      04-20-2016, 10:20 PM   #1
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
Brake Squeal
I just picked up the F85 last night and I noticed some break squeal, more of a low pitched squeal under moderate braking at slow speeds. Has anyone experienced, I did a search and didn't see any complaints. I did have serious brake squeal on my F10 M5 so was hoping it isn't an issue on the X5M. How many people bedded their brakes, and which process did you use?
2016 991.1 911 Carrera GTS
2016 F85 X5M - Carbon Black/Mugello Red
      04-20-2016, 10:25 PM   #2
Vassilis1971
Vassilis1971's Avatar
Drives: 2015 X5M
My one and only complaint with my beast. Brake sequel! 18K KMS and I've succumbed to the fact that it will never go away.
I'm offsetting it by just downshifting and enjoyed the wonder sounds of he engine revving down.
There are multiple threads on this.
      04-20-2016, 10:42 PM   #3
G80POWER
Drives: 2023 iX M60i
Known problem on these M SUVs because the brakes are so huge. My service advisor told me there is nothing they can do about it. Can believe BMW make a $100K+ vehicle and can't figure out the brakes to keep them from squealing! It is so embarrassing when I pull up to stop signs in my neighborhood
zjaiz180.00
      04-20-2016, 11:21 PM   #4
Coelho
Drives: X5M
same here...
      04-21-2016, 12:47 AM   #5
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
When it starts to squeal, slam on the brakes real hard and it goes away. All M cars squeal, unless you have CCB.
Otherwise, look into Carbotech 1521. I know they make them for the M5, I assume the calipers are the same.
      04-21-2016, 05:29 AM   #6
Ryngo
Drives: 2016 F85 X5///M, DG
I bet it's not embarrassing when you pull away from that stop sign!
      04-21-2016, 06:19 AM   #7
cmyx6go
cmyx6go's Avatar
15763
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Mine squeal big time too. My '13 only did this when the wheels were dirty with brake dust. I'm glad it's not just me. Is it the bigger calipers?
      04-21-2016, 06:57 AM   #8
UrbanExtant
Drives: F82 M4 Comp Pack
My husband calls our X5 M "the grey school bus", because that's what is sounds like coming to a stop with how badly the brakes squeal.
      04-21-2016, 07:00 AM   #9
PatrickC23
PatrickC23's Avatar
Ok, so I guess they never addressed the issue from the F10M brakes then. I will probably get it out this weekend and attempt to bed them although I dont think it will help. As long as its "normal" Im fine with it, just hate taking it in for these type of things since they never fix them. This thing is scary fast though I can tell, from a stop it feels faster than my F10 and I am breaking it in still. It just feels like it wants to go (if that makes any sense).
      04-21-2016, 07:15 AM   #10
UrbanExtant
I've tried bedding mine three to four times, doesn't help much. I've learned to just live with it. They squeal, people look, see the nice X5 M, then I move on.
It does feel like it just wants to go. It feels like you're constantly restraining a beast inside that's eager to get out and play!
      04-21-2016, 08:07 AM   #11
jcfay
jcfay's Avatar
Drives: 2016 BMW X5 M
Ditto. Bedded mine twice, no help (maybe it helped for like a day). No replacement pads out there that help? Nothing like driving a (relatively) high end car that sounds like it's got 3rd hand used brakes...
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers
2014 C63, Klassen M52Rs, Eurocharged tune - Gone
      04-21-2016, 08:17 AM   #12
cmyx6go
cmyx6go's Avatar
15763
It drives me crazy. Much more so now that the weather is nice so my windows are open. The sound makes my ears bleed. I've tried adjusting how I apply the brakes to lessen that nails on blackboard noise.
      04-21-2016, 08:33 PM   #13
PatrickC23
PatrickC23's Avatar
I may still attempt to bed the brakes - but do you need to wait until the brakes are used for 4-500 miles prior to that? Tire Racks site says certain brakes should not be stomped on for 500 miles. Are these Brembo?
      04-22-2016, 03:33 AM   #14
RaVe
RaVe's Avatar
Germany
80
Drives: X5M F85
Its really a big problem.
A friend of mine, the carriage is withdrawn, because they could not repair the brakes.
Now he gets a new car in a few month with the hope that the brakes no longer squeak.
My brakes squeak now also from time to time.
      04-22-2016, 05:37 AM   #15
Adris
Adris's Avatar
Lithuania
136
Drives: BMW F92 M8
mine does too, last year I went to Monaco, believe me, basically all exotic cars does too, I think mclaren p1 was the worst, it had very annoying high pitched noise when braking
      04-22-2016, 06:02 AM   #16
jcfay
jcfay's Avatar
I don't think I got to it after 500 miles, so can't say. I would wait a bit, that's for sure to let the pads and rotors wear in a bit.
      04-22-2016, 06:47 AM   #17
cmyx6go
cmyx6go's Avatar
15763
Not a peep out of my brakes this morning
      04-22-2016, 09:53 AM   #18
raym3cs
raym3cs's Avatar
Drives: San Marino M3CS
I had the same issue with my X6M F86. Went to two different dealerships before they finally gave me new rotors and pads. First dealership Took out the brake pads and clean them .did a test drive and told me there was no issue. A week later the brakes started squeaking again. And Then I decided to contact the dealership that I picked up my vehicle from. They had the vehicle for about three days. My service advisor calls me and tells me that they have no choice but to give me new rotors and new pads all around because the first time the issue was not corrected. i haven't had a squeak since
      04-22-2016, 10:19 AM   #19
PatrickC23
PatrickC23's Avatar
Which dealership in NJ did you end up at? Thing is mine is brand new, i noticed it Day 2 with 48 miles on it so I cant imagine the pads got dirty. Completed build 4/12 also so its not like it was sitting somewhere building up corrosion.
      04-22-2016, 11:28 AM   #20
WCH
WCH's Avatar
Drives: '20 M8C convertible
I have it a little. Comes and goes - worse when it is cold and wet.
It is however much less obvious than my F10 M5 with CCB. The CCB sounded horrible 80% of the time - But there was never any brake dust.
      04-22-2016, 12:33 PM   #21
Alpine300zhp
Drives: 24 M4 Comp RWD
I went through two sets of brakes on my m4 before the issues were ironed out. It may be defective brakes or it may be a problem that goes away after the brakes wear down a little and bed in properly.
~ 24 M4 Comp
~ Prior BMW's - Too many to list here (27)
      04-22-2016, 01:32 PM   #22
Coelho
Drives: X5M
I think only my driver's side front brake squeals. Not the others.
