07-16-2015, 01:08 PM | #1 |
Rep 3,834
F85/F86 Coding
I just coded my F85 with the following features:
All of those worked. I came from an F80, so I used the same reference sheet attached (just search the key words in FDL edit mode, the numbers sometimes don't match up inside the same module). On Euro LED headlights, you only need to code FEM and KAFAS2 (don't code all modules like the other F15 guys are doing). Oh, rear fog lights don't work like the F80 so don't even attempt. I removed the switch, it's not the same as the F30. Looking at the F80 parameter, you'll need to see the second attachment of how to change FA (VO) for dazzle headlights. It's easier than it looks. The Euro LED light coding is worth it. I'm so happy with how the headlight works now. For those who love coding, don't forget to pay it forward. Information on my thread below on how to donate. http://f80.bimmerpost.com/forums/sho....php?t=1125375 Thanks shawnsheridan again for your help. Hit Shawn up for the software and contact me if you have questions. After you installed eSys, don't forget to hit "Abort" when you launch eSys Premium the first time then change the body to F85 or F86. Otherwise you have to wait 3 days to change it agian.
07-16-2015, 02:38 PM | #2 |
525
Rep 1,440
Question, I coded my F86 as well and the Brake Force Flashing feature works as does the tails being on with the DRL's but whenever the Brake Force Flash feature is actually activated by hard braking, it generates an error msg that is easily dismissed by pressing ok in idrive. Does anyone else experience this?
Thx in advance
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
07-16-2015, 02:52 PM | #3 | |
Rep 3,834
07-17-2015, 12:28 AM | #4 |
Rep 18,780
Coding tail DRL is perfectly fine. The rear fog indeed causing error from what I have been hearing.
07-17-2015, 07:01 AM | #5 |
Rep 518
Drives: 2024 XM Label
+1 - I coded DRL back in April and have had no issues over 4000+ miles. I don't have rear fog coded tho (as the OP says, our vehicles don't support them)
07-17-2015, 08:02 AM | #6 |
Rep 3,834
Did you code brake force flashing too? If so, have you done hard braking to test = ABS engaged? I believe the error comes with hard brake flashing and DRL are on the same time.
07-17-2015, 08:31 AM | #7 |
525
Rep 1,440
This is true. This is what I have been experiencing. Its not the DRL that causes the issue but the Brake Force Flashing. I like the feature enough to keep it and simply dismiss the error msg by pressing ok in idrive if and when it ever shows up.
07-17-2015, 12:07 PM | #8 | |
Rep 18,780
Because it uses the rear fog lamp. Also, I believe you don't even need to code this because by default it is on already.
07-17-2015, 12:16 PM | #9 |
Rep 3,834
Brake Force in the US doesn't flash, it just gets brighter and fills the entire taillight. It's probably not DOT approved, just like dazzle LED headlights. I had to changed the function ESS_AKTIVIERBARER_AUSGANG to bremsclicht blinkend (flashing).
07-17-2015, 12:37 PM | #10 |
Rep 18,780
Ahh. I never see it myself on the F15/F16 X5/X6 or F85/F86 X5M/X6M, but I saw it on F22 M235 F3x 3/4 Series F80/F82 M3/M4 during my track day and it flash twice before it went solid if I remember correctly.
07-17-2015, 12:53 PM | #11 |
Rep 3,834
It was probably coded. I coded my F80, the guys behind me on the track loved the flashing brake lights.
08-07-2015, 08:29 AM | #12 |
Rep 20
Is there anyway to enable front camera to work when the car is moving at fast speed? i have done this for the back and top view camera. don't know what the code is for front camera?
Also for some reason i cannot open the trunk with my foot on the new X6M. Anything i have to do? |
08-08-2015, 10:33 AM | #13 | |
BMW CCA #505303
43
Rep 185
Is rear hatch foot opening an available feature, this is the first I've heard of it (with BMW that is).
I need to code mine so that I can close the hatch from the remote as well as some of the others I normally code, such as Fogs on with Highbeam's, remove disclaimer messages, etc... I do like the idea of being able to see the front camera at speed and I'd have to think it's available. I know in my Range Rover the front cameras are available to turn on while driving directly from the factory. For those whom have done coding on the F85 or F15, could you please post which modules you have modified (coded). The last one I've coded was my 2015 650xi Convertible. On that it allowed me to change the display (Navigation) screen to display an animated ///M at startup which was really kind of neat. It would display this prior to the actual Navigation coming up. Quote:
2015 BMW X5M F85 ///M
08-09-2015, 04:59 PM | #14 |
Rep 1,377
Handsfree opening of the trunk is an option with Comfort Access on the X6 but not the X6 M due to the exhaust position. The X5 doesn't have this option at all due to the split tailgate design.
08-10-2015, 08:06 AM | #15 |
Rep 15
08-10-2015, 08:30 AM | #16 | |
Rep 729
If it's exhaust related on the M cars, that I understand. Not much could be done about that. |
08-10-2015, 11:07 PM | #17 |
Rep 518
I've been trying to get the foot hatch thing to work for a while - and have been assured several times by BMWNA's "Genius" team that the F86 does have it.
It obviously doesn't, and my guess too was that it was based on the exhaust layout on the M model.... |
08-11-2015, 08:13 AM | #18 |
Rep 729
I wonder if it was a last minute decision to remove it from the X6 M. In the manual that came with my X5 M, that also covers the X6 M, it specifically lists that the X6 M has this feature, but the X5 M does not.
08-11-2015, 08:51 AM | #19 |
Rep 3,834
Mine doesn't work. The trick is a kicking motion, not waving motion. I'll keep trying and look like an idiot at the grocery store's parking lot.
08-11-2015, 01:11 PM | #20 |
Rep 20
I wast told by the dealer that x6m doesn't have this feature due to the design of rear fender.
02-26-2016, 01:45 PM | #22 |
Rep 1
I want to have my fogs working only with DRL
I want to have my Fog log lights working only with parking lights on a X5 F85 2016 if somebody knows the coding value for that i will appreciate it..
Tags |
esys, f85 code, f85 coding, x5m code, x5m coding |
