09-21-2024, 03:42 PM | #1 |
Rep 276
2017 50i Build
Just getting back into my shop working on this again so I figured I should start a thread of my build.
Bodywork: I have f85 bumpers and side skirts, carbon front and rear diffusers and carbon sideskirt trims. Working on a custom rear spoiler (top), nothing goofy or anything just something with a little "aggressive" looks to it. The X5 is solid white now with the ivory interior, doing a full dip in a matte pearl white. Lighting: I disassembled the headlights and changed the halo and eyebrow to orange, I am able to change it all back to white by switching a white if I wanted, but the orange looks mean!! also used a custom orange led strip behind that clear piece where the blinker is, looks so much better, and de-chromed everything and painted a combo of gloss and matte black. Also upgraded the projector lenses, wasn't a direct fit they were just a hair to wide in diameter so I had to use a wet belt sander to shave them a little bit. Wheels: I have the 20" Ferrada FR2's, bronze with black lip, I had the have the hubs on the rears cut larger to fit on our side hubs, still need to order tires, wheels are staggered, 10's up front 11.5 in back. carbon bmw roundels I need to adhere to the center caps. Brakes: I have Tonys brake kit in yellow with brembo lettering, and stainless braided lines, not installed yet. Engine: I have s63 manifolds, intercoolers, and new oem turbos (all cerakoted with piston coat) with ported inlets, will be using custom intake boots that go from the turbo inlet to a Dinan intake. instead of the stock cwa50 intercooler pump I will be running dual cwa100's and dual heat exchangers with a 1.5 gallon reservoir I made to fit inside the driver fender. I need to do the upper oil pan gasket at some point too and when I do that I place on putting new rod bearings in. Exhaust: 3" downpipes cerakote piston coated with titanium heat wrap, 200cell cats after the downpipes for smell purposes only, resonators and custom x pipe going back to an f85 muffler with carbon tips and an aftermarket valve controller. Tuning: I am really not sure yet, some people have had issues throwing the cross bank headers onto N63's due to each of the O2 sensors reading both banks, I really didn't think it could matter a whole lot but apparently its a thing.. it got me wondering if I could just get F85 DME's and program my vin into them, then just get a BM3 stage 1 tune? There's a tuning shop a few miles away I might check with them, and I've reached out to someone that people were recommending too but they're in Turkey so we'll see what they say.. Last edited by Djhumvee; 09-21-2024 at 03:58 PM.. |
09-21-2024, 03:48 PM | #2 |
Rep 276
I know people are going to say "should have just gotten an f85", well you're probably right lol. I didn't intend to go all out like this, when I bought this in 2021 I paid 34k for it, and f85's were 50k and up so it was just out of my budget.. I found the f85 body parts for next to nothing, then later on a saw a pair of new f85 oem turbos on eBay for 1500 so I figured.. gee ill just get those and the S63 manifolds which are cheap on eBay too and I'll have a nice little turbo upgrade, lol nope not so easy..
09-21-2024, 07:37 PM | #3 |
Rep 276
Wrapped the Downpipes, and did extra wrapping near where the trans lines are, these have also been cerakoted with piston coat. Forgot to take a pic of the wrapped headers but you can still sort of see them in the pics. Also not that impressed with the Arm Downpipes, they want you to use a 3" band clamp that has a tab welded on but there's not way on earth it would have worked, also the flex joint was rubbing on the motor lift bolts so I took it off for the clearance.. I feel like these downpipes should have been made another inch longer coming off the back of the turbo.
09-21-2024, 07:48 PM | #4 | |
Rep 1,206
Those turbos, do they have the updated compressor housings or is that stock for an F10? BTW, on the intake boot, Once the alternator is in + wiring, there is not as much room in there as it looks and unless those housing change things up. The sides are not symmetrical. For the IC, who not just got the interchiller route like SR or Tony did? Granted allot more $$. When you do the rod bearings, any chance to doco how far you had to drop the subframe and/or what you had to ublot/clip to do it. *EDIT* is that a fluro green sticker in the turbo?? |
09-21-2024, 09:55 PM | #5 | |
Rep 276
The turbos idk about an updated compressor housing, it's been a while but I believe they were matching part numbers for the f85. Yeah I do think it is going to be pretty tight making an intake, I guess I'll cross that bridge when I get to it lol. So the IC I was almost thinking of the interchiller route but one of those guys that did it I think had issues at first and blew up his AC or something, it might have been Panda aka Autolust? So I just figured I'd play it safe and just upgrade the pumps and heat exchangers. Yeah I can definitely do a write up on the rod bearings, I think the subframe gets completely dropped doesn't it? |
09-22-2024, 12:56 AM | #6 |
Rep 1,206
Yeah that green sticker thing. Is it worth taking the compressor off and trying to clean it out? It looks like the other side still has the half torn of paper left.
Just looked at the P/N those are definitely from an m5 + it looks like compressor bore got bored out, so I doubt the stock m5 or the f85 boots will fit as they use a single inner o-ring. The stock 50i boots may as they have that orange o-ring. Also on the lack of symmetry, here. The pie cuts are identical but see how little clearance there is on bank 5-8 to that 2 connector thing. On the clearance issue, on the stock f85, the issue is not length (to the back of the IC/airbox) but the height of the inlets. They sit too low and back straight cooling lines and the Alternator. more pics on how my 2.5" bend it butting up against cooling and + terminal https://f15.bimmerpost.com/forums/sh...3#post30749893 Cheers, blindly hoping that is not the case. Last edited by Chilled; 09-22-2024 at 01:33 AM.. |
09-22-2024, 02:27 PM | #7 | |
Rep 276
09-22-2024, 07:17 PM | #9 | |
Rep 1,206
The post 2014 i think are, the pre are slightly different. That's what caught my eye, the housing casting, the actuator mount and the compressor inlet (the outer shape) are different. Last edited by Chilled; 09-22-2024 at 07:27 PM.. |
09-23-2024, 12:21 AM | #10 |
Rep 1,206
Miss read this first, not waste gate. Inside the compressor housing.
09-23-2024, 12:21 AM | #11 |
Rep 276
Shoot you're right, I was fitting everything after I removed the actuators damnit lol. Im working building the exhaust right now, I got from the downpipes to where they meet in the center tacked up, once I finish the exhaust ill check out that actuator and maybe oblong the holes a bit for the actuator or something..
09-23-2024, 08:10 PM | #13 |
Rep 2,771
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
that's a pretty awesome build dude!!
Djhumvee101.00 |
09-24-2024, 12:04 PM | #14 |
Rep 898
Drives: BMW X5 XDrive35i
This is sweet dude, props to you for uniqueness. Got me wanting to mod my headlights lol.
2017 X5 XDrive35i X-Line | Sophisto Grey | MHD Full Flexfuel Tuned | Mosselman Turbo | Sutphin Tuning TCU | Nostrum Stage 2 HPFP | Walbro 450 | S63 EU5 Injectors | ER Charge Pipe | FTP F10 Inlet | Midnight Motorsports Intake | ApexBuilt Catted DP | VRSF FMIC | Zeitronix Flexfuel Kit | KateCool Oil Cooler | Variant Wheels | Conti DWS06+ | Custom 3.5" Catback | M18 Racing Oil Breather Cap | Turner Catch Can |
Djhumvee101.00 |
09-24-2024, 10:46 PM | #17 |
Rep 276
I elongated the mounting holes for the right waste gate and can just barely get the silicon hose on now over the inlet of the turbo. These silicon reducing 90's just barely clear the alternator, I could actually trim the turbo side if I had to and that would sneak them away from the alternator even more. I layed the intake in place over the mock up and it looks like it'll line up, ill obviously have to trim the carbon 45's to the right length but you get the idea..
09-24-2024, 10:54 PM | #18 |
Rep 276
Actually I see what Chilled was talking about with the + connection on the alternator. The silicon boot pushes up against it. I can trim a half inch to a full inch even off the turbo side of the silicone so that would obviously give the clearance I need.. Since it's silicone and not plastic I wonder what the long term effect would be if I left it touching, I can't imagine it would wear through the silicone?
09-25-2024, 02:56 AM | #19 | |
Rep 1,206
Looks good, I wish mine was that simple. No idea on the life of the bends if they are touching the terminals. I have no choice, the inserts move the turning point so far out its ridiculous. If they wear thought, I see replacing them as a cheap/quick service item.
How is the clearance on the oil funnel? The question I would have is it a good idea to be pushing on it considering that it is plastic and if that breaks ..... Quote:
Did you end up cleaning these out? Last edited by Chilled; 09-25-2024 at 03:10 AM.. |
sukhk5272435.00 |
09-25-2024, 12:22 PM | #20 | |
Rep 276
Ohh is that the green sticker you were talking about previously?? That's actually not a sticker its like printed onto the core. So with the tuning I would think if they could go from non crossflow to crossflow they could also go crossflow to non. There is a guy in the M8 forum who used/is using Motiv to go from cross bank to custom non crosssbank manifolds. |
