05-08-2021, 10:03 AM | #1 |
Rep 32
Led Fog Error
Hi,
I installed new H11 Led fog lights on my 2015f15. I used bimmercode to change from Halogen fog lights to led fog lights. The new led bulbs work great, super bright and good colour match, however if I drive with the fog lights off I get a fog light error after about 5 minutes of driving. If I then turn on the fog lights the error goes away! Is there a code I'm missing? I did see temp sensor hot and cold awsell in bimmercode. Thanks all. |
05-08-2021, 11:09 AM | #2 | |
Rep 7,542
Go back into the Bimmercode app and look up “cold monitoring” and turn that to “NOT ACTIVE” for the fog lights. This should stop the warning if cold monitoring is still active for your fog lights. See info below from the Bimmercodeapp’s website:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 05-08-2021 at 11:20 AM.. |
Violator4587.50 |
05-08-2021, 09:30 PM | #3 | ||
Rep 32
Thanks |
05-08-2021, 10:12 PM | #4 | |
Rep 7,542
In regards to having fog lights on all the time by default...I don’t personally recall ever seeing that particular coding parameters.
