11-13-2017, 03:24 PM | #45 |
Rep 43
02-27-2018, 09:55 AM | #48 | |
Rep 7
Here's the panel on the driver's side rear that it is behind, a simple pull and it pops out: Here's what's behind there: There are two 5/6" nuts that come off easily with a deep socket. You can see the one in the front, but there's another one in the back in the exact same spot. This is after the first one is removed: And with both nuts removed and the unit pulled out: Push the little grey button in and slide the black lever over it and the connector comes right off: Put the heat sink unit back onto the bolts, tuck the wire and connector up behind there, and re-install the 2 nuts holding the heat sink onto the bracket and voila! Push the cover panel back on and your ears will be saved going forward! |
02-27-2018, 08:34 PM | #50 | |
Rep 43
08-26-2018, 02:52 AM | #54 | |
Rep 222
https://f15.bimmerpost.com/forums/sh....php?t=1243856 |
iconoclast7265.50 |
08-27-2018, 06:51 PM | #55 | ||
Rep 702
You may think I'm crazy but sometimes I want to hear the fake sound |
08-29-2018, 06:52 PM | #57 |
Rep 702
08-29-2018, 06:58 PM | #58 |
Rep 31
08-29-2018, 07:08 PM | #59 |
Rep 702
if helpful, it's the plug to that small metal box
08-29-2018, 07:09 PM | #60 | ||
Rep 31
08-29-2018, 07:11 PM | #61 | |||
Rep 702
08-29-2018, 07:12 PM | #62 | ||||
Rep 702
10-08-2018, 02:20 PM | #64 |
IG: @88jae88
1622
Rep 1,741
So I did it via coding with the Carly app and man what I difference! I rather the the sound of the natural exhaust and my sound system is clear and clean!
IM POOR..
10-08-2018, 03:28 PM | #65 |
Rep 81
I cannot for one second understand you people that pull the plug on the ASD rather than the fuse.
1) power still going down the cable needlessly 2) takes max 10 seconds to pull the fuse |
