05-11-2023, 08:54 AM | #1 |
Rep 48
Rear view mirror upgrade
Hi all,
My rear view mirror is missing Homelink so I wanted to upgrade to one with the three buttons included. Got hold of a mirror off ebay and hoped it would be a simple plug'n play operation. However, after installing I have several error codes, one stating incorrect mirror installed. Is there a way around this, is it possible to retrofit a homelink mirror? Cheers, Sean |
05-11-2023, 01:52 PM | #2 |
Rep 7,542
Did you shop using the correct part nbr(s) for you F96 based on its VIN & options?
For example, if I look up the interior mirrors for the F96 X6M...it shows item #1 & item #3 in the diagram below as having the HOMELINK buttons. That gives the option of two compatible (current) part nbrs (and click the links below to see other older compatible part nbrs):
05-11-2023, 05:20 PM | #3 | |
Rep 48
The part number from the one I bought is 9274270-01. I honestly didn't check this very thoroughly before buying, I assumed they were basically interchangeable. I saw that the one I bought had the three homelink buttons and the alarm LED below and figured that was OK. In Realoem there were so many variations I found it hard to understand which one I actually had. |
