07-24-2022, 07:44 PM | #1 |
Rep 25
Unlocking doors when shut off
So I’ve been trying to figure out why I can’t get the doors to unlock when the vehicle is shut off. I’ve coded with BimmerCode to have this feature active and in I drive it is set to lock in drive. For sone reason I can’t get the doors to unlock unfortunately. Is there a step I’m missing or doing wrong?
07-25-2022, 06:17 PM | #2 |
Rep 7,525
Now that you’ve coded unlock on shut down/engine off…does it only take ONE pull of the door handle to open the door. If this is the case…is there any reason for the door pin to rise since it will only take ONE pull of the door handle to open the door?
Report back what you find out. If the above scenario plays out…then there’s still a safety parameter built into the central locking system where if something unseemly is occurring or waiting to occur outside the vehicle…when the engine is shut down, passengers are STILL safe inside the locked door UNTIL they actually pull ONCE on the interior door handle to exit the vehicle. If coding UNLOCK raised the door’s lock pin first…it would still take ONE pull of the interior handle to open the door….but the door could also be opened from outside the vehicle, too. If coding doesn’t raise the door’s lock pin, but it still only take ONE pull of the interior door handle…passengers remain safe inside until they actually pull the handle, and again, it doesn’t matter if the door pin rises or not…it still only takes ONE pull of the interior door handle to open the door.
07-25-2022, 07:19 PM | #3 | |
Rep 25
