do I still need to flash the firmware to get to X/Y? What are the options for this? |
02-02-2023, 09:37 AM | #222 |
Right to Repair Enthusiast
95
Rep 115
Yes, you will need to flash the NBT firmware using E-sys to version X or above. You can then code Fullscreen CarPlay on using either E-sys or something like BimmerCode.
02-03-2023, 12:46 PM | #223 |
Rep 113
Drives: X63.0D, 911C4S
well that would be great but I am not getting new issues, I reloaded the 240GB database again. and followed each step,
1. connected to car via VIN and brings up my F16 model and correct shipment I-step 2. new I read the FA and saved as FA order 3. then I read and saved the SVT as SVT_ist 4. next I did calculate under SVT Target the KIS calculate using shipment I-step and newest it showed. F025-18-03-540 shipment and target of F025-22-11-510 (also tried it with an older I-step 22-07-540). saved that file as SVT_soll 5. next further down under TAL, I tried to TAL calculation and get this error. generating TAL failed (C041) DetailInfo must not me null for ECU ECUId:ICAM_0x06 [1608]. I am using an Emet cable is that the issue? thanks |
02-03-2023, 12:49 PM | #224 | |
Rep 41,159
Do exactly: 1) Read FA 2) Select Read VIN our of FA & "Read VIN" 3) Then do all of the ECU Selects - blflash... 4) Do the Check Software 5) Then select the "Read VIN out of FA" which greys out the "Enter VIN" 6) Then do the Start...
02-03-2023, 03:35 PM | #225 | |
Rep 113
thanks |
02-03-2023, 03:37 PM | #226 | |
Rep 41,159
02-03-2023, 04:24 PM | #227 |
Rep 113
no I am using Enet cable. but only get as far as step 10 to create TAL file that is why I was wondering if something is set wrong in my Esys files to make it think I am using Icam not enet but I cannot find anything in the configure files or the setting?
thanks |
02-03-2023, 04:27 PM | #228 |
Rep 41,159
If you are not flashing ICAM, then delete ICAM from svt_ist, and then calculate svt_soll, and then TAL.
02-03-2023, 04:40 PM | #229 | |
Rep 113
is there another place in esys to turn off ICAM completely? thanks |
02-03-2023, 04:55 PM | #230 |
Rep 41,159
02-03-2023, 05:14 PM | #231 |
Rep 113
I edited it with notepad, so I think that was the error. I just generated a new file and tried to use the SVT editor but same now says this file in missing ECU data or was generated on a different car. so it seems I cannot find a way to edit this file which has the reference to ICAM. Man I am a retired IT guy and this is very crazy stuff. my newly generate SVT is attached. since I don't know what is the best way to edit and I am not certain which lines to delete. I pass it to you, but since it only seems to load when I read the file, not sure how to get to point B.
It generates a file with ICAM in it. but when I delete with editor says cannot load due to generated on a different car. and likewise I cannot edit in in the SVT editor without a similar error. ??? Last edited by rmacgurn; 02-03-2023 at 05:16 PM.. Reason: attach file |
02-03-2023, 05:23 PM | #232 | |
Rep 113
I just must be missing something ... |
02-03-2023, 06:38 PM | #233 | |
Rep 41,159
02-03-2023, 06:55 PM | #234 |
Rep 113
ok will do in am. but the svt file posted is the original I just downloaded using esys before I quit. I have the saved FA on my laptop in garage but it's dinner time.
I can delete all and redo the process one more time which allows me only to read/save SVT_ist, SVT_soll and FA_factory file. thanks |
02-03-2023, 07:08 PM | #235 | |
Rep 41,159
02-04-2023, 09:03 AM | #236 |
Rep 113
Shawn here are the ist, FA and soll files from my car that give the error about null data and won't generate a tal file.
thanks |
02-04-2023, 10:42 AM | #237 | |
Rep 41,159
What E-Sys version are you using?
02-04-2023, 10:43 AM | #238 |
Rep 113
3.40.2 and no it’s just saved after generating it.
02-04-2023, 11:31 AM | #239 |
Rep 41,159
I got it to load, but svt_ist has NO CID;s in it.
02-04-2023, 11:34 AM | #240 | |
Rep 113
let me know if this is any better, (not I saved as SVY as I didn't have my glasses on) thanks Last edited by rmacgurn; 02-04-2023 at 11:36 AM.. Reason: typo |
02-04-2023, 11:35 AM | #241 |
Rep 41,159
It isn't. Open svt_ist in Notepad and search on CID. All 3 are missing.
02-04-2023, 11:41 AM | #242 | |
Rep 113
strange that I got past this step before, should I just delete the entire installation and reinstall Esys again? that will be the 3rd time. but as I say it did one time get to step 18 and gave the only module to update as DME. |
