01-11-2024, 07:19 AM | #23 | |
Rep 3,006
Are you saying the sludge will eventually biodegrade? Last edited by omasou; 01-11-2024 at 07:37 AM.. |
01-11-2024, 07:32 AM | #24 |
///M driver
16017
Rep 499
Drives: 2022 M3 6-speed
I actually went 14 years (!) without getting the septic pumped -- it was overdue to be sure. More recently went 5 years.
I did a large addition to the house in 2010, adding a bathroom (taking the count to three) but not a bedroom (my setup is three bedrooms + disposal but only two persons) and the county insisted upon adding a second septic tank for the addition but without a leach field. Instead, they specified a line that pumps from the new tank to the old tank, thereby integrating the two tanks. Talk about $$$...
'22 G80 M3 6-sp Portimao Blue/Tartufo
omasou2089.00 |
01-11-2024, 07:48 AM | #25 |
Rep 3,006
OP I cannot find anything information about never having to pump the DBox. What I did find is what can happen if you don't.
A concrete D-box can typically last up to 20 years. However, in the event of sludge buildup, tree root invasions, improper maintenance, heavy machinery on top of the box or other issues that can cause unrepairable damage to your distribution box, you may need to replace it. Some signs of a failed box could look very similar to a septic tank system blockage or a leach field issue. https://www.kulksplumbing.com/what-i...tribution-box/ Frequency The cost to get a septic tank pumped can rise drastically when property owners aren't keeping up with having a tank pumped every three to five years. Not pumping a tank on schedule will cause solids to build up until a tank's holding capacity is diminished, which results in a clog. See #4 & #5, in the section 5 Ways to Save on Septic Tank Pumping Costs. https://www.angi.com/articles/how-mu...mping-cost.htm BTW, the prices listed on the link above seem high, as a reference my last pumping cost was $240, so shop around. Public sewage in my area is ~$300 yearly vs. my $240/3 years. Last edited by omasou; 01-11-2024 at 08:18 AM.. |
tranquility3245.50 |
01-11-2024, 08:02 AM | #26 |
Free Thinker
16967
Rep 7,455
The bedroom based thing is important if you buy an older home with a septic system. The original system was probably sized according to the number of bedrooms. If you expand the house by adding a dormered upstairs area or add a bedroom over a garage, for example, you can run into issues with the local authorities about your now undersized septic system. Can cause problems if you try to sell the house.
01-11-2024, 08:11 AM | #27 | |
Free Thinker
16967
Rep 7,455
2000cs3502.50 |
01-11-2024, 08:14 AM | #28 |
Rep 1,247
I've lived in my house since 2007 and it was built in 2005 and my septic system has given me zero troubles. I have it cleaned out every 4-6 years just to make sure, but it has never given me any issues at all. *KNOCKS WOOD*
Best thing about a septic system??? It usually mean you are far enough away from other asshole people that you can't connect to a sewer system - which is well worth it to not have annoying ass neighbors which will FOR SURE be a problem - far worse than a septic system. LOL
5
01-11-2024, 01:17 PM | #29 | |
Rep 1,004
I get mine inspected every 5 years, and pumped if necessary. Usually just a couple of inches in there, plenty of capacity available. I have never had a problem with the D-Box, but if the tank overflowed it would run into the dbox and then the leach lines - which could be a very expensive problem (dig the whole system up and repair/replace). Maintenance of the system, like our cars, keeps long-term costs down. Having no trees or invasive roots near the d-box or leach lines is really a good thing. |
01-11-2024, 01:29 PM | #30 |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I currently have septic and basically it's been just like living in the city other than making sure I get the annual maintenance done and then a 5 year re-inspection. The only major thing to make sure you don't do is put feminine hygeine products or other non-dissolvable items in there. You're just asking for trouble. You might think you have crude oil bubbling up but the smell will tell you otherwise lol. Eventually the city will make it out to me and it won't be that big a deal to hook up at that time.
Main thing to check if you're buying a house with septic is to ensure it meets code for the number of rooms/occupants the house was built to. Older houses are more likely to have a problem since an addition may have been built while the septic system was overlooked and then too small for the now bigger home and more people. |
2000cs3502.50 |
01-11-2024, 01:31 PM | #31 | |
Primo Generalissimo
4672
Rep 4,023
Drives: All of them
01-11-2024, 02:41 PM | #32 | |
sportscars only
3246
Rep 3,198
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
vreihen1615333.00 |
01-11-2024, 04:05 PM | #33 |
Rep 4,821
Wells and septic systems are pretty common around me but we chose to prioritize buying in a neighborhood on city water and sewer to bypass any real concerns about maintenance, well water or septic problems. I lived in a house with a septic system when I was a kid and remember problems, but not specifically what they were. I also have a friend who had a problem with their septic system because the builder installed a septic system that was too small for their house once they had kids and was costly and difficult to repair. If I recall they ended up spending many thousands of dollars to connect to the sewer system years later because they never got it straightened out, probably because they kept getting sold on “easy” solutions doomed to fail because the system was too small.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
01-13-2024, 01:21 PM | #34 |
sportscars only
3246
Rep 3,198
I'm analyzing this diagram and am confused about some things:
1. why are there 2 lines, plumbing (why is there a 'vent'?) and septic? 2. I guess the drainer/maintenance guy accesses the tank where the scum/sludge is located? How can he possibly check the whole system for prbs? 3. is this setup ideal or would it be better on a slope where the house is higher elevation, then the septic tank, then the leachfield? 4. someone mentioned electricity loss being a prb, what did they mean since I don't see any moving parts? Totally new question: what happens in cases where there is no city water access? I guess one needs to install a well? How does that work and what are the concerns? I would imagine the biggest ones being limited supply and if the quality if good enough?
01-13-2024, 01:45 PM | #35 |
Rep 1,910
Drives: 2020 BMW M4 CS
I've lived with septic systems for most of my life and honestly I would not have it any other way. Here are a few things I know or have learned
The system must be properly designed, sized and constructed. I really recommended pea stone under the tanks and connecting pipes with proper compaction to eliminate setting. Have risers on the tanks to ground level rather than letting some lazy contractor bury the lids. The only system that is legal in most area's uses a dosing tank before the leach field. If your codes don't require that do it any way. The field will last a lot longer. The field should have clean outs on the ends of the runs. I cut mine to ground level and I fit screw on caps. It makes mowing easier and when I need to flush the leach fields it is easy to find the clean outs. Keep heavy equipment off the system. Read up on what you can put down the system. I do use a garbage disposal but it is seldom used as I use a composter most of the time. The best part of having a septic system is having a well. Have the water tested and treat as required. I do have to run a water softener. When I go to friends who are on city water, I can't stand the taste of their water. Well water makes a much better cup of coffee IMO Last but not least know that the cost in maintaining a septic and well pale by comparison to the monthly cost of most water/sewage bills and if you are ever in a sewer assessment you will rue the day you got hooked up. Last edited by Car-Addicted; 01-13-2024 at 02:05 PM.. |
vreihen1615333.00 tranquility3245.50 |
01-13-2024, 01:54 PM | #36 |
Free Thinker
16967
Rep 7,455
We have a $175 annual maintenance contract with the septic company that installed our system. Sometimes it feels a bit like extortion. (That's a nice septic system you got there. Be a shame if something happened to it.) They supposedly come around once a year to inspect the system and they'll pump it free of charge if it needs it. In 22 years of living here, I've never seen them come by. But I have asked about it before and they always come up with a date and time they were here.
That said, the contract also covers labor should the system need repair. Last year our aerator died, so we had to have it replaced. We paid for the new one, but the septic company pumped and cleaned the tank and installed the new aerator and alarm system free of charge. I guess we're good to go for another decade or so.
Car-Addicted7049.00 |
01-13-2024, 09:39 PM | #37 | |
Rep 1,913
Drives: Here and There
You’ll pay by the foot to drill, and you’ll want a minimum, adequate flow for the house size. No guarantees on finding water or enough of it. Water testing may result in a variety of needs to purify - some just need a softener, other need UV and other items. If you lose electricity, you lose water. Gotta have it for the pump. All told, I think it tastes better and at least I know what’s in it! |
tranquility3245.50 vreihen1615333.00 |
01-13-2024, 10:10 PM | #38 | |
sportscars only
3246
Rep 3,198
How does well water compare to city water in terms of health safety? Needing a well seems there will be way more potential prbs vs needing a septic tank.
01-14-2024, 07:18 AM | #39 |
Rep 1,913
Once you’ve got a well, you’re pretty set. Just maintain the system.
Feel free to search for images of the inside of municipal water systems! |
01-14-2024, 08:03 AM | #40 |
Rep 1,004
Usually the drillers have a good idea of the depth and rock so will guide you on drilling. Well water should be tested, can have a funny taste or odor which bothers some and others don’t mind. I have friends on wells who use it for everything except drinking - buy bottled water for that. Others just filter it.
Wells are located outside of the septic field, etc so they don’t get contaminated. We are on city water and septic, and that is the arrangement we had in KY too. |
01-14-2024, 08:50 AM | #41 | |
Rep 1,913
The new place will be the polar opposite - well water and septic. It is our county code that the well must be a minimum of 150 ft from anything septic related. |
2000cs3502.50 tranquility3245.50 |
01-14-2024, 11:45 AM | #42 |
sportscars only
3246
Rep 3,198
To ppl w well systems....are there any concerns about freezing? I live in Canada so haha.
01-14-2024, 12:04 PM | #43 | |
Rep 1,004
On the other hand, with city water I have had the meter freeze several times, different houses. Fortunately not hard enough to break pipes or the meter but enough to stop all flow. Took my longest extension cords and hair dryers/heat guns to get it flowing again (and several hours), then buried it in straw to help keep the cold from settling back in. Always leave a faucet at a fast drip during extreme cold, too. |
01-14-2024, 02:01 PM | #44 | |
Recovering Perfectionist
15333
Rep 941
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
A shallow well (less than 15 meters) with an above-ground jet pump is more prone to freezing, and needs to be in a heated environment of some sort. I'll let you Google pitless adapter, one pipe versus two pipe jet pumps, etc.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
2000cs3502.50 |
