12-22-2019, 05:58 PM | #1 |
Rep 402
55,000 miles
Approaching the 55k mark and I'm just wondering what I should be doing maintainence wise. Already did brake fluid and changed spark plugs. Oil changes every 5-6k Miles since I got the truck with 36k on it. Anything I should be looking to do? Tranny?
12-22-2019, 06:18 PM | #2 |
Rep 65
Similar situation and changed both differential fluid (OE Brand), transmission fluid (ZF Filter and Fluid Kit), all air/engine filters, and spark plugs. All purchased through FCP Euro. Good preventative maintenance for those of us who plan on owning long term.
12-23-2019, 12:47 AM | #3 |
199
Rep 351
Would definitely add changing transfer case fluid onto that list. Had my TC fluid changed at 50k and the oil was dark blackish brown looked pretty bad don't forget to have them recalibrate through ISTA after TC fluid change as the clutch packs need to readjust there have been some who skipped recalibrating which led to some jerkiness.
12-23-2019, 07:37 AM | #4 | |
Rep 65
201198.50 |
12-23-2019, 07:39 AM | #5 | ||||
Rep 402
12-23-2019, 12:33 PM | #6 |
199
Rep 351
Seems like your in Jersey if that's the case you can hit up Dave at apexautocare in Ridgefield lots of members here including myself had fluids done there at a very reasonable price and there service was great. If I can remember correctly for both diffs, transfer case with ista reset, brake flush and drain fill/plugs all in all was about 490$ and thats with all genuine bmw fluids this was for a 35i. Not sure where they sourced there parts but it was just as cheap as getbmwparts so you wouldn't have to bring your own fluids.
12-23-2019, 12:49 PM | #7 | |
Rep 249
I’m at 43k and will definitely hit up apex auto for my service. Last edited by NYC_X5; 12-23-2019 at 01:11 PM.. |
201198.50 |
12-23-2019, 01:19 PM | #9 |
199
Rep 351
Lol yup, got quoted 1300$ by the dealer
12-23-2019, 02:39 PM | #10 | ||
Rep 402
I have a 2015 50i will that matter price wise? |
12-23-2019, 03:33 PM | #11 |
199
Rep 351
Speenybean91.50 |
12-23-2019, 05:56 PM | #12 |
Rep 108
My 50i with DHP required two different type of fluids for the rear diff and just one particular fluid for the front diff so I do think it depends on what suspension you are running on.
01-16-2020, 08:27 AM | #13 |
Wisdom Searcher
58
Rep 193
Good info. Anyone have more info on reprogramming needed after TC change? Hadn't heard anything about that before.
BLUE HEAVEN
My cars - 2002 Lemans M5, 2006 Interlagos M3 |
01-16-2020, 08:36 AM | #14 |
Rep 1,261
Transmission service is overkill at 55k...Wait till around 70k
Speenybean91.50 |
01-16-2020, 08:58 AM | #15 | |||
Rep 274
03-25-2020, 11:43 AM | #16 |
Rep 885
Anyone else can recommend any reputable indy shops in Jersey? Just found out Apex stopped doing mechanical services bummer..
03-25-2020, 12:00 PM | #17 | |
Rep 402
maDjzo861.50 |
03-25-2020, 04:06 PM | #18 |
Rep 885
03-25-2020, 05:10 PM | #19 | |
Rep 402
03-25-2020, 07:20 PM | #20 |
Rep 115
Personally, depending on what year you have.... I would absolutely replace the Battery or Batteries (if you have two).. Especialy if your at the 5 year mark.
06-19-2020, 10:12 AM | #22 |
Rep 31
