09-13-2019, 09:58 AM | #1 |
F86, G05, E91
455
Rep 778
Wheel hub? Hmmm. Not so sure.
So do I trust the dealer with my left front clicking noises as needing a new hub for 890? And they say it's from potholes so not a warranty item. I think it's brakes or CV. Not sure.
09-13-2019, 10:41 AM | #2 | |
Rep 1,025
Drives: Mein F Fünfundachtzig Einhorn
Stealers love to remove & replace parts. So unless you've got $890 burning a hole in your pocket, maybe a 2nd opinion is in order?
09-13-2019, 02:26 PM | #3 |
F86, G05, E91
455
Rep 778
09-13-2019, 11:43 PM | #4 |
Rep 1,449
Is it the wheel bearing issue that you are having? Clicking noise when turning?
No. Try not. Do. Or do not. There is no try.
-Yoda |
DgjoX6M2016455.00 |
09-14-2019, 04:33 AM | #5 |
Rep 5,728
Drives: '24 iX50; '23 i4 M50
Simple friction discs under warranty are all my dealer installed for the clicking noise, and no more noise. Apparently there is an updated bulletin. I posted my invoice here a bit ago.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
09-14-2019, 12:53 PM | #6 |
Rep 1,449
Here is the thread on the wheeling bearing issues:
https://f15.bimmerpost.com/forums/sh....php?t=1143328
-Yoda |
09-16-2019, 06:04 AM | #7 | |
F86, G05, E91
455
Rep 778
-pair of pliers on the oil fill cap damaging it (and leaving it) -engine cover post grommet missing -rear calipers are all stained with white stuff after brake service. Maybe they sprayed something on them when hot? -left service indicator on after all my service. Now it lights up every time. What does all this mean for the major stuff?! |
09-17-2019, 10:44 AM | #8 | |
Rep 271
When my M5's wheel bearing went, it made clicking noises while turning. If this wasn't an AWD car, I'd say changing the wheel hub is just four bolts. AWD and a half shaft will complicate things.
Based on your other experiences, I would look to a different dealer. Good luck, Chester Quote:
DgjoX6M2016455.00 |
