07-10-2018, 10:03 AM | #1 |
Rep 2,388
Can someone experienced with coding/flashing give me an advise?
So I was coding Kombi ecu (instrument cluster panel) via obd Carly app. Car was running, phone was on charge cable, but cable failed (it wasn't charging) and my phone died during coding.
I had previous Kombi ecu backups and tried to restore earlier version, but Carly either says wasn't able to restore or it just stops in the middle and nothing happens. Basically now I have fuel and temp gauges not working and got some errors too. Car is driveable, but now I'm thinking how to fix it. One person suggested following: "You'll either most likely have to inject a CAF or do a cdeploy as a flash target instead of just coding. This all is assuming that the module is still responding on the bus and didn't get fully botched". So i need esys/ISTA for that (Carly won't do anything like that lol).The problem is I'm not at all experienced with coding via esys/ISTA and in addition I don't have battery charger to keep me safe during remote session. I also don't have laptop, I only have surface tablet which has no slot for enet cable. (I have proper laptop back in NY, but not here in AZ). I was thinking: 1. Buy battery charger, buy some cheap laptop and enet and do a remote session. 2. Find some local coder, but the one I found locally suggested that I go to dealer to recode it back to stock, so that missing coding packets get replaced. He said it's very expensive 3. Find some more experienced coder who can fix it without going to dealer lol. Not sure what to do at this point. My warranty is up, so going to a dealer that will see my tampering attempts is probably a bad idea. They can easily hit me with a $3k bill for complete reflash (and I'll loose my tune as well). So I'm trying to find easier solution if at all possible. I know I can just replace 6wa or even 6wb LED cluster panel worst case scenario (if Kombi ecu module is fried) and it still be cheaper than going for a reflash to a dealer, plus I'll get a LED panel lol. Any thoughts? |
07-10-2018, 10:51 AM | #2 |
Rep 120
Sorry to hear about that man. To save some money in regards to a laptop, there are USB to Ethernet adapters that exist. I use one with my wife’s Surface Pro because it’s the only Windows based PC we have and it works fine. The one thing I’m not sure about is if Esys runs on a regular Surface (non-Pro).
DuSh2113.50 |
07-10-2018, 12:45 PM | #4 | |
Rep 2,388
Went to see couple local "coders" but to no avail. One was a joker that only does simple stuff like fodling mirrors etc. via Bimmercode Another one said he will need to re-flash whole car (all modules and DME including). He had no idea what injecting CAF is or how to do a cdeploy. Heavens to Betsy - these guys advertise and ask $250 just to update new version without even looking into my issue. So I think remote coding session with a real coder is my best bet - to see if module is revive-able. If not I'll venture into swapping my instrument panel 6wa to same or possibly full LED 6wb. |
07-10-2018, 12:48 PM | #5 |
Rep 2,388
Wow - that's great news! In that case I'll inquire with my dealer - that would be awesome if they can do that! The local "coder" told me they can only update whole car and that will take 5-6 hours and will cost close to $1k. I'm going to check with dealer. Thank you!
07-10-2018, 01:17 PM | #7 | |
Rep 2,388
So yeah, I have a talent to create problems for me out of nowhere |
07-10-2018, 01:24 PM | #9 | |
Rep 2,388
I can try to take battery terminal off for 20min, but I doubt that would miraculously fix it. At this point esys or ISTA is a must I think. |
07-10-2018, 01:39 PM | #10 | |
Rep 475
DuSh2113.50 |
07-10-2018, 01:56 PM | #11 |
479
Rep 317
When i was programming my LED headlights for VLD and Anti-dazzle I saved all of my CAFD File, I have a copy of my KOMBI CAFD file available, but mine been a 35d and yours is a 50i will have incompatibility issue.
Perhaps if someone has a copy of 50i KOMBI CAFD and if you can get a copy of your KOMBI file, get the NCID/CAFD viewer "here" tool to view what you're missing and using ESYS to rebuild the your file. That would be the cheapest or "last resort" (if no one would assist) solution but its a gamble tho. |
DuSh2113.50 |
07-10-2018, 02:00 PM | #12 | |
Rep 2,388
07-10-2018, 03:12 PM | #13 | |
Rep 648
Drives: 2016 F15, 2015 F83
Hopefully Almaretto or shawnsheridan will chime in shortly with some help.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
DuSh2113.50 |
07-10-2018, 11:04 PM | #15 | |
Rep 8,364
DuSh2113.50 |
07-20-2018, 04:41 PM | #16 |
Rep 2,388
Update: just finished remote session with a very cool and knowledgeable guy Steve Ma http://www.codemybimmer.ca
He is a sponsor of our forum anyway, so many of you probably know him. All I needed was a enet cable and a laptop. He installed software remotely and recoded my car. My instrument Kombi panel bricked by a Carly adapter is now working as new and he also fixed my EGS module error (separate issue with transmission and Sport+ mode). Took about 30min total, including downloading and installation of esys etc. Very professional and I'll be using him in the future for all my coding needs. I'm just so glad I didn't have to buy another 6WA/6WB panel - he saved my sorry arse basically. |
Russmov1328.00 |
07-20-2018, 07:40 PM | #17 | |
Rep 8,364
DuSh2113.50 |
07-20-2018, 07:50 PM | #18 |
Rep 2,388
Yeah, he said he had 6 clients with Carly bricking various modules. I didn't ask about Bimmercode, but I'm sure it's similar. I'm glad that at least in F series modules seem to not really "brick" and are recoverable - unlike E series (infamous frm module as one example).
07-20-2018, 08:18 PM | #19 | |
Rep 8,364
Definitely good to fix issue before going to dealership because also seen people get voided warranties. |
DuSh2113.50 |
