      11-24-2019, 12:44 PM   #815
ems328i
Drives: '14 35i (F15) '14 M135i (F21)
Originally Posted by davidbcrow View Post
I've gotten the most complete breakdown I could find and still have questions about the options on the car. Seems to have a majority of the options except a few. Seems strange it's lacking a few basic upgrades like lane assist and more than the lowest of the 3 grades of stereo system.
Hear are a few pictures.
You have a Luxury Line like mine. What are the last 7 digits of your vin, then we can look up your options list?
Eibach Pro Kit & Lowering Links, RC GTS Black
2014 M135i 3dr
      11-25-2019, 08:43 AM   #816
KingBiscuit
KingBiscuit
Drives: '15 BMW X5x35i/'14 Lexus EX350
How could you tell by looking?
0K49906
      11-25-2019, 09:43 AM   #817
ems328i
You can tell by the front lower intakes:
From left to right, M Sport, Luxury Line, X Line
2014 M135i 3dr
      11-25-2019, 09:44 AM   #818
ems328i
0K49906
Online BMW VIN Decoder:
https://www.mdecoder.com/decode/0k49906
2014 M135i 3dr
      11-25-2019, 11:00 AM   #819
KingBiscuit
KingBiscuit
Thank you!!! That was actually the info I found. I'm going to check a few of them out in detail so I'm in complete understanding. One thing though... I don't think I have a steering wheel heater, or a sport steering wheel for that matter. It smaller in diameter than what I consider to be a "sport" steering wheel.
      11-25-2019, 11:04 AM   #820
ems328i
There is a Sport wheel, which you should have, vs the standard wheel which does not have the chrome look trim on it. Consider it a 'Sport look' wheel. The 3rd version is the fatter M Sport wheel, but that has an M badge on it
The button for the heated steering wheel is on the left side of the steering column near to where the steering wheel adjuster is....
2014 M135i 3dr
      11-25-2019, 11:11 AM   #821
KingBiscuit
KingBiscuit
My goodness, I DO have a heated steering wheel. And it does have Chrome on it... You're a wealth of knowledge! I may be back... Getting conflicting opinions on what a blowby heater is.
      11-25-2019, 11:21 AM   #822
ems328i
Option S4NEA? Best I could find was this from another BMW forum, but not specific to F15's:
"I believe that is the same thing they describe as "Residual Heat" in the options for the interior climate control. Basically the way it works is if you push the buttom on your dash it will open up a vent that will allow warm air from the engine compartment to flow into the vehicle for about 15 minutes after you have shut off the engine."
You also have the SoftCloseAutomatic option for the doors, my kids never get tired of that - if the door isn't fully latched, it will pull itself the rest of the way closed
2014 M135i 3dr
      11-25-2019, 12:08 PM   #823
ems328i
Originally Posted by KingBiscuit View Post
Which tire pressure monitoring system do I have and which is better?
S2VBA which is TPMS I believe, it's the better of the 2 as it measures each wheel individually with a pressure sensor in each wheel - but if you get a second set of winter wheels for example then you will need a new set of 4 sensors, they are part of the air valve.
FTM is the more basic version which, as I understand it, uses the speed sensors in each wheel and compares rotational speeds to check if there is a differential between wheels.
2014 M135i 3dr
      11-25-2019, 04:01 PM   #824
sajmani
#LetRideBeYourLife
Drives: BMW X5 50i
Originally Posted by A-4WD View Post
A lot of X5 have that USB problem including mine. Dealer apparently checked it and found nothing wrong. I'm like did the tech try plugging something into it lol? I just use the power socket with an adaptor now. Apparently it's some head unit that needs to be replaced but I don't see that as being reason enough to allow a stranger to potentially have to remove my centre console for a USB problem when I can use the adaptor instead. I'm on iOS so my phone connects automatically soon as I get in so I only use the adaptor to charge my phone or vape battery lolz.
You may as well remove the phone cradle. It doesn't fit anything larger than iPhone 4 or maybe 5. There are instructions on here how to do remove it. I did mine in like 20 mins. You'll really appreciate not having that cradle in the way.
Exactly. After being fed up of the issue and bugging the dealer again and again, he gave me the iPod connecter and the iPod to USB. This works and it is for freeeee!!!! The only freebie I'll ever get from BMW
      11-25-2019, 04:11 PM   #825
KingBiscuit
KingBiscuit
Originally Posted by sajmani View Post
Exactly. After being fed up of the issue and bugging the dealer again and again, he gave me the iPod connecter and the iPod to USB. This works https://f15.bimmerpost.com/forums/im...nim.gifperfect and it is for freeeee!!!! The only freebie I'll ever get from BMW
This link doesn't work but I can upload updates somehow without that working...
2014 X5 xDrive 35i
      11-26-2019, 12:05 PM   #826
ManImCool
Drives: F15 X5
I valeted my car the other day and later at home, noticed the valet somehow dented my steering wheel emblem. Is this a massive safety hazard which will require a costly $$$ replacement, and if so, which parts? Or is it just a cheap little piece that has to be replaced (but is still a massive safety hazard until fixed)? Or is it not a safety hazard at all?
I'll be working with the valet company either way, but I want to get an idea of what problems I'm facing.
      11-26-2019, 08:10 PM   #827
Richard Ellis
Drives: 2018 BMW 328D X-Drive
Maybe the valet thought BMW stood for Bend My Wheel. HarHar.... I know, I'm here all night folks.
      11-28-2019, 12:17 AM   #828
ManImCool
Drives: F15 X5
Um, I appreciate the post, but my question is quite serious - is this dent a serious safety hazard? As in, could this potentially be turning a life-saving device into a shrapnel bazooka? I understand the airbag deploys through that emblem hole anyway, but I am trying to determine whether this dent compromises its integrity in such a way that bad things will happen if the airbag deploys in its current state.
      11-28-2019, 07:52 PM   #829
beats
beats's Avatar
225
Drives: 2015 911 GTS
I'm pretty sure you are fine.
      11-29-2019, 09:18 AM   #830
djrabbi
djrabbi's Avatar
Drives: G05 M50i
My issue is I drive too much and waste gas
      11-29-2019, 09:20 AM   #831
djrabbi
djrabbi's Avatar
Drives: G05 M50i
Just put a sticker emblem over it and that's it. Valet isn't going to admit they did it. Let's be honest. I doubt it has any safety hazard
      11-29-2019, 03:08 PM   #832
ems328i
Haha, me too - but it's worth it. Might as well enjoy whilst we can, before ICE are banned completely
2014 M135i 3dr
      12-01-2019, 12:12 PM   #833
KingBiscuit
KingBiscuit
How was that even done?
2014 X5 xDrive 35i
      12-01-2019, 03:42 PM   #834
JDL4407
Drives: BMW X5
New to me, 2013 BMW X5. Having an issue with the hatchback opening and closing. It only opens about a third of the way, then another third, and then the final third when pressing the button. On closing it only goes part way down and the only way to close it is to apply force when it’s closing.
Anyone know how to fix this?
      12-01-2019, 04:07 PM   #835
dashti640
Drives: F06
Hi All,
i have got an issue with the BDC ECU when tried coding the headlight new ECUs the BDC stopped working as there was an issue with it before. now Terminal 15 is not available and E-sys cant read gateway the car is completely dead. do I need to replace the BDC now or what is the solution?
      12-02-2019, 09:00 PM   #836
CanadianLurker
Drives: 2018 X5 xDrive35d
No worry as the airbag doesn't actually deploy through a hole underneath the logo emblem, so the dented emblem is not going to come shooting out at you (whether dented or not).
The whole panel in the centre of the steering wheel pops open while staying attached to the steering wheel. The force of the airbag opening deploying forces the panel to open up and hinge out of the way.
The only time you might get hit by debris is from a defective Takata airbag deploying.
