11-22-2023, 12:57 PM | #1 |
Rep 23
Rims Damaged during storage - thoughts on cause?
Just got our winter tires switched over and immediately noticed all four rims are peeling the and the emblem is popping out. The rims are 7 years old and were by all means not pristine but did not in any way look like this. I luckily had a photo of the car in the garage last winter and the rims were fine. Mechanic stores in a shipping container onsite. He maintains this is normal corrosion from the salt/brine used in this area. He then stated it was our fault for not cleaning the wheels prior to storage. Basically gave us a million excuses as to why this normally occurs over the course of 6 months of storage. Interestingly, they also told us the winters had one more season then took them out and told us they were done. I should have gone to look at them. Combined with the condition of the rims, I am now wondering what happened to the tires.
Has anyone see damage like this or have any thoughts if this was caused by heat and/or moisture in the container? It rained excessively this summer and we did have some hot days. Lastly, appreciate any thoughts on refurbing these or replacing them. Thank you. Last edited by katkins; 11-23-2023 at 09:12 AM.. Reason: Add image |
11-22-2023, 01:13 PM | #2 |
Rep 1,821
That looks to be quite extreme decay. I'm not sure a sandblasting will leave much undamaged alloy behind.
A before picture would help but that's the poster child of why you shouldn't store salty metal in a potentially damp/humid area. They're toast. |
spammysammich1604.50 |
11-22-2023, 01:19 PM | #3 |
Rep 6,307
Just to clarify, were the rims still dirty from last year winter season or did you indeed clean them?
I don't have professional experience but IMO if they were still dirty with some salt, I could see it happening especially stored for so long with moisture. I bought used alloys for my winter set up to and have some bubbling like that in certain areas from just normal driving (I would say they are around 7 years to, got them used but I put 5 years on them), so if that winter salty mixture was still on the rims perhaps it infiltrated with moisture. Fun fact (not so much), winter salt corrosion is the worst in spring exactly because of the moisture and temperature. |
11-22-2023, 01:26 PM | #4 |
Rep 3,620
Agreed, straightforward corrosion. It's the metal underneath, and it's making the finish flake off. Storage conditions didn't help, but there were almost certainly some issues before then which were simply made worse.
Options? The right processes could get off the old finish and clean them up reasonably well. Then they'll need refinishing of course. You might always see some evidence of their condition even under the new finish. And in my experience new powder coating doesn't stick the absolute greatest, so don't expect perfection. I'd call them your winter wheels and run with the ugliness. At least until it gets to the tire bead and you start losing air pressure. Or of course replace them. You can repair them but at a cost of a new wheel. Not something you really do to 4 wheels, unless it's to get a crazy color for a show car. Usually the process is to repair a single wheel to match the others. |
11-22-2023, 01:26 PM | #5 |
Jim90046
9
Rep 26
Drives: 2012 135i Convertible/2019 23
Your rims can be repaired. It probably won't be cheap.
I am very anal about my BMW. I have a rim guy who does amazing work. So good I had him repair my wife's Benz E350 convertible rims. Again I was really impressed by the result. So do a little shopping, Rim refinishing ranges from about 75 to 250 bucks a rim. |
11-22-2023, 01:27 PM | #6 |
Rep 23
Added photo of before they were removed in the spring. I think it's clear enough to see they were undamaged. I agree about sandblasting. I am considering buying used from Marketplace.
11-22-2023, 01:30 PM | #7 |
Rep 1,821
From the added pic it looks like they were in good shape. I wonder if the mechanic grabbed the wrong wheels? That's a lot for 1 storage season of paint bubbling.
tracer bullet2502.00 |
11-22-2023, 01:36 PM | #8 | |
Rep 23
11-22-2023, 01:50 PM | #9 | |
Rep 6,307
11-22-2023, 01:52 PM | #10 |
Rep 6,307
It's a pic from far but I do agree they seem to look mint lol. But if it was the wrong wheels the tires in the pictures would most likely be different to than what OP bought?
11-22-2023, 01:53 PM | #11 |
Rep 290
ugh - those look horrible.... sorry man
I head over for a car wash the same day I am going to swap out my wheels I change and store them in my garage - so when I do the swap, sometimes they are still wet, but I let them dry off before wrapping them in their tire protectors I cannot see that happening in one round of storage - very confusing
2019 YMB ZCP convertible with Dinan Exhaust
2011 Ducati Diavel Carbon Edition 2015 BSM M4 Convertible - 2018-2019 2016 228Xi - 2017-2018 2003 Acura RSX Type S 2003-2017 |
11-22-2023, 02:02 PM | #12 |
Rep 23
I checked in with my dad who stores at the dealership and they clean the tires prior to storing. Lesson learned.
11-22-2023, 07:17 PM | #13 | |
Rep 23
Every part of this experience has been a peach let me tell you. The owner also went on an anti BMW rant and said he will only service in warranty BMWs going forward. |
carseatsm5845.00 |
11-22-2023, 07:23 PM | #14 |
The Seeker
14063
Rep 3,375
Salt.
Replace. Car must be clean as a whistle for storage, end of story. ZERO salt. |
DrFerry6731.50 nyalpine907442.50 |
11-22-2023, 07:29 PM | #15 |
Rep 23
///MPhatic14062.50 DrFerry6731.50 |
11-22-2023, 07:30 PM | #16 | |
Rep 23
MADBMWX5MC918.50 |
11-22-2023, 08:08 PM | #17 |
Rep 569
Each fall/spring I change out the winter/summer shoes for our buggy. Just put the winter shoes on and was looking at the summer shoes and thinking I do not want to get bucket out and wash them. Just want to put them away for the winter. But I did. Left them for a couple of days in the garage to dry, then put them in their bags and stored accordingly. Rinse and repeat.
As for the OP wheels. A couple of thoughts, obviously we have two sets of the wheels. I was not a fan of the original wheels which I managed to ding one nicely. The others had some minor road rash so I had them all stripped, repaired, and repainted. They were repainted in a gun metal gray. They look sharp for the winter. Last edited by BeEmVe; 11-22-2023 at 08:15 PM.. |
11-23-2023, 09:14 AM | #18 | |
Rep 23
11-23-2023, 09:57 AM | #19 |
Rep 3,620
FWIW you aren't crazy, that's an incredible amount of corrosion for 1 season of storage.
What's up with the marks on the tires? A lot of white stuff going up the sidewalls. Did it happen during storage? Was somethign flung off the wheels when you were driving home? It might be related... |
11-23-2023, 10:24 AM | #21 | |
Rep 23
11-23-2023, 10:26 AM | #22 |
Rep 23
