11-03-2022, 08:45 AM | #1 |
Rep 1,592
Drives: 2011 335d, M-Sport
Custom Covered Dog Ramp (Originally cut for F15 X5)
Morning, All! My lovely better recently traded in for a Cayenne (against her will) with different interior dimensions and colors, but left in my home office is the heavy duty telescoping pet ramp and custom-built (homemade) black carpeted cover which we kept in the trunk of her X5 for easy entry for our pup. The dog ramp specs are as follows... Ramp Weight Supported Weight Length Height Tread Surface 13 lbs 400 lbs 39" - 72" up to 30" 13" [originally purchased here: Chewy] In Car... Recessed (from trunk opening)... Recessed (from above)... Extended (from above)... The cover would likely support around 150-200 lbs-or-so (no problem with our little guy) and could easily be supported with some angle iron for additional weight capacity. Would likely fit other vehicles as well, but was specifically cut to fit an F15 X5 with the rear bucket seats pulled 1 notch forward. Was (laughably) easily one of the most broadly complimented "mods" ever installed to one of our vehicles. $120. Local pickup only (20816). Happy to test fit if you have a different vehicle you want to try it in.
02-11-2023, 02:36 PM | #2 |
Rep 1,592
FYI: This is still sitting in the office if anyone needs it.
Tags |
accessories, pet, ramp |
