      03-05-2019, 04:41 PM   #1145
digirat
Drives: x5
Originally Posted by sweeper6 View Post
If you coded to start without clutch or by not pressing the brake pedal as you said you will need to press the start/stop button once then again and hold it to fire her up.
couldn't get it to fire up. on second press it turned off, or didn't do anything if i held it. i ended up uncoding that and it starts again now. phew.
      03-05-2019, 06:43 PM   #1146
DonJuan
DonJuan's Avatar
538
Drives: G82 M4, F15 X5, F30 328d, E30
Anyone successfully coded the Auto Unlock when turning off the car? Is it a multi coding option?
I coded it in but it doesn't work. I coded it successfully in my F30.
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black
MSport Pro and Prof.
      03-05-2019, 07:53 PM   #1147
taseal
Drives: '15 Corvette, '15 X5,
I got the veepak today. I will mess with it tomorrow...
That being said, I'm curious if Sport Auto Transmission and sport+ can be programmed into the S35i?
I kinda wanna try launch control... lol
      03-05-2019, 08:46 PM   #1148
Teufelshund
Teufelshund's Avatar
Drives: 2019 X6 xDrive35i
Not having any luck with this one myself (F15).
2011 328i (turned-in); 2012 Z4-28i (traded); 2013 X5-35d (traded); 2014 228i (traded); 2015 X5-50i (traded); 2017 X1-28i (traded); 2018 X1-28i (traded); 2018 330i(current); 2019 X6-35i (current)
      03-05-2019, 10:07 PM   #1149
MK2018
MK2018's Avatar
231
Drives: 2018 X5 xDrive35i
Originally Posted by taseal View Post
Originally Posted by ems328i View Post
I have recently gotten a 2014 x35i and I have ordered a vgate icar pro and bought the Bimmercode app, but before I try my first bit of coding I just wanted to check the general consensus on this forum: is Bimmerlink also necessary to clear error codes? I read conflicting advice but I only have Android devices, and I'm not going to buy an iphone just to use Bimmerlink!
You've heard conflicting stuff cuz it depends. Most error codes will reset by just shutting the car down for awhile. Some may not which require to be cleared. BimmerLink isn't the only option just the easiest. But as you said since you don't have apple products then not sure if the question cuz you can't download it anyway lol. Use esys or ISTA.
OK, I came to this thread to ask about this... I read in another thread you need bimmerlink to clear errors, and when looked on the play store (android) no such app is there...
so this is an apple only app? My kids have my old ipads, which I guess I could use... or borrow a phone from my parents I guess, but it's either that or esys?
Guess I'll see if I can get bimmerlink on the kid's ipads... they are like 1st or 2nd gen... I don't even know if it'll work lol
The app will work. It's free if you buy BimmerCode so just do it. Lol
Mav, are you saying bimmerlink is free if you buy BimmerCode?
Ya.
Weird. Mine still shows that it's 36.99(Canadian)
Hmm. Ya I got it through the BimmerCode app and it was free.
Lucky. Maybe I will email them and see what they say
Let me know what they say, I'm in Canada too
Current
2018 F15 M sport x35i
Past
2017 GMC Sierra Denali
2017 GMC Yukon Denali
2016 GMC Yukon SLT
2015 GMC Sierra All Terrain
      03-05-2019, 10:08 PM   #1150
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Ya.
That's a no go on free app. Developer emailed me back and said it isn't free.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      03-06-2019, 09:40 AM   #1151
ems328i
Drives: '14 35i (F15) '14 M135i (F21)
I am trying to enable Driving Mode Memory in Bimmercode, and it is now set to active, but when I re-start the car it still defaults to normal, rather than the last mode I was using. Do I need to be in Expert mode for this?
      03-06-2019, 09:44 PM   #1152
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Memory does not work, in my experience. You can switch default mode though.
Strike that, it works on F15, not on G-series.
      03-07-2019, 02:29 AM   #1153
SchweiZ4
SchweiZ4's Avatar
France
52
Drives: F15 X5 M50d
I have coded that last year and you can also find it in this thread somewhere.
It's just that it needs to be coded at 2 different places. If you do only one of them, it doesn't work.
I have written down something like this:
- BDC_01 > Driving mode on start up
- ICM > Driving mode on start up
Let us know if it does the trick
      03-07-2019, 07:14 AM   #1154
Teufelshund
Bumping this one.
I'd really dig this function if it worked. Opening the driver's door on my JK Sahara pops all five locks.
I'd settle for that too if anyone knows if/how it's possible.
DonJuan537.50
      03-07-2019, 07:18 AM   #1155
ems328i
Ok so I had indeed only coded in BDC (first time coding ), I have now set it to Active in ICM as well, but unfortunately no dice.
I notice in ICM there is also an option for the Default Driving Mode which cannot be turned off - does this override the Driving Mode Memory? I was hoping that if I strted a journey in Sport/Eco Pro, then on starting the car again for the return journey it would remember my previous setting....
      03-07-2019, 08:09 AM   #1156
SchweiZ4
SchweiZ4's Avatar
France
52
Drives: F15 X5 M50d
If I remember correctly, there are 2 things possible:
1) Remember the last driving mode you were in before turning off
2) Select the default driving mode of the car
I have only done the 2) using the same process described here:
https://f15.bimmerpost.com/forums/sh...3&postcount=20
For the 1), it should be at the same place.
Also the link of the thread itself talking about it:https://f15.bimmerpost.com/forums/sh....php?t=1482187
      03-07-2019, 08:17 AM   #1157
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
It should work. I have mine set to be in sport by default every time I start. Remembering what it was when shut off is the other option. Does the same thing for the A/C.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      03-07-2019, 08:41 AM   #1158
ems328i
Thanks for taking the time with this. From what I have tried (active in BDC and ICM), it seems that I can only choose a default setting which the car remembers, and not the last selection I made. There is no option in ICM to leave Default driving mode unassigned, which there is in BDC, and I think this is the issue. I will contact the developer and see if this is the case...
      03-07-2019, 07:43 PM   #1159
Teufelshund
Another one that doesn't seem to take is parking lights angel eyes @100%. Mine are considerably brighter with the switch off. Just took these in this order:
#1 = Off
#2 = Park Lights
#3 = On (low beams)
      03-08-2019, 02:20 PM   #1160
fattone18
Drives: BMW X5
Just got my 2018 X5 back from the dealer and they erased some of the coding I did last summer. I went to re-code and don't see the one press mirror fold option anymore on the updated Bimmercode app. How are you coding this on the new app?
      03-09-2019, 02:08 AM   #1161
Almaretto
Almaretto's Avatar
2374
#1 = Off
#2 = Park Lights
#3 = On (low beams)
If you have adaptive headlamps, then coding is in light module (TMS or FLE).
      03-09-2019, 06:04 AM   #1162
brevets10000
Drives: F15 2015
It absolutely works - have mine coded via bimmercode
      03-09-2019, 06:13 AM   #1163
Almaretto
Almaretto's Avatar
2374
I guess you missed my second statement?
      03-10-2019, 07:46 AM   #1164
eric_s
Drives: X5
If I remember correctly for IOS user gotta pay for Bimmerlink, for android its all in the bimmercode app.
      03-10-2019, 08:52 AM   #1165
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Yeah I reached out to the developer and he confirmed it was a paid app.
      03-12-2019, 08:16 AM   #1166
taseal
so I tried doing the hard braking to flash brake lights instead of the other one (I can't remember now. enlarge area or something?).
I got it to work and got the lights to flash... BUT.... when they flash, all my exterior lights cycle (headlights and all) and I get an error about the lights and to take it in for service.
any ideas on how to fix this?
