04-12-2021, 09:29 AM | #1 |
128
Rep 300
Unable to Reset Brake Pad Service
Hey all - I followed the Brake Pad reset procedure, but it fails to reset the service interval. Is there something else I am missing? I did not replace the brake pad wear sensor since it had not been worn through.
04-12-2021, 10:02 AM | #3 |
128
Rep 300
Tried this with the parking brake did not reset. The car is not on.
04-12-2021, 12:15 PM | #8 |
Rep 178
Replace the sensor
04-12-2021, 01:25 PM | #9 |
128
Rep 300
Alright, I'll give the sensors a try... I usually just zip tied them out of the way on my 1 series without issue, but that is a 2012.
Thanks. |
04-15-2021, 12:20 AM | #10 |
Rep 86
You might have to use Ista to reset it. Had the same issue but my break pad sensor was destroyed ( I have no idea how). When I replaced it the display only reset to 6000 miles, did it with Ista afterwards and boom 30000 miles until next replacement
04-26-2021, 01:20 PM | #12 |
Rep 97
Was your sensor worn out? I saw many ppl changed brake pad w/o replacing sensors and they don't have issue at all.
2018 X5 35i
04-26-2021, 01:29 PM | #13 |
Rep 295
Worn out or just failed due to heat/age, I would be pleased with such a simple fix.
I have reused sensors in the past, but before this thread, never considered they could cause issues if they didn't actually make contact with the disc. I've also seen the sensor cut off and the wires just twisted together which would eliminate any further sensor issues. |
04-26-2021, 02:11 PM | #14 | ||
128
Rep 300
I should have tried un-plugging and reconnecting the original sensors to see if that did the trick. I had limited time so, just threw new ones in vs experimenting. My theory is that unplugging and reconnecting the sensor must trigger something to allow a reset, probably could have saved $45 doing that oh well. |
01-17-2022, 07:18 PM | #16 |
Rep 15
Thanks! Turning off the parking brake allowed me to reset the front brake pad maintenance interval. I had already replaced the wear sensor yet it still wouldn't let me reset the maintenance light. Seems silly to me that the rear wheel parking brake influences the front brake pad maintenance indicator...but it does.
