      10-16-2020, 11:22 PM   #1
bmwchue
Drives: 2013 bmw 328i
coding soft touch turn signals
Hi I'm trying to code the soft touch blinker on bimmercode for my 15 x5 but I cannot find #3 in expert mode . Ive coded everything else that I wanted except this one.Any help appreciated.The cheat sheet said
1.BDC_BODY
2.3068
3.BLINKZYKLEN_ANZAHL_TIPP
      10-17-2020, 07:21 AM   #2
Florida-X3
Drives: '24 X3 x30i / '12 Infiniti M37
The 5 blink code used to be available and I had it coded. Then after a trip to the dealer it stopped working. I tried to code it again but the option has been removed. To bad, I think 3 is not enough, 5 was perfect.
bmwchue242.00
      10-17-2020, 08:57 AM   #3
DenBel
232
Drives: F15 50i, F13 650i
1.BDC_BODY
2.3068
Check if this option is there:
PIA_DEFAULT_TIPPBLINKEN
bmwchue242.00
      10-17-2020, 10:06 AM   #4
bmwchue
yep I wanted 5 too
      10-17-2020, 10:59 AM   #5
jero1213
Drives: F15 MSport
I was able to code 5 blinks a while ago, but there was an update recently. wonder why programmer would take that off.. I really do like 5 blinks much better than 3
Current:
2015 F15 X5 35i MSport - BSM/Black - RC RS - BMS CP
Past:
2002 E53 X5 3.0i Sports Pkg - Titanium Silver/Black
      10-17-2020, 11:09 AM   #6
scotty339
Drives: 2015 BMW X5 x35i M-Sport
Any software updates will erase any coding previously done. You will have to re code to get 5 blinks again.
      10-17-2020, 11:12 AM   #7
CatalinP
Drives: BMW X5 F15 2014 3.0xd
It is not possible to re-code after the latest ilevel update from the dealer.
      10-17-2020, 11:34 AM   #8
DenBel
232
Possible, I did it, but with esys, never tried bimmercode
      10-17-2020, 11:36 AM   #9
jero1213
Drives: F15 MSport
Oh wow, really?
I might skip the update then, I just checked and there's an update available
Don't think i'm going to do it !
Current:
Past:
      10-17-2020, 08:54 PM   #10
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
Are the codes same names in esys? If yes, shouldn't we be able to read/edit them with bummer code ?
      10-17-2020, 08:59 PM   #11
jbfq2014@gmail.com
Drives: X5 F15
Lost my 5 blinkers after a dealer visit, have bimmercode but unable to find them
      10-17-2020, 09:39 PM   #12
DenBel
232
Never tried bimmercode, as do all my coding with esys. But bimmercode users Use the same function names as I see in esys. That makes me think that they are the same. Just check the cheat sheet from the official coding thread and compare the functions with the ones you use with bimmercode
      10-17-2020, 09:41 PM   #13
DenBel
232
Please check with bimmercode if you can find this one :
Saw several people asking for the blinker coding after update. That’s what I coded with esys for 5 blinkers
      10-17-2020, 10:16 PM   #14
jbfq2014@gmail.com
Drives: X5 F15
Will do thanks
      10-18-2020, 10:23 AM   #15
bmwchue
found it under 3069 but when I change the value and coded it it didn't work. should I turn off the car then turn it back on?
      10-18-2020, 10:37 AM   #16
DenBel
232
I did my coding with esys and engine running, there suppose to be three values to choose from, not sure how bimmercode works.
      10-19-2020, 06:26 PM   #17
daytonaviolet
OEM CSL Whore
Philippines
1250
Been trying to get 5 blinks for two years and so far no luck.
      10-19-2020, 07:37 PM   #18
turboawd
1636
Drives: 2015 X5 35i
Weird. I was wondering if I could make it less like 2 flashes, which seems enough for switching lanes.
      10-19-2020, 09:47 PM   #19
pits200
2, you must change lanes at a 90 degree angle.
      10-19-2020, 10:43 PM   #20
turboawd
1636
Drives: 2015 X5 35i
No, but 5 flashes will get me across 3 lanes minimum. 🙂
      10-21-2020, 12:08 PM   #21
Qsilver7
Qsilver7's Avatar
Originally Posted by Qsilver7 View Post
I was just able to code my 2014 X5 to five blinks using Bimmercode expert mode . I was coding the BDC module...go to: 3068 > BLINKZYKLEN_ANZAHL_TIPP ...then change CUSTOM VALUE to 0x04
Back on 10/17/2020...I posted that I was able to change my 2014 f15 X5 to 5 blinks using the Bimmercode app.
The OP mentioned they couldn't find BLINKZYKLEN...did you try using the search feature in Bimmercode? In the IOS version...you can type "blinkzyklen" in the search box when you've gone into the EXPERT MODE and go to the 3068 selections.
      10-23-2020, 04:11 PM   #22
DenBel
232
Just checked it, you found it right, the value should be 02 for five blinkers
