10-14-2023, 03:38 PM | #1 |
Rep 42
Bootmod3 OTS stage 1 tune undrivable
When I put the tune on my vehicle I can’t drive with enough throttle to get a data log because the engine misfires, it goes into limp mode and cuts ignition off to the cylinder that misfired until I pull over and turn off the car and when I turn it back on all CEL lights are gone and there’s no record of it ever happening.
When I return it to the stock map I can drive the absolute piss out of it in all driving modes with zero counts of knock and can’t recreate the issue. Protuningfreaks is the vendor, I’ve contacted them and they say they can’t diagnose if I can’t get a datalog. They also confirmed I have the most current version of the tune. I’ve had the tune for a few years and only recently after putting the tune back on (I had reflashed to stock for last winter and then I’ve had too busy/crazy of a year to care to reflash back to the tune) have I had any problems. Anyone have any insight on where/what to start troubleshooting first? |
10-30-2023, 09:27 PM | #2 |
Rep 271
Sounds like bad spark plugs and ignition coils issue. You need one step colder plugs since you are tuned. I would also replace ignition coils at the same time.
https://burgertuning.com/products/ng...der-spark-plug |
11-17-2023, 02:04 PM | #3 | |
Rep 42
I’ve had coil packs go out before on other cars but when they go out, they go out for good, no weird intermittent stuff which is why I didn’t automatically just replace them. |
