08-24-2023, 10:59 PM | #45 | |
Just me
23
Rep 80
Iluvbmw. I dont think there is such thing as the "best oil" you will have make a decision based on the products you have available in the market, Climate conditions of where you live, driving style (tracking or not) and also Oil change intervals In my case i can't use 5w -30 due to our hot weather almost all year round and i opt for slightly thicker 5w-40. Additionally while assembling my engine i measured bearing clearances they were within spec as i used OEM bearings but on higher side of the allowable range. |
08-24-2023, 11:11 PM | #46 | |
Just me
23
Rep 80
I don't mean to say LM is bad or is the best, I just changed my perspective of oils and thats why i changed brand but sometimes i question all the heaven and earth they promise users with all the marketing of different array products. |
08-26-2023, 11:07 AM | #47 | |
Rep 1,490
First of all, sulfated ash is byproduct. It cannot find its way into passages etc. There is some, SOME evidence that low-SAPS oils will leave less deposits on intake valves. But, that is about it. Second, no V8 has LSPI issues. At least those that don’t have dramatic tunes. LSPI Is primary concern in small turbo wngines, 1.5ltr, SOME 2ltr mostly bcs. they have very aggressive eco mode or in stick shifts when there is very low rpm and too much boost. If you run low-SAPS oil doesn’t mean you prevented LSPI (let’s assume your engine has that issue, and N63 does not). Both high-SAPS and Low-SAPS oils can have low or high calcium content. That is key in preventing LSPI. Too much calcium rects violently with too much pressure at low rpms. There are low SAPS oils with more calcium than many high-SAPS oils. So, you are shaking wrong tree here. |
08-26-2023, 11:35 AM | #48 | |
Rep 1,490
There are many other oils I would go vefore LM. One thing I don’t appreciate with LM is that they hide HTHS numbers like snake its legs. Motul, Mobil1 are far more transparent. That also says something. |
08-26-2023, 06:03 PM | #50 |
Just me
23
Rep 80
Hi, edycol Thanks for your clarification
So are you of the opinion that oil that has found its way into the combustion chamber can not contaminate fuel octane levels and lead to LSPI?? In this case a V8 N63 or S63 |
08-26-2023, 07:27 PM | #51 |
Rep 84
Leaving this right here for anyone else that isn’t tracking fully
https://en.wikipedia.org/wiki/Low-speed_pre-ignition |
09-04-2023, 10:00 AM | #52 |
Just me
23
Rep 80
I do find this article very helpful concerning engine oils, types, approvals & recommendations.
https://www.bimmerworld.com/BMW-Engine-Oil/ |
09-04-2023, 10:01 AM | #53 |
Just me
23
Rep 80
1st Service
Car has been serviced 1st time around 1,200km after rebuild
Thankfully oil was clear with no metal particles. Also i changed the filters to my oil catch cans (vent to air) as they were looking dirty with signs of oil soak. I did find oil laying around the catch can outlet where the filter is fixed. This goes to prove the importance of catch cans otherwise this oil will be dumped into the intake hose and unto the engine to be eventually burnt. I also added an oil cap crankcase breather (with a one way check valve) now i have 3 exits where blowby gasses are expelled thereby reducing crankcase pressures and improving throttle response. Also a bit of something for the interior : ) and the flashing brake lights will be installed later |
I Luv BMW90.50 |
09-06-2023, 11:29 PM | #54 | |
Rep 168
09-07-2023, 07:54 PM | #55 |
Just me
23
Rep 80
10-08-2023, 08:11 PM | #56 |
Just me
23
Rep 80
Another S63tu (F10 M5) Engine Failure that could have been prevented 🥺
https://youtu.be/Wh6YMQS9rAg?si=_YiW-wuIRqetNlxz |
10-15-2023, 03:06 PM | #57 |
Rep 41
Very interesting thread! I too am in the process of rebuilding my S63 (X5M F85) that I bought with a knock in the bottom end. Spun big ends on cyl 2 and 6. The block will need to be replaced due to bad cyl scoring on 2 and 6, so am currently on the hunt for a decent used block. Pics attached for those interested.
I have a question, how do you treat the BMW bearing designations when going oversize and aftermarket bearings. In my case, I will be going 0.5 on big end, 0.25 on main. Apologies, not trying to hijack your thread. Thought this thread could be a good source of info for other in the future. For those interested, I have attahced a list of parts I have bought/need (green need, yellow don't need). May have missed a couple of things here or there... Cheers Last edited by DrVirz; 10-15-2023 at 04:51 PM.. Reason: Pictures |
10-18-2023, 09:00 PM | #58 | |
Just me
23
Rep 80
Thank you for sharing your experience as well as an extensive detailing on your costs. Feel free to post about your progress so we can help out where we can. So youre actually going undersize and not oversize as machining the crankshaft reduces the OD of the shaft, requiring bearing shells with a smaller ID BMW will usually express that as Main bearing "+0.25mm" or 64.75mm (+0.25mm) Con rod bearing "+0.50mm" or 53.50mm (+0.5mm) I compiled the part numbers in the pdf i shared on page1 of this thread Bear in mind Standard big end journal is 54mm STD Standard main journal is 65mm STD Rear Seal diameter is 100mm But why dont you consider buying the block complete with its rotating assembly? (crank, pistons, rods etc) instead of machining the your crankshaft |
10-20-2023, 01:36 AM | #59 |
Rep 901
Congratulations on fixing this issue. However, I absolutely doubt it was caused by valve stem seals leak at 58k miles. Did you take a look at those seals on the engine to come to the conclusion that the VSS was the culprit? The N62 engine had the weakest valve stem seals and I replaced them at around 125k miles on my old X5 E53 after the vehicle started emitting huge plumes of the smoke of shame on extended idles (5-10minutes, e.g., at stop lights in heavy traffic). They were brittle and you could actually see the gap between the seals and the valve stems. The seals were improved on the N63 and later models. In fact, N62 folks use the N63 seals when doing the replacement. They leak typically due to extended oil intervals or engine overheating.
10-21-2023, 08:38 PM | #60 |
Just me
23
Rep 80
Thanks,
I have already come to peace as to what lead to the engine damage and tbh no longer dwelling on that coz i am now well over 5k miles since rebuild. I moved on lol But the main point of my thread is help explore different other options when faced with unfortunate engine failure instead of waiting for long months trying to decide fate of the car. In terms of both time saving & costs |
musa423.00 |
10-25-2023, 04:36 AM | #61 | |
Rep 2
Firstly i think everyone on this platform should give you a gold medal. You have been so detailed and informative with your issue. I have EXACTLY the same smoke issues. Only once it reaches temp does it smoke. Oil consumption is normal. Just really bizarre. 98,000km. 2011 N63. It’s a ticking time bomb I’m guessing. Thank you again for your post. |
10-25-2023, 06:46 PM | #62 | |
Just me
23
Rep 80
Hey gtp, thanks for your kind words Hopefully its not a ticking bomb, the smoking could be due several reasons on the N63/S63 mainly 1. Leaky turbos 2. PCV hose 3. Valve stem seals 4. Worn out piston rings 5. Cylinder wall scoring. U ll be lucky if its 1 or 2, so i’ll advice if you rule them out first by checking the intake boot/pipe connected at the compressor side of your turbos for any noticeable “fresh” oil residue. If present then your problem is at 1 or 2 If no fresh residue on the intake boot and you have consistent smoke (light or heavy smoke) either at cold start or operating temperature or even on both scenarios then this could possibly be 3 (valve stem seals) With 4 or 5, your car will smoke like a chimney non stop, all day all night lol But whatever case of oil smoking you find yourself in, before you eventually fix the issue, just make sure you use 1. High octane fuel 2. Change your spark plugs if you havent (in the last 30k miles) 3. If possible use thinner 0w-30 for the meantime. 4. Avoid heavy throttle at low rpms 5. Drive in sport mode (more fuel is injected) |
