03-12-2020, 06:54 AM | #1 |
Rep 48
Morning start "bog down"
I am reaching 60K miles (58,000K, 2014 3.5 gas) and haven't done any other maintenance then routine oil & filters.
I started the car and the tachometer went up towards the 3 like normal but when coming back down dropped below the 1 and kinda "shuttered" if you will. Do you think this is plug related, possible fuel or the dreaded vacuum lines? I have plugs ready to go, please let me know what you think. |
03-12-2020, 09:44 AM | #3 |
Rep 287
Drives: 2020 M4
Garage List 2020 BMW / F82 [0.00]
2016 BMW X5 35i [0.00] 2012 Porsche 991 C2S [0.00] 2013 Audi S8 [0.00] 2004 Ferrari Challe ... [0.00] |
If it only did that one time, I'd be tempted to just blow it off.
Put the plugs in and see if that has any impact. |
03-12-2020, 09:49 AM | #4 |
Rep 48
Yea, it was odd. I wasn't 100% paying attention as it was 6am and headed to work, all I really noticed was that it stuttered.
03-12-2020, 09:51 AM | #5 | |
Rep 48
I think I will see what the plug change will entail, time, work, etc... |
03-12-2020, 04:24 PM | #6 |
AutoPilot
97
Rep 87
Drives: 19 X1,18 M550i,15 X5,14 328d
Garage List 2011 Mercedes GL550 [0.00]
2019 BMW X128i [0.00] 2015 X5 XDrive35i [0.00] 2018 M550i [0.00] 2014 328d [0.00] |
My 2015 3.5 started doing the same thing at about 48k miles. It was still under warranty, so I took it to the dealer... They said a software update fixed it. No parts required. Has not done it since.
03-12-2020, 05:16 PM | #7 |
Rep 46
03-12-2020, 11:39 PM | #8 |
Rep 26
I have this same issue
Vehicle will randomly on start up, not based on outside temp or engine temp do this rpm rev up. Then shutter and bog and shake then level out and all is fine I get a pretty crazy vibration idling sometimes as well that you can feel through the steering wheel. Any help appreciated. Might just take to dealer for a software upgrade |
03-13-2020, 09:24 AM | #11 |
Rep 48
I am not sure, after further research it appears to be a common, misunderstood phenomenon with these vehicles. Sometimes the issue may be something more severe and problematic, and then sometimes possible a gas issue, bubble in the fuel line... I have had vacuum line problems with my older 04 528 I had, but the issue didn't come and go, that is what I am pondering.
The issue didn't happen this morning, or yesterday afternoon leaving the office... One of the threads I read is when these vehicles are woke up from their "sleep" they prime the fuel lines. Some stated that this procedure may have been the issue, that the priming wasn't fully established, or a second or two may have helped it out? |
03-13-2020, 11:24 AM | #12 |
AutoPilot
97
Rep 87
10-14-2021, 08:24 AM | #13 |
Rep 48
This same problem seems to be getting a little worse as the temperatures cool down. The plug change last year didn't seem to help the problem, from all the research I have done (not much out there with this issue) it's really not exactly known what the issue could be. From reprogramming, injector, plug, coils, vacuum leak. I would think the vacuum leak would be prominent when the motor is warmed and running too, not just cold start. I had a couple codes but no good leads to this problem.
Could I check the injectors when the engine is running with my Foxwell scanner, or possibly have the motor running and check certain parameters that could lead to an issue. Or have the Foxwell connected and on for an early morning start? EDIT: I am going to try Chevron Techron Fuel injector cleaner first 2nd replace the coils with new plugs 3rd try and narrow down "if" it's a certain injector Last edited by dr_greenthumb; 10-14-2021 at 09:13 AM.. |
11-01-2021, 09:18 AM | #14 |
Rep 48
I just now got one full tank through with the Techron Complete cleaner.
The "bog down" issue seemed to be gone, but then it did it once briefly, but not as bad. That was about half way through the tank with cleaner in it. I have one additional bottle of snake oil Techron cleaner, not the "complete" cleaner bottle, but it's made for a 1/2 tank of gas, seems as a half clean. Instructions: Add the entire bottle and fill to 12 gallons. I'll run this through and report back. Last edited by dr_greenthumb; 11-01-2021 at 12:36 PM.. |
11-01-2021, 06:38 PM | #15 | |
Insta~ f10_sapphire
158
Rep 412
Insta ~ f10_shapphire
11-01-2021, 09:49 PM | #16 |
Rep 7
I was having the same problem every day the first time I started the car no matter the outside temp. I ran a can of the Liqui Moly injector cleaner through the tank and it hasn't done it since. Of course now it will likely start doing it again tomorrow morning.
11-02-2021, 07:35 AM | #17 | ||
Rep 48
11-03-2021, 12:38 AM | #18 |
Insta~ f10_sapphire
158
Rep 412
It's called Executive Garage Located in Oklahoma City. Owner/Tech is MJ. He is very trained in our vehicles.
11-04-2021, 07:32 AM | #19 |
Rep 48
RPM dance happened again this morning, I really think the injector cleaner helps, but didn't fully mitigate the issue. (I say this bc the issue was everyday, now it's only random)
Can the FOXWELL scan tool help me to diagnose / check the injectors? |
11-07-2021, 07:24 AM | #21 |
Rep 165
+1 I would change the injectors and while you add it just change the coils and the spark plugs if you haven't done so. They are all pretty easy to change if you do it yourself.
11-07-2021, 07:30 AM | #22 |
Rep 364
Drives: F15 M50d / ex E90 335i / Panda
