      09-30-2019, 01:32 AM   #1
sheepwow
Drives: F85
Lug bolts HELP!
What are the OEM lug bolts seat type? Do I need new bolts for aftermarket wheels like Vossen HRE ETC. ?
      09-30-2019, 07:17 AM   #2
ferrarif1
Drives: F85, G05, E46M3
OEM are cone style lugs. Hard to answer what lugs you need for aftermarket wheels as it can he cone, acorn or flat. Check with the wheel manufacturer and go from there.
      09-30-2019, 11:21 AM   #3
pachieh
Drives: '17 X5M
Also, if you use spacers, you will need longer nuts.
      10-01-2019, 11:13 PM   #4
sheepwow
Drives: F85
Do you use OEM lug bolts on your Vossen ?
      10-01-2019, 11:34 PM   #5
pachieh
Drives: '17 X5M
I do, I'm not running spacers either.
      10-02-2019, 09:12 AM   #6
GODZLLA
Drives: 2016 X5M
I suggest you convert to stud and lug nut. Its very simple and not very expensive. You can get the studs and lugs from these guys. I am running them with my Vossens and have had no issues.
https://motorsporthardware.com/
      10-02-2019, 11:19 AM   #7
Ehloo
Drives: 15 x5 m
Most quality and high end forged wheels are cut to
Accept using stock bolts. But you have to be careful as some wheels might fit on other carsif you are buying them used
      10-02-2019, 11:40 AM   #8
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
Which ones are you running?
Pics on your ride?
No. Try not. Do. Or do not. There is no try.
-Yoda
      10-02-2019, 03:38 PM   #9
GODZLLA
Drives: 2016 X5M
Pics on your ride?
75mm studs
Pics are on my Instagram page in my signature block.
      10-02-2019, 04:53 PM   #10
sheepwow
Drives: F85
Might just get a new set of Vossen HF-3, that should be fine with oem lug bolts
      10-02-2019, 10:59 PM   #11
Big companies like Vossen and HRE will cut your wheel to accept OEM lug bolts.
If it doesn't, most of the time they will supply you with the new set or tell you which one to buy.
