      05-10-2024, 11:40 PM   #1
raja101
Drives: 2017 X5 35d
Lowering F15 - H&R
Hey guys, new to posting and searching on this site so please bare with me. I am looking at lowering my F15 35d with third row seating and self leveling suspension. I saw online the following sets but can't understand which one is better. Any help would be appreciated. Why would anyone go with the two springs and links if there is a four spring option?
https://www.turnermotorsport.com/p-5...CABEgKdKvD_BwE
https://www.vividracing.com/vtf-adju...9=37726&ymms=1
      05-11-2024, 02:49 PM   #2
jiggz
Drives: E90 M3|F15 X5 50i
Self-leveling suspension = rear air suspension.
You don't have traditional springs in the back (airbags/air springs instead), therefore you'd need front springs + rear end links. So, the first link you posted.
H&R is not known to be the most comfortable setup, so hopefully you're not planning to go too low or you may end up disappointed.
      05-11-2024, 09:16 PM   #3
1norseman
Drives: X5 50i
I agree with Jiggz, stay away from H&R VTF if you want comfort and go low...
But if you go with H&R VTF, I recommend also getting a set of Koni Reds.
Use Google to search the forum, often works better IMO.
Also, you can reach out to r33_RGSport and see what deal he might be able to get you on the lowering kit.
Then once you are lowered, he can help you out with right size spacers...
      05-12-2024, 08:42 PM   #4
Geo41e
Geo41e's Avatar
33
Drives: 2018 BMW F15 xDrive30D M Sport
my 2 cents, and also as stated above
your rears are air bags, so no springs - hence links to tell the system to sit "lower"
I installed Eibach springs on the front, and adjusted the rear via a snap on tool.
For what its worth, depending on how low you want to do, i would recommend getting a set of coilovers/aftgermarket shocks, if you want to go lower than 15mm. Even my Eibachs are only 12 - 15mm lower than stock, and the ride in comfort mode is very bouncy. Sport mode is good, but can be abit too harsh for Sydney roads.
2000 Honda DC2R Integra Type R - Sold
2003 Nissan Z33 Z350 - Totalled
2010 Holden Commodore SSV - Sold
2008 E60 LCI 530i M Sport - Sold
2018 F15 X5 XDrive30D M Sport - Current
      05-16-2024, 10:59 AM   #5
SD35D
Drives: BMW 35D
I initially installed h&r springs but upgraded to silvers coil overs. I installed the fronts and left the rear on airbags. Definitely worth the extra 4-500 dollars to me. It rides really good and can go low. Bc racing coilovers is about the same price and are good quality as well
