08-23-2019, 07:48 PM | #45 | |
528
Rep 2,822
Drives: X5M F85
spacejamm_x5m293.50 |
08-24-2019, 06:36 AM | #46 | |
Rep 900
08-25-2019, 08:16 PM | #47 | |
Rep 103
08-31-2019, 11:56 PM | #49 | |
Rep 6
09-01-2019, 07:36 PM | #50 | |
Rep 900
https://www.newtis.info/tisv2/a/en/f...epair-manuals/ |
09-01-2019, 11:50 PM | #51 |
Rep 900
Came across a post on E53 forum where an X5 (first generation X5) with front bump stop removed + sofware glitch caused the vehicle to bottom out resulting in locked front wheel and a clean blown apart front CV.
https://xoutpost.com/bmw-sav-forums/...ration-17.html |
09-06-2019, 10:33 AM | #52 | |
Rep 6
iconoclast7262.50 |
09-06-2019, 09:30 PM | #54 |
Rep 18,683
I believe so, I don't think I ever done one yet.
But I've sold the set to out of state before. It is the same thing as cutting the stock one. Well, better a actually since it is still one piece.
musa421.50 |
09-07-2019, 06:46 AM | #55 | ||
Rep 103
09-07-2019, 06:48 AM | #56 | |
Rep 103
09-07-2019, 10:02 AM | #57 |
528
Rep 2,822
Drives: X5M F85
Here's mine done and settled, rides like stock, bump stops untouched at this height. Also included a stock for a comparo.
09-07-2019, 10:04 AM | #58 |
Rep 103
09-07-2019, 01:08 PM | #59 |
528
Rep 2,822
Drives: X5M F85
09-07-2019, 03:55 PM | #61 |
IG: @88jae88
1621
Rep 1,734
What spec are these wheels?
IM POOR..
09-07-2019, 08:15 PM | #62 |
248
Rep 326
I'm at 30 1/2" in the rear with no bump stops. I've tried it with full stops, cut halfway and removed completely.
It rides fine until it bottoms and it does bottom hard if you're not careful. The lower you go the softer the air spring (bag) gets. There is no getting around that. It really needs a true coilover for the rear with the proper spring rate. The air bag is always going to be a problem no matter what shock you get. You can get a shorter shock that won't bottom but the vehicle won't handle as well as it should because the rear spring rate is way too soft. I definitely notice it in mine. I'm really surprised nobody else has mentioned it. Doesn't anyone else notice it? I'd pay a lot of money to have a real coilover in the rear.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM |
09-07-2019, 08:17 PM | #63 | |
Rep 103
09-07-2019, 09:08 PM | #64 | |
248
Rep 326
The problem is that the rear is actually softer. I've owned A&A Corvette Performance for over 15 years. We've installed hundreds of sets of coilovers on Corvettes. The Corvette is obviously different from the F85 BMW but the basic principles are the same The spring rate is always stiffer than stock on a properly designed set. As a matter of fact, the rear spring is stiffer than the front, even though the front is heavier. On our cars (trucks) we end up with the spring rates inverted. For normal driving this isn't an issue. I drive 800 - 1000 HP Corvettes all the time. I like to go fast. Even though these cars are way heavier, they can be fun to push through the corners. I honestly think that they handle better, when pushing it, before we lower them. They are just better balanced that way. My M5, on the other hand, handles better lowered because the spring rates are balanced front to rear.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM Last edited by VETTEPRO; 09-08-2019 at 08:46 AM.. |
iconoclast7262.50 |
09-10-2019, 12:15 AM | #65 | |
Rep 944
This is why the kw is a better option. Full shock replacement. The stock shock is too long and if you are slammed it’s going to bottom out without a proper shock to accompany the height.
I had a similar issue when I first lowered with HR Spring setup. It was the worst and unsafe ride ever. The VTf rear setup is pretty much the same. I had the rear height level with the front which was pretty low. Never liked the rake look. But after experiencing unsafe ride quality I raised the rear which made things more tolerable Ended going with KW and couldn’t be happier. Quote:
iconoclast7262.50 |
09-10-2019, 08:23 AM | #66 | |
248
Rep 326
The car will never handle as well as it could with the rear spring rate being so much softer than the front. It's the best we can do until someone designs a true coilover for the rear. Unfortunately that will never happen due the low demand. If we could still utilize the air bag and have a light spring on the shock to make up the difference, that would also work.
