12-04-2018, 02:16 PM | #177 |
Feelin Nauti
104
Rep 116
Since my subs are firing up and open on top I did not use Dyna mat. I did carpet the box on all sides and also used spray glue to install a carpet liner under the box to help with vibrations between the box and the trunk. Sounds great and no real vibration noise from the box or bottom of trunk.
2014 650i M Sport Frozen White Matte Metallic
2015 X5 M Sport 50i Mineral White 2012 650I Conv Sapphire Black 2013 Harley Softail, Road King, Road Glide show bikes 2010 40' Express Cruisers Yacht |
12-05-2018, 10:53 AM | #179 |
Rep 1,066
Drives: 2015 X5 50i M Sport
Somehow mines are from window glasses.
2019 Cayenne Turbo
12-05-2018, 01:20 PM | #180 |
Rep 209
Drives: 2018 X5
Twin Peaks94.00 amtrucker2247.00 |
12-05-2018, 03:32 PM | #181 |
Rep 2,388
12-05-2018, 10:30 PM | #184 | ||||||||||
Rep 144
I used regular tool box liner which was 10 bucks in Home Depot and it doesn't rattle at all. The only thing that might rattle is the clip that flips down when you close that compartment. |
DuSh2113.50 |
12-05-2018, 10:48 PM | #185 | ||||||||||||||||||||||
Rep 114
2016 X5 50i MSport in White
Dinan Powered AC Schnitzer Springs 22" Varro VD01 Wheels iND Black Emblems and Badge |
12-05-2018, 10:55 PM | #186 | |||||||||||||||||||||||
Rep 144
And prob like 3inch after lid closed since you have 9in in total space |
12-12-2018, 01:14 PM | #187 |
Rep 114
The installer said that the sub I'm adding will tie into the same line/channel as the stock subs (under the seats), is that accurate or can they be totally separate? Regardless, if I have a bass nob will that just control the sub and not factory subs?
12-12-2018, 01:39 PM | #188 | |
Feelin Nauti
104
Rep 116
Its just a line in for that amp. It has no affect on your stock system. You can go a more expensive route and get a piece made exclusively for our vehicle that taps off the wiring harness to your stock amp... but really not necessary. What the installer is telling you will work fine and will not have any repercussions on your vehicle.. You will have complete control on the added subs with the new amp, its crossovers and gains. You will also be able to adjust on the fly if it has a remote knob. I hope this answers your questions.
trlengle83.50 |
12-12-2018, 03:38 PM | #189 | |
Rep 1,247
12-12-2018, 08:27 PM | #190 | |
Feelin Nauti
104
Rep 116
DuSh2113.50 |
12-12-2018, 10:40 PM | #191 | ||
Rep 1,247
12-13-2018, 07:56 AM | #192 |
Feelin Nauti
104
Rep 116
Yes the one factory amp for the entire audio system is in the cargo area behind the panel rear drivers side where first aid lit and emergency triangle and cargo net are located.
12-13-2018, 08:21 AM | #193 | |
Rep 1,247
Thanks for the info!
12-13-2018, 04:28 PM | #194 |
Rep 114
I'm installing a 12" sub (JL Audio CS112LG-TW3) to a JL Audio Amp (XD500/3v2) and the installer said I'm good to go, no other hardware pieces except the bass knob and cables. Apparently my amp can handle the high level inputs from stock amp. This amp also gives me a channel for the future if I want to upgrade my 4" speakers in the front.
12-14-2018, 03:55 PM | #195 | |
Rep 703
high-level inputs — up to 8 volts RMS (about 16 watts) I believe the BMW line is higher than 8 volts...but I'm not 100% sure; on my car I installed a LOC just to be sure |
12-14-2018, 03:57 PM | #196 | ||
Rep 703
On Friday, October 5, 2018, 9:00:34 AM EDT, Elias Jones <TechnicPnP@hotmail.com> wrote: Please select X5 (F15) -> Top HiFi(688) at main page of www.TechnicPnP.com for the selection of products for your particular BMW model and OEM audio system. A LOC is required as the OEM amp outputs 35V+ peaks at the woofer outputs. No JL Audio sub amp can handle such high level inputs - it will damage the aftermarket amp. |
12-14-2018, 07:09 PM | #197 | |
Rep 277
trlengle83.50 |
