06-20-2020, 02:10 PM | #1 |
Rep 84
Eisenmann Race Install Question
For those that installed the exhaust themselves were there indents in the factory pipes you used for cut location or did you just measure and hope? Also, since I won't have valves anymore can I disconnect the wires and tuck them away or do I need to leave the valves attached? Not sure if I can just code them out. I have my car up on the lift and sawzall ready but did not see any indents for where to cut.
Any help would be much appreciated!
2016 X6M - Minera Whitel Metallic | Akrapovic Exhuast - Dinan Intake - Dinan S2
06-20-2020, 03:19 PM | #2 | |
Rep 11
I just measured and hoped! Lol. I held up the Eisenmann system under the stock exhaust (that was still on the car) and marked the cut locations. Ended up using an exhaust pipe adapter which gives it some play. Turned out pretty good! I think that’s all an exhaust shop would do anyway.
For the valves, just disconnect the wires and you’re good to go. I just wrapped them in electrical tape, and tucked and taped them behind the bumper to protect from any debris or water. You’re gonna love it! Quote:
06-21-2020, 01:46 PM | #3 | |
Rep 84
You wouldn't happen to be the same Mike from Obsessed Garage, would you? If so I'm a fan!
