      08-28-2021, 07:06 AM   #551
Kolianovskyi
87
Drives: BMW 650i
Originally Posted by Bstone View Post
Originally Posted by dmkaldas View Post
Alpina s0+ flash is quicker than s2
A lot of assumptions but I figure since it is alpina mapping that it would account for stock alpina configuration (full OEM exhaust and so on). So off the top of my head, alpinas may have different turbos and possibly different/larger coolers from the M version.
With that being said since your stock safest bet is to stick to stage 1. Stage 2 I believe suggests you get catless DPs
Logging still recommended
When I emailed pro tuning freaks they told me that stage 2 ran more boost than alpina 600hp tune. Also the alpina tunes were designed around the different alpina turbos.
Have you tried that stage 2 e30 map? That is the most aggressive of them all for the n63tu.
No, I have not. I do not have downpipes installed.
      08-28-2021, 03:06 PM   #552
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
Drives: Something fast
I just flashed it in a couple days ago. I agree much more aggressive.
      08-30-2021, 09:46 AM   #553
CYPER
Drives: X6 F16
Originally Posted by pennsiveguy View Post
I'd probably swap in new air filters, just to make sure that wasn't an obstacle. They're a 5-minute job. Our x50is will take the X5M filters interchangeably, and they've got more surface area so they breathe better and last longer. These totally make sense, since a BM3 tune makes the 50i make as much power and move as much air as the X5M. Doesn't make sense to pay $900 for a tune and some more $ for dyno time when a couple of $45 filters are holding the engine back.
Part numbers are 13-71-7-850-055 (right side) and 13-71-7-850-056 (left side).
I get mine here: https://www.getbmwparts.com/v-2017-b...ation--filters
Hi, do you know if these filters will fit X6 F16 50i?
They are of different shape size it seems.
      08-30-2021, 11:23 AM   #554
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
They share same engine
Same intake box
and requires two filters which are different in shape from each other so make sure you dont order two of the same part numbers. You should order two different part numbers one for each side as the pervious member listed.
Step up would be getting the filters from the X5m which also fit again two part numbers for these as well.
      08-30-2021, 11:34 AM   #555
CYPER
Drives: X6 F16
Same intake box
Hi, you seem to talk about 2 different sets of filters and none of them are the original for my car. Mine are both the same with one part number.
You talk about the ones from X5M and what is the other set?
      08-30-2021, 02:10 PM   #556
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
The original filters that came in your X6 50i and the X5M filters interchangeable
The shape of the x5m filter is different (to allow more air) but mounts and fits properly into these cars X5 50i / X6 50i / X5M / X6M
Hope this clears it up
CT335xi684.00
      09-17-2021, 08:24 AM   #557
Kracker DC5
Drives: 2014 550xi & a lil 4 cylinder
Talking with BM3 now on gains for E30 on the N63TU.
As soon as I get some confirmation (and potential gains/dyno verification) then I was going to flash my 550 and hopefully hit up the track tonight. As long as the rain holds off...
2014 550xi M-Sport/BM3 Stage II/Catless DP/Comp Exhaust
2002 RSX-S 2.4L on corn spooling 62mm=550+whp/2500lbs
      09-17-2021, 03:31 PM   #558
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
Ran at irwindale 1/8 drag the other night and mustered 3 runs
with temp at 65F and Density altitude was 1300ft
Running e30 bm3 s2 tune and catless dp (e85/91 blend)
Starts off bully with a bit of wheelslip but feels like it tapers down
I sent them over a log to see what they think.
      09-18-2021, 07:35 AM   #559
Kracker DC5
BM3 says the e30 map should add 31% HP / 33% TQ.
But, went to the track after mixing up some e30 and loading the map. It sucked. Idk what happened here, I was a second faster on stage 2 93 map. 60' was still good (1.8x).
Datalogs show that I was down on boost by several pounds. Working with BM3, damn good customer support
      09-18-2021, 03:38 PM   #560
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
After checking my logs I am also not reaching target boost on e30 map.
I just refueled and reloaded alpina stage0+ and waiting for support to get back to me.
Let us know what they say
      09-18-2021, 08:38 PM   #561
Kracker DC5
Ok, good. Was hoping it just wasn't something with my car. Makes me feel a little better about the situation. I'll go fill up with 93 and go back to stage 2 OTS map.
I'll report back once I hear anything.
      09-18-2021, 10:57 PM   #562
ahmad1985
SPC
ahmad1985's Avatar
7
Drives: BMW F15
I recently got stage 1 93 octane tune on my 50i. New plugs new filters just did fresh oil change. I started to notice x5 started chugging gas. The number where it says how many miles to gallon left fluctuates alot and i drive super conservative. No aggressive driving. There was a code of car running rich i used ista to check. so i changed maf sensors both of them. I just took the tune off today and wanted to see if car goes back to normal. Anyone else has had that experience where gas consumption went too high and running rich.
      11-11-2021, 07:16 PM   #563
Vocatusk
Drives: 2015 F15 x50i M Sport
Hey! New here,
X5 50i 2015 n63Tu, 83k miles odo
Mods are x5m filters, stage 2 (aggressive bubbles) bm3 tune,
Down pipes, and x pipe with resonator delete and catless. Just
The muffler is left, I've been reading through the replies of this post
And seeing people get 3.5 0-60 without launch control and dsc off
And I'm contemplating on launching my car in the same manor,
Does anyone think you engine will blow up? That's the only thought
Holding me back, I've never even launched it since I got it tuned.
      11-13-2021, 09:27 AM   #564
CT335xi
CT335xi's Avatar
684
Drives: 2022 x5 m50i, 2005 evo 8
Originally Posted by Vocatusk View Post
Hey! New here,
What are you waiting for let it rip!!
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno
Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr,
04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp
2014 x5 50i msport
      11-13-2021, 10:08 AM   #565
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
Hey! New here,
Make sure you're fuel is right, spark doesn't miss and as mentioned let it sing
If you want to take monitoring to the next step you could (and I suggest) taking a log. Nothing gives satisfaction and peace of mind like a good clean log every now and then.
      12-05-2021, 08:44 PM   #566
Solarize
Drives: BMW X5 50i
Quarter Mile Time 2011 X5 E70 50i
Took my 2011 X5 50i to the drags on the weekend, best run was 13.66. Outside air temps were 33C / 92F. I'm happy with the time for a stock car.
      12-06-2021, 06:28 PM   #567
Bstone
Drives: 2014 BMW X5 50i
Get a tune and downpipes man, my 1/8 mile is over a second quicker.
2014 BMW X5 50i
520awhp 605awtq
      12-06-2021, 08:02 PM   #568
Solarize
Drives: BMW X5 50i
That is the plan - out of interest what is your 1/4 mile time, high 12's?
      12-06-2021, 08:29 PM   #569
Bstone
11.7 @ 115
2014 BMW X5 50i
520awhp 605awtq
      01-04-2022, 09:37 PM   #570
jfandl
Drives: 2014 BMW X5 5.0 (F15) - BM3
Hey! New here,
Do it!!! I have the same setup except for the X pipe delete, my DP's are catless, you didn't mention if yours are. My car runs around 3.6 without LC according to my dash cam. Oh yeah, I have the xHP trans mod which made a major difference in acceleration because of shifting. If shifts like a race car with DTC off. It does decrease your mileage about 1.5 mpg though. The car (SAV) can handle it, not much else around here that can touch it.
      05-02-2022, 03:52 PM   #571
surgeonbyday
Drives: 2017 X5 50i (F15 N63TU)
New to tuning
Hey guys, I’m new to tuning and I am super excited about it. I’ve had my 2017 F15 50i for about two years now and finally decided it’s time to tune the baby. I’ve just ordered the JB4 tuner and the X5M intake filters. I have a couple questions about downpipes and charge pipes. I cannot seem to find any charge pipes for this f15 chassis with the N63TU engine. Is this necessary if I pursue a meth injection kit? As far as downpipes, I would love catless pipes but the shop in my area says I would have to trailer in the car and trailer out the car because it would not be street legal after the installation. Does anyone have any experience with that? Am I better suited for high flow catted pipes?
Thanks guys and I appreciate any additional recommendations. I have literally read every single page of this thread already and have learned quite a bit!
      12-31-2022, 11:54 PM   #572
F15FromHell
F15FromHell's Avatar
Drives: 2018 BMW X5 Xdrive50i Msport
2018 X5 50i m-sport
Bm3 Stage 2 e30 ots
X5M filters
Xhp stage 3 trans flash
Arm catless dp
340lb driver
Runflats
FCX52410.50
