07-06-2023, 04:44 PM | #1 |
Rep 48
Cold start X6M
Hi all,
I am fairly new to the X6M and have an issue, or rather a question regarding starting the X6M/X5M from cold or if it has been standing for a while. Average temp here is around 70-80 most days, and when starting RPM fluctuates a bit, then holds about 1500 rpm for about 20-30 seconds before it drops down to idle. This bit, I understand from what I have read here, is normal due to the cold start feature of the engine. What I don't find normal is that if I drive the vehicle up to temp, then park it for a while(say 30+ minutes), it still does this same fluctuate and high RPM before it drops down to idle. If I drive it, then park it for 10-15 minutes, it will start up and drop down straight away like I would expect it to do. Is this normal behaviour? I always feel it sounds like it a runaway at first, making unnecessary noise not what you would expect form a luxury car. If it is not normal, any ideas what issues I should be looking. Thanks. |
07-07-2023, 07:04 AM | #2 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
16-20 oz bottle of Techron to full tank of gas, two times in row should fix “initial rpm wobble”. The rest is engine management system/ catyictic converters. 1200rpm idle is preheating cats. Upon restart at different time intervals, engine management senses cats have cooled below optimum temp.
Buy top tier gas at busy statio…even Costco, use Techron every few tankfuls and don’t worry about cat preheat cycle |
07-07-2023, 01:43 PM | #4 |
Rep 138
I'll be it is normal, too. How many miles on your ride? This also sounds similar to old spark plugs, etc. I cannot seem to locate it at this time, but I thought I read that our spark plugs should be replaced every 30k miles.
2018 BMW X5 M in Donington Gray Metallic with Aragon Brown Merino interior, etc.
2016 Audi S8 Plus with Dynamic Package, APR Stage One tune, etc. |
07-07-2023, 03:28 PM | #5 |
Rep 592
Factory spec is every 30 k on plugs…it is in maintenance booklet that came with car
07-07-2023, 06:41 PM | #6 |
Rep 592
But plugs and engine filters and runs like a rabbit
07-09-2023, 03:31 AM | #7 |
Rep 48
It has done around 60K at the moment.
According to the iDrive the plugs are not due until next year, but have ordered in a set so will change them when they arrive. Air filters were changed in April. Can't find anyone that has Techron here where I am, but read that STP Ultra 5-in-1 is a good alternative, so have run through one bottle of this so far. Will get another bottle asap. |
07-09-2023, 06:59 AM | #8 |
Rep 592
Amazon sells Techron in various sizes and number of bottles..much easier. 16-20 oz per full tank of gas
07-10-2023, 01:39 PM | #9 | |
Rep 48
Not easy as you can imagine. |
07-10-2023, 01:41 PM | #10 |
Rep 592
A county without Amazon…how uncivilized! Almost any BRAND NAME fuel system cleaner should work
07-12-2023, 01:03 PM | #11 |
Rep 48
