03-25-2020, 12:34 PM | #23 |
1636
Rep 2,995
The 6wa is a nice cluster. Good mix of analog and digital.
03-25-2020, 02:47 PM | #25 |
Rep 648
Way nicer than the basic version, the offset display bugged the crap out of me.
Anyway, this thread is about the 6WB, and I merely wanted to post about recommending Koanga, since he's able to help with the 6WB too. Once he was up and running with UltraViewer on my old laptop, it didn't take long at all for him to get the final step done.. |
03-26-2020, 12:19 PM | #26 | |
Rep 159
Looks cool, definitely not worth $3K. I could buy new wheels and a performance exhaust with that cash before I buy a digital display. |
03-31-2020, 03:07 PM | #29 | |
Rep 648
Base version has a small digital screen, off center to the right bottom of cluster. 6WA has a wider digital screen, centered at the bottom of the cluster. 6WB as OP is talking about, is all digital. |
03-31-2020, 04:39 PM | #30 |
Rep 7,477
Post #25 (right above your post) mentions that there’s a “basic” cluster.
There’s the basic analog cluster, the 6WA analog/digital cluster, and the 6WB full digital cluster. There are also visual clues as to which cluster you have before you even turn the car on:
04-14-2020, 06:55 PM | #31 | |
Rep 1
Are you still selling the 6wb cluster..? Please email me iashraf213@gmail.com Thanks |
05-16-2020, 11:36 AM | #33 | |
Rep 2,511
https://f15.bimmerpost.com/forums/sh...039855&page=20 You still can have Navi on the hud, you can't have navi instructions on both at the same time. If you turn the HUD off-it will display on the cluster, if your HUD is on-navi instructions will be still projected there. I personally use HUD navi at night but during sunny day I turn the hud off and switch to cluster navigation for better visibility. |
08-15-2020, 08:18 AM | #34 |
Rep 23
Does anyone know what's going on with my car.I installed the 6WB cluster a couple month ago.And I was very happy about that,but one time I parked my car,and left,when I came back I started the car and there was no any lights on dashboard.Just got all black.I got home and unhooked the battery,and after 5 min hooked back,and it was working again.After a couple weeks i got same problem,and did same procedure.And got it working again.But yesterday it happened again,I did the same and it didn't work.PLEASE HELP!!!I am pretty sure someone got same problem as well.Thanks a lot.
Now when I start the car it shows me I drive message and I even can't select anything from menu. Last edited by Bmwdrocher; 08-15-2020 at 08:25 AM.. Reason: Attached files |
08-15-2020, 10:55 AM | #37 |
Rep 23
09-26-2020, 10:31 PM | #39 |
Rep 199
Can anyone advise a 6WB cluster to pick up used? They all seem to have different part #s. Can I get any 6WB? I have a 2017 G30.
Thanks for the help! |
09-26-2020, 10:43 PM | #40 |
Rep 199
also does anyone know if you can get a 6WB cluster that is KPH coded to MPH? Since it is all digital is it just a code change?
Thanks! Last edited by Supacat; 09-26-2020 at 10:53 PM.. |
09-27-2020, 11:13 AM | #41 |
Rep 2,511
Part numbers can be found here:
https://f15.bimmerpost.com/forums/sh...039855&page=20 As well as the answer to your second question, yes it can be changed to km/h or MPH. |
09-27-2020, 12:23 PM | #42 |
232
Rep 337
