04-21-2021, 11:30 AM | #5303 |
Rep 40,924
Your CAS functions are part of your BDC_BODY module.
alanm1.50 |
04-21-2021, 03:14 PM | #5306 | |
Rep 40,924
04-22-2021, 10:10 AM | #5308 |
Rep 111
There have been some good deals on ebay lately for complete BMW coding laptops preloaded with all software and ready to rock out of the box. They're typically used, older laptops but perfectly fine for the purpose.
My old setup bricked somehow so I picked one up last week for about $300. Leveno X220 thinkpad running windows 7 with the nicer screen with all tools loaded, help files, etc. plus an enet cable. |
04-22-2021, 10:27 AM | #5309 | |
Rep 2,514
http://tokenmaster.blogspot.com/2019...r-pro-282.html |
04-22-2021, 11:49 AM | #5310 | |
Rep 111
04-22-2021, 01:18 PM | #5311 |
Rep 2,514
04-22-2021, 03:07 PM | #5312 |
Rep 111
Indeed I do. Esys launched through Esys plus. No idea if that's good, bad or indifferent as I can FDL code most anything I need through bimmercode anyway. I guess I could install the other launcher if needed but I only needed to VO code a few things on the F15. I use NCS Expert and other tools for my E46 M3.
In any case, my only thought in the original post was to point out to folks asking questions above that if you need a dedicated laptop anyway then you can buy one preloaded with all the tools. |
04-22-2021, 06:40 PM | #5313 |
Rep 1,696
Drives: 2014 428i and 2018 X5
Anyone know if there's a way to code the instrument cluster so it stays white and not red at night?
04-23-2021, 05:06 PM | #5317 | |
Rep 7,522
Unfortunately I don't remember if I did it to my 2013 F06 650iX GC or 2014 f15 X5...and they both have the 6WA cluster...and I believe it may have been done using Expert mode. Do a search for the coding parameter charts that are out there and then check to see if your communication bus & modules have this coding parameter. ???? KOMBI-->3007 KI_Dimmung, 24-->DIM_NACHT_EIN-->Werte=FF ??? EDIT: Looks like you need to have the KOMBI module to do the above coding...if you don't have the KOMBI...then this is a no go.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-23-2021 at 05:22 PM.. |
ooshnoo880.50 |
04-24-2021, 01:45 AM | #5318 |
Rep 23
Trying to code folding mirrors. Have mirrors that fold on the button and the fob if you keep the button pressed, but want them to auto fold on lock and vice versa.
I've coded these: CAS / KOMFORTSCHLIESSUNG_FB = aktiv CAS / KOMFORTSCHLIESSUNG_PA = aktiv FRM / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv But it hasnt worked. Anyone got any ideas? |
04-24-2021, 11:19 AM | #5319 | |
Rep 3,061
Code KOMFORT_SCHLIESSEN to 00 (fold-mirror delay time).
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
alanm1.50 |
04-26-2021, 09:16 PM | #5320 | ||
Rep 49
KOMBI-->3007 KI_Dimmung, 24-->DIM_NACHT_EIN--> Werte is either activ or nitch activ, and it doesn't matter what i select it still turns red at night |
04-26-2021, 11:38 PM | #5321 |
Rep 23
Need help with Mirror Folding and Enhanced Bluetooth
I've coded these lines:
KOMFORTSCHLIESSUNG_FB = aktiv KOMFORTSCHLIESSUNG_PA = aktiv ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN = aktiv KMFRT_SCHLIESSEN->Werte=00 But I must be missing something. The mirrors only close when I hold the keyfob for 30seconds. Also been trying to code Enhanced Bluetooth, I added 6NS and VO coded the modules but I still don't have office in the menu or the ability to add 2 mobile phones. I've removed and re-added the phones, it just doesn't make any difference. Anyone any ideas? |
05-02-2021, 04:41 PM | #5322 |
Rep 21
Hi, new to F15 but have coded before on my E63. please could someone PM me the download details for the E-Sys software and latest PSdZData? Thanks!
05-02-2021, 04:42 PM | #5323 |
Rep 40,924
PM sent.
05-05-2021, 12:38 PM | #5324 |
Rep 40,924
Under E-Sys Options, you were supposed to have Unchecked both Boxes for Update MSM and Update VCM.
