      04-17-2019, 06:41 AM   #1
Siy
Drives: XM5
X5M drive settings
Apologies all for the most basic of questions - I got my 2016 X5M about 4 months ago - set it up, and havent really altered the settings much. However was reading a post on here yday when the OP stated he has exhaust set to sport+
Can anyone give me a quick tutorial as to the 4 different buttons - there is the gear shift button, below the gear selector, which I think alters how aggressive the gear change is (and when it changes up?)
Then there are the 3 buttons together - steering wheel, which seems to affect the feel of the wheel - suspension, which assuming changes the damping to a degree - then there is the other one - which goes from efficient to sports, to sports plus.
This third one is the one that confuses me - if there is already a button affecting the gear cahnge etc, what does this one do?
Sorry for the basic question - but I would like to get this right
thanks
      04-17-2019, 08:47 AM   #2
cmyx6go
cmyx6go's Avatar
15761
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Go in your idrive to the M settings under vehicle. You can set them once and just press the M1 button instead of hitting each button every time.
These are my daily.
Engine - Sport +
Suspension Sport +
Steering Sport +
Transmission D2
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
      04-17-2019, 09:09 AM   #3
Siy
Drives: XM5
Thanks - I have already set it up on the idrive etc - but my failure to understand is basically what the 'Engine' setting does - I understand that the Transmission setting alters severity of gear change and when it actually changes - but failing to understand what the 'Engine' function actually changes.
Assuming Sports+ is much less economical - but does it also alter the exhaust (open/close the vacuum for the louder noise)?
      04-17-2019, 09:11 AM   #4
foldpages
Drives: 2020
2020 AMG E63 S  [0.00]
2020 Jeep Wrangler  [0.00]
2017 X6 M  [0.00]
It's my understanding that the engine settings change the throttle response. In Sport and Sport+ it also opens the exhaust valves.
      04-17-2019, 06:33 PM   #5
ajgraham
ajgraham's Avatar
Scotland
23
Drives: Nada
For the gearbox button you have 6 modes: D1, D2, D3, S1, S2, S3 (D = automatic, S = manual with S3 being best performance). You can also put it in manual mode by pressing the paddles on the wheel or pushing the gearstick forward (+ plus) or back (- minus).
The other button you weren't sure about is throttle/engine response. As was mentioned you can map them to the M1 and M2 buttons on the steering wheel.
      04-18-2019, 07:51 AM   #6
gqgambler
gqgambler's Avatar
Drives: Fast & Furious
Gearbox button will affect the speed of shifting through the gears. The higher the number the faster and more noticeable/harsher the shifting.
rem40i132.00
      04-18-2019, 08:30 AM   #7
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
program one of the shortcut keys for "self-cleaning" function like your oven. it is my favorite feature within the ultimate executive package. details found here: https://www.bmwusa.com/self-clean/f85.html
      10-13-2019, 05:58 AM   #8
f30er
f30er's Avatar
Drives: F85
I can't find what this does. The link just takes me to the BMWUSA website but can't find anything related to "self-cleaning"
      10-14-2019, 11:14 AM   #9
TheVazha
Drives: X5Mmmkay.
Haha I think he meant it an analogy, like a shortcut.
My daily used to be:
Engine: S
Suspension: S
Steering: S
Then I realized that the difference is unnoticeable from S to S+ (other than steering which I find to be way too artificially heavy is S+). With a tune, it's basically all the same except for efficient mode. So new daily is:
Engine: S+
Suspension: S+
Steering: S
Also, tuned and dd, transmission in the "3" setting is unbearable. For spirited canyon runs it's the only way, but for daily, it's not great.
But to answer your question, you can program the M1 and M2 buttons to whatever custom set up you want. That said, pressing any of the buttons after engaging M1 or 2 settings automatically just turns off the "M" setting light, even though the parameters are basically the same.
Also, if you're in D mode and trans is at a "2", if you click the paddle or gear lever to the right it automatically takes you into Manual mode and the trans setting automatically shifts to the 3rd shift setting.
