10-16-2023, 01:03 PM | #67 |
///M Powered for Life
11490
Rep 10,329
We just did this job on our 2015 X5M. We bought it with aftermarket HJS high flow cat downpipes and are installing the OEM dps.
Short DIY with no pics: Up top Remove the bridge that holds a bunch of cables, then the heatshield that covers the dps Remove primary and secondary O2 sensors Remove the bolts holding the v-clamps so the top of the dps are loose On each dp there is a small bracket that goes from the block to the dp. Remove it on both ends In the bottom Remove or loosen the exhaust so you have some wiggle room, then disconnect the exhaust from the dps Remove two nuts from each dp in the bottom section, they hold the dp in place The passenger one can now be removed. It is removed from the top of the car. You will have to wiggle it to get it out, but it eventually comes out The driver's side is much harder. You have two aluminum pipes carrying transmission fluid to the transmission and also the front transmission driveshaft. All of this is pretty much in the way Wiggling the dp, you can get it to almost clear both of the studs that remain after you removed the nuts earlier. You can get it past the first one, but not the second one Loosen the bracket that goes into the transmission, it's a single 11mm bolt IIRC. Some fluid will leak out, but it'll stop before long and you can inspect the fluid to decide whether to do a fluid flush later on With that bracket loose, the two aluminum pipes can bend a tiny bit. Just that little bit is enough to wiggle the dp past the second stud that's in the way! Note this completely avoids loosening the other brace everyone is talking about. The 'other brace' is the other side of the bracket that has two nuts you removed earlier. That is a much harder option |
SaNGRia986.00 |
10-22-2023, 09:04 PM | #68 | |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
10-27-2023, 10:03 AM | #69 |
Rep 1,351
Yeah i struggled : )
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
