02-25-2020, 11:22 PM | #1 |
Rep 102
f15 50i Brake pads
My car ran out of warranty and needs the brakes pads. Do I need to change all 4 brake pad sensors? They are like $25 each.
F30 335i xdrive
02-25-2020, 11:58 PM | #2 |
Rep 1,092
02-26-2020, 01:19 AM | #4 | ||
Rep 102
Cool thanks Quote:
How can you tell its been trigger? I still have about 2000 miles on rear and 9000 miles on the front? .
F30 335i xdrive
02-28-2020, 02:18 PM | #5 |
Rep 648
Drives: 2016 F15, 2015 F83
The sensor head resembles a pencil eraser. It has two wires embedded into it (they cannot be seen). As the brake pads wear, the sensor gets closer and closer to the rotor until it finally begins making contact. Once that happens, the rotor starts chewing off the head of the sensor (just like using an eraser) until one or both of the wires are severed. This is what triggers different levels of brake warnings on the iDrive. As long as the sensor has not been worn down and is still 100% intact, it is reusable. If it has been worn at all, if you don't know how to check them or if you are unsure, just order new ones. They are cheap enough.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
02-28-2020, 04:28 PM | #6 | |
Rep 102
F30 335i xdrive
