03-26-2020, 09:45 AM | #1 |
Rep 1,535
Any minor or major issues with F15 35i?
I am looking to buy one within couple of months and checking with owners if there are any reliability concerns with F15 35i. Engine, transmission, waterpump, fuel pump, suspension components..etc
The car has been out for 6-7 years now and usually you would not notice any issues until you hit 100K+ miles after 6 years of ownership. I realize many of the owners would jump ship once they hit this mark so I am looking for feedback who owned it enough and put alot of miles on it. |
03-26-2020, 11:31 AM | #2 |
1636
Rep 2,995
35i is pretty reliable. Go for it. No real common issues. I have around 120k miles with no repairs, just maintenance.
The Libertine1235.50 OnlyGerman362.00 |
03-26-2020, 01:08 PM | #3 |
Rep 1,222
03-26-2020, 03:56 PM | #6 |
1636
Rep 2,995
03-26-2020, 05:00 PM | #7 |
Rep 1,535
03-26-2020, 05:36 PM | #8 | |
1636
Rep 2,995
Certain oil leaks may occur with age. Overall the 35i is pretty reliable. Last edited by turboawd; 03-26-2020 at 08:49 PM.. |
03-26-2020, 10:39 PM | #9 |
Rep 3,647
I've owned a lot of BMW's over the years that have required full cooling system replacement well before 100K miles - not preventative, but due to failure or on the verge of failure.
If you really treasure driving these vehicles, are you really worried about a few fixes here and there before 100K miles? Even if it's a water pump or bigger ticket item? To be expected on a higher end vehicle IMO. I've owned 2 50i's and an M3 in the last year - I would have to believe a 35i would be a piece of cake to maintain. |
03-26-2020, 10:55 PM | #10 |
Rep 240
I had the N54 on my 335i and it was a disaster with 2 fuel pump replacements, O2 sensors failing prematurely, and wastegates starting to get wonky. since then I've had 2 N55 engines and haven't had any issues thus far.
03-27-2020, 09:17 AM | #11 |
Rep 276
The N55 (at least on the E90 platoform) has an electric water pump that is known to fail anywhere between 60k and 120k. Mine died around 80k. Typically, when it dies, it dies, and you're stranded. It is a good idea to replace it before it fails if you can.
2014 X5 50i, M-Sport, Bootmod3 Stage 1, JB4
03-27-2020, 12:16 PM | #12 |
Rep 28
Are there any noticeable symptoms/signs when it starts going bad?
03-28-2020, 07:16 AM | #14 |
Rep 276
03-28-2020, 08:57 AM | #15 |
Rep 162
I wouldn't be overly worried about the water pump. I had one fail at 43,000 miles. The car goes into limp mode and you can safely get off the road. I drove about 10 miles. Since it can fail at 40k or 120K it's your call if you want to be proactive. I would rather wait until it fails. Other than that the other common N55 issue is a leaking oil filter housing.
03-28-2020, 09:16 AM | #16 | |
Rep 1,535
03-29-2020, 01:19 PM | #17 |
Rep 409
Get the transmission fluid , front & rear diff , transfer case fluid change done as most people don't think about getting that stuff done . Especially the transmission. ZF recommendation is to change fluid between 60-70,000 miles
03-29-2020, 03:49 PM | #18 | |
1636
Rep 2,995
03-29-2020, 04:39 PM | #20 |
Rep 1,535
I have made more reseach and found some earlier models get engine failure due to rod bearings or connecting rod issues. Is really something I should be worried about if I get into 2014 model with more than >90k miles ?
03-29-2020, 05:22 PM | #21 | |
Rep 28
Seems to happen fairly indiscriminately to older/newer MYs and high/low mileage engines. I'm sure you've read a lot of the same threads from the various message boards as well though. |
03-29-2020, 06:24 PM | #22 | |
Rep 1,535
I am not convinced the issue is related to oil filter gasket. I believe this is just purely coincident as what does oil filter gasket has to do with rod bearing issue. I also did search other websites and it mentions an issue with oil starvation when making a turn at high speed (or while revving car at higher RPMs) but of course there is not "yet" a proof to this theory |
