12-19-2018, 06:04 PM | #1 |
Rep 54
Android Auto, Waze and more: aftermarket screen with Android 8.1 Install & Review
Hey there, I did it, I changed the screen for an aftermarket version.
Here is the version I acquired, from 4x4shop.ca, select Android 8.1, and take the GPS Antenna Splitter. You can take the CarPlay/Android auto USB Dongle, I tried to use it with Android, no success. I need to test it with an iPhone for CarPlay, and I'll update the thread. To start with the conclusion, would I recommend it? Yes, definitely, if you are looking for a way to have any Android app on your infotainment (waze, google maps, android auto,etc.) How does it work? So the BMW "brain" of the system is behind your CD player in the front. The screen is just a screen, there is nothing else into it. It's the same you will have with a desktop computer: The tower is the "brain", and the screen is just a dumb component that display a picture. When you replace the screen, what you do is install an Android tablet with a video input, so the BMW system will work exactly the same as before, you will have in addition an Android system that is working at the touch of your fingers, and to some extend with the idrive wheel controller. Then you have a harness that is going in between the car and the BMW "brain", that intercepts and send signals to the Android interface. + and - The good - Hardware is powerful enough to make the experience fluid - Android 8.1, so you can install all the recent apps - Integration with the physical buttons - Possible to use the BMW interface only if you want - Possible to install any Android launcher, and to create the experience you want, no limit here except the time you want to spend on it - Navigation button launch the app you want - Switch from BMW system to Android with holding the menu button - Screen quality, no reflection/glare (even if it looks different in the pictures, it does not look glossy when you look at it) The meh - No camera, that would be great for video calls - Software does not have all the Google services installed, you have to side load a bunch of apk to have a full Android experience, - The option/settings apps is not very well designed - No automatic screen brightness with ambient light - I wish they would offer the option with 4G/LTE, as it's an extension card on the hardware - The hardware: plastics are not qualitative, assembly is not very well done, gaps in between all elements. It looks bad when you open the box, but when it's installed, you don't notice it as it's a bit further away, and you don't see the back. It is far, far, far away from the BMW screen in term of assembly and plastics quality. The bad - The interface that pretend to be a BMW interface, and is absolutely not (but you can change it) - Microphone has a hard time to capture the sound from far, you have to lean towards the screen to make it work - The wifi only works in 2.4Ghz (no 5Ghz) How to install? The hardware It's very easy, don't freak out, you only have 6 screws to remove. I watched 2 videos, and it's well explained: Here is how to remove the dashboard and screen Here is how to connect the harness and the screen You will actually not use most of the connectors, it's only the basics ones that you need. The audio works fine, no need to do the hack they are talking about. I recommend to tape the extra cables together, to make everything look nice and not have things all over the place. For the double USB entries that they put in the glove box, it's not mandatory. I put the cable from the center to bellow the glove box (in the fuse box), and it gets out at the passenger feet. You will see, there is a hole, and you can run the cable along the center console, no drill, no hole, it just goes nicely. I will actually not use any of the USB cable, so will let them inside the fuse box. The install was much easier than I thought it would, it was super fast to install. The software Ok, here, the first thing I recommend you to do is installing another launcher. Seriously, the interface is bad, really bad. I tried a couple, and ended with Smart Launcher 5, it has an interface that works very well as an infotainment (big button, shortcuts, gestures...). Side load the Google Contacts Sync 8.1.0 (and only this version), then go in Android settings, in permissions, and give permission to the app. Install the Google app. Install the Google assistant. Side load Android Auto, and launch the app, it will ask you to install a couple more services. Do it and launch the app again, it should work. Install the last Contacts App (you can put a dark them on it), and uninstall the old contact app (check with the icon). Install any app you'd like from the Play store (Waze, the Weather Channel, Calendar, YouTube, Duo, Messages, Messenger, Hangout, Netflix, Audible, Spotify, etc.). Have fun configuring the launcher to your taste. The review Watch here Basically, things did not start well. Assembly and plastics quality being what it is, I had doubt on the look when installed, but honestly, I have no pb with it now (and I am a crazy person regarding to details and quality). Then the software, oh my, I wanted to return it, it's terrible! There is nothing worse for me than pretending to be something you are not. But here is the thing, what you have is an android device... So install a launcher, apps, widgets, and whatever you want to create the experience you are happy with. So with the setup I have now, I am very happy with it, and can definitely recommend it. I put my phone in hotspot, the unit connect to the wifi, and I am good to go. It feels so good to not have a phone and "stuff" in the middle console, and use the infotainment to have waze, Spotify and company. It was my goal, and it works well. Next steps I have still some experiments to do, and will update the thread: - Carplay - Some Bluetooth experimentation - I have a random crash of the Smart Launcher 5 when the system starts, might not be happy with another app I installed, it's nothing, I'll see if I have time to fix it one day - Improving the microphone (might have to unmount the screen and check the hardware) My dream? The same unit, better plastics, better finish (no gaps), better microphone(s), light sensor, camera, 4G/LTE sim card slot. That's it... I would pay double to have all this, because it's so worth it. Need help? Feel free to ask questions, and if you make the jump, I'll be happy to help! If you live near San Francisco, you can also come by, test the system, and I can install it with you if it makes you feel better Last edited by Fab's; 12-20-2018 at 02:37 AM.. Reason: Added picture |
7
12-19-2018, 06:15 PM | #2 |
Rep 54
12-19-2018, 06:55 PM | #3 |
1150
Rep 2,426
Gives a whole new meaning when people say BMW just sticks a tablet onto the dashboard.
Is the screen very glossy, not laminated, or both? I hate really glossy screens and the BMW has a very good antireflective capability.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
12-19-2018, 07:10 PM | #4 |
Rep 54
The screen is not glossy, I was actually very surprised when I took the pictures to see the reflection, because it does not look this way at all
12-20-2018, 02:22 AM | #6 |
Rep 54
Thanks for telling me, I changed the hosting and added some more. It should work now.
12-20-2018, 07:50 AM | #8 |
Rep 714
Drives: BMW X5 M Sport - G05
12-20-2018, 09:17 AM | #11 | |
Rep 54
I want to make sure you know it is incredibly easy to remove the components. It took me less than 10 minutes, and because I was doing it for the first time. Doing it again would take me less than 2. Pull on the wood panel from the glove box, it'll come off, and you have done half of the work already. If you want to do it, I'll be happy to have a video call and assist you. |
12-20-2018, 09:19 AM | #12 |
Rep 54
12-20-2018, 09:25 AM | #13 | |
Rep 54
Now if they disguised it so well that all the version number are 8.1, and all the apps work, that's fine with me Also, the contact sync app is the version that work only on 8.1, so I believe it is really Oreo. |
12-21-2018, 07:21 AM | #16 |
Rep 1,343
I think this is an even more important question
12-21-2018, 12:07 PM | #17 |
Rep 54
Short answer is no.
Please watch the video I made that explains it This is what I tried to explain in the "how does it work" section: Basically, the screen in BMWs is just a dumb screen, there is no intelligence into it. So when you replace it, you don't lose any feature, the BMW unit that manage the features is still here and send images to the new screen. LMK if it's more comprehensible. |
12-21-2018, 12:57 PM | #18 | |
Rep 54
You can also have Apple Carplay with a dongle they provide (I did not test it yet). |
12-28-2018, 01:02 PM | #20 |
Rep 29
I had this on the E70 I just got rid of, it really left too much to be desired.
The audio was horrendous. Though the way it achieved audio was through the aux in on the car. I imagine a lot had to do with whatever cheap audio chip was in the unit, so perhaps if this is connecting a different way it may be ok. On top of that the android portion was so incredibly buggy and laggy. Every time I opened spotify if forgot my login. The idrive would navigate one step in the wrong direction before going the right way. And a ton of other small things. I will say I never got around to trying out Carplay which was one big draw for me on the unit, I am sure Android Auto is fun to test out. |
12-28-2018, 03:42 PM | #21 | |
Rep 54
Mine works pretty well for me so far, I use Spotify without issue, audio is through the bracket, not with audio input, and quality is good, interface is fast, integration with idrive works great. You also have to load another launcher to make the experience enjoyable, I find the original one horrendous. |
12-29-2018, 02:00 PM | #22 |
Rep 7,160
i woulda have loved to seen a side by side screen resolution comparison. Thanks for the write up. These units have been around for so long and used more in the F30 side of the house. almost pulled the trigger on this unit that was being sold by another forum member like a week or two ago but get hesitant since all i really was interested in is carplay and having waze on my screen. I'm not an android user and can use all the apps i need from my phone via the usb port (music that is). Never really saw a need to have google on my idrive when again its right there in my hand and i can type so much easier on my phone that a touchscreen thats 3' from me.
IMO, the only thing that is left out of the iD4 is carplay. I dont like touchscreens cuz they make the screen dirty AF. I do like the iD5 home screen interface better but i would never see it cuz i'm always driving with my Nav screen split with entertainment anyway. I wanted to get the bimmertech MMI carplay adapter thing but they force you to have a 2/3 screen (like BMW does they explain) which is dumb and as of yesterday i was told they may never be able to change it to full screen despite even iD5/6 users being able to get full screen carplay to work these days. So this alone may drive me back to your Avin unit or to unichip (but they scare me being completely foreign and bad customer service). decisions decisions.
CatalinP589.50 |
