07-16-2018, 12:46 PM | #1 |
252
Rep 387
Prepping for Dyno?
Dinan stage one goes in today. Dinan air intake already installed. Anything I should do to prepare for a Dyno? Also, what questions should I be asking? I do know the dude I talked to said he has a Mustang Dyno, should I be looking for a _________ Dyno instead?
07-16-2018, 12:52 PM | #2 |
Rep 2,388
Would be interesting to see your dyno. You don't have to do anything afaik. Just don't forget to turn off A/C. Mustang dyno might show a bit lower output - but it's up to you. I personally would go for Dynojet, not because it shows a bit more, but only because it seems everyone is posting their Dynojet numbers, even tuners have mainly Dynojet values on their websites. So just to be able to compare easily your output and others. But it's up to you of course.
07-16-2018, 05:00 PM | #3 | |
252
Rep 387
DuSh2113.50 |
07-16-2018, 05:29 PM | #4 | |
Rep 1,434
Mass?
2022 x5 m50i - Dravit grey
DuSh2113.50 |
07-17-2018, 10:09 AM | #5 |
252
Rep 387
I talked to Dynotech yesterday and they have the Mustang Dyno. I'm going to shop around for a Dynojet location...
07-17-2018, 11:23 AM | #7 |
252
Rep 387
07-17-2018, 09:55 PM | #8 |
Rep 231
Personally, I would go to a mustang dyno over all others. Typically it's a more accurate depiction of a vehicle on a road. Dynojets give higher numbers which is why you see the tuners advertise those, bigger number equals more sales.
And you can't really compare dyno results to others that have been on a different dynos. Each dyno will be different. If you check around you'll see that some have good reps and some are heartbreakers. Most dyno ops will give you their drivetrain loss estimate. From there, you can calculate the delta from stock. If you plan to dyno a lot, get a stock run done first, then you'll always have something to compare too. |
07-18-2018, 07:24 AM | #9 | |
Rep 648
Drives: 2016 F15, 2015 F83
Without a baseline, your after-tune dyno numbers are completely useless. All your going to get are bragging rights, so you might as well find a Dynojet and get the higher numbers. If you happen to use Brian at dynotech in Seekonk, he has my 2016 50i files, so at least there is a baseline 50i to compare it to and you'll be using the same dyno I did. Be prepared for lower numbers on his dyno. It generally reads about 14% lower than a Dynojet. Some things to remember for the dyno run: PDC off Sport + Transmission in Sport Shift mode DSC off (hold the button) Accelerate and manually shift into 5th gear
2016 F15 X5 50i M-Sport
2015 F83 M4 Last edited by Rotzy; 07-19-2018 at 07:56 AM.. Reason: Fixed typo |
07-19-2018, 05:49 AM | #10 | |
252
Rep 387
perry8912101.00 |
07-19-2018, 12:16 PM | #11 |
Rep 231
Also, make sure the operator is aware of the step-down button on the accelerator. Many a dyno runs are ruined by this, he can get a feel for it with the engine off.
07-20-2018, 12:51 PM | #12 |
Rep 648
If you have an M Sport and use Sport+, Sport Shift and manually select the gear, the transmission will not kick down. That is why I suggested it above.
2015 F83 M4 |
joyride43.00 |
07-20-2018, 06:23 PM | #13 | |
Rep 231
