07-14-2018, 02:52 PM | #23 |
Rep 467
OK, just talked to the Service Manager and our X5 should be ready by end of day. They were able to reproduce the "hiccup" some of us are experience under heavy acceleration. They replaced all 6 coils and plugs as well as the transfer case VTG. Hope this fixes it. Thank goodness for the CPO warranty :-)
07-15-2018, 05:03 PM | #24 | |
Rep 467
07-15-2018, 05:19 PM | #25 |
Rep 2,388
Interesting. This may be a completely separate issue. Not sure what to think. I guess I will try to unplug it and drive without it - to check. I know the plug is accessible from below, but plastic cover is in the way. On positive note - that will make car RWD maybe I should leave it like that? More power on dyno too
07-15-2018, 05:42 PM | #26 |
126
Rep 303
i have got that shuddering after BPC , so i think that my transfer case is ok.Bob have send me 2nd tuned file with less power (5-10% less ) and what i have noticed after the flash was that first there was a drivetrain malfunction popped on and than after car sleeps and turned on there was no message .I jump on the highway and drive around. Now that shuddering is not that mush as it was and its on higher speed.120Mph , 4.5Rpm... the other thing i have notice is that the gears are shifting more smoother ... With the 1st tune definitely car is more aggressive but when shifting gears had that little punch... now is better but drivetrain malfunction drive moderately ... lights on and than back off when i step on the gas .So i assume is the tune but i think i will have to go with changing the spark plugs too ...
DuSh2112.50 |
07-15-2018, 07:45 PM | #27 | |
Rep 239
DuSh2112.50 |
07-15-2018, 07:50 PM | #28 | |
Rep 2,388
I still want to try to unplug it - if it works - I'll drive unplugged, except in winter season. I'm assuming handling should increase in RWD mode, MPG may go up a bit and dyno pulls should be a bit higher |
perry8912101.00 |
07-16-2018, 09:42 AM | #29 | |
Rep 139
07-16-2018, 11:25 AM | #31 |
Rep 2,388
So apparently we can add another issue that may be causing similar symptoms: HPFP failure. It's very rear (it's nothing like it was on N54), but I saw 1 post on facebook that ended with hpfp replacement under warranty. Similar symptoms - car is shuddering during acceleration. The only difference is that with hpfp you do get a bunch of specific codes.
I'm just saying we may be talking about several different issues that have very similar symptoms and to really distinguish between them - you really need to have a good bmw scanner that can read codes and/or you need to try some things to logically eliminate wrong choices. Like unplugging TC to check if it's the cause or not. Of course for those who are not tuned and under warranty - there is a simple choice - go to dealer. For others - we need to share info - maybe we'll sort it out eventually. |
07-16-2018, 11:34 AM | #32 | |
126
Rep 303
https://www.youtube.com/watch?v=weK8...ature=youtu.be |
07-16-2018, 11:52 AM | #33 |
126
Rep 303
Friday after i get back home from work i have let the car work with ac on so it can get colder inside since the flash takes about 30 minutes to install itself and i have to be inside No sound .. car was so quiet. So i ran the power cables from my wife's car get in my and ...boom ... BPC software was out of date ... i get home and download the newer version . in the morning (Saturday ) i install the new software and installed the 2nd tune ...i drove the car etc... i have notice this noise this morning . Yesterday i drove the car for about 4 miles,but i dont know if it was there or not .. Cant hear it inside
07-16-2018, 12:09 PM | #35 |
Rep 467
07-16-2018, 12:19 PM | #36 | |
126
Rep 303
DuSh2112.50 |
07-16-2018, 02:33 PM | #37 | |
126
Rep 303
check this out https://www.youtube.com/watch?v=0MY5lSSHf4g cant be the rod... mine is not even close to that |
DuSh2112.50 |
07-16-2018, 03:22 PM | #38 |
126
Rep 303
That is what i am praying for ... next step is ... . Car is only 15k miles and i have warrant but after put the car back to stock and that sill there BMW NA may find that there was a DME flash and i am screwed ... i have found that it might be just rod bearing that might be the problem ... dont know
DuSh2112.50 |
07-16-2018, 04:04 PM | #39 |
126
Rep 303
last time i have checked the oil was couple days ago. If not mistaken saturday nigh .. it was at the max.Not sure when i have changed the oil but i think was about the end of February beginning of March . i always check my oil every 1-2 weeks. The mechanic i use for oil change is working on German cars only and he is a very knowledgeable .. He is using Motul 5W40 . Not sure thou but is Motul
DuSh2112.50 |
07-16-2018, 04:56 PM | #40 |
Rep 1,434
I hope it’s nothing serious but I’m with Dush on this one it don’t sound to good.
2022 x5 m50i - Dravit grey
DuSh2112.50 |
07-16-2018, 05:44 PM | #41 | |
Rep 299
DuSh2112.50 |
07-16-2018, 06:02 PM | #42 |
126
Rep 303
i have installed my stock data and that sound is still there ... no codes no engine lights ....not sure if i want to drive around and see if this will go away after adaptation...i will wait 30 minutes and car should be in sleep mode . i will go out and drive a mile and i can only hope that will be an adaptation .honestly highly doubt it
07-16-2018, 06:13 PM | #43 |
126
Rep 303
i have send that video to my mechanic and he told me that this is no good.. now that been said i can now only hope that bmw will not gonna see that flashed ..now i wonder what are the potential risk .. what they will look for and if they find it
