      01-13-2020, 08:29 PM   #1
ed116
HUD all of a sudden too low?
Hey guys, yesterday night i noticed something strange my HUD disappeared. I came online today and noticed that some people it had gone away and come back after restarting the car ... so i go in for a drive today noticed it still wasnt there...
upon further inspection i saw it was very low --- i checked the HUD settings and it was on max height and i could see it if i lean my head forward and its all the way at the bottom. anyidea on what could have happened? car is a 2015 f15 with about 108,000 km
uploaded pics .. anyway to reset HUD? re calibrate it?
      01-13-2020, 08:35 PM   #2
PnP
PnP's Avatar
Laos
207
Drives: 2014 X5 30d
I had the same problem before. After inspection, the voltage from the battery is lower than 12.2 volts and they replaced the battery. Problem is gone for good now.
Hope this helps.
      01-13-2020, 08:38 PM   #3
ed116
cool my car is out of warranty --- should i replace the battery at the dealer?
      01-13-2020, 08:43 PM   #4
PnP
PnP's Avatar
Laos
207
Drives: 2014 X5 30d
Mine was out of warranty too, but I still went to the dealer to get it replaced, but if you have an indy shop that you trust, you could also go that route and save some $$$
      01-13-2020, 08:52 PM   #5
ed116
roughly how much did it cost you at the dealer?
      01-13-2020, 11:45 PM   #6
RED_Y_
Drives: 2014 X5 3.5d
One person got it fixed by removing fuses for couple of minutes
https://f15.bimmerpost.com/forums/sh...1489340&page=2
You can give it a shot, doesn't cost you anything.
Battery replacement varies from dealer to dealer but usually it is around $400
But you can DIY
https://f15.bimmerpost.com/forums/sh....php?t=1626793
      01-14-2020, 01:27 AM   #7
PnP
PnP's Avatar
Laos
207
Drives: 2014 X5 30d
about $700 but that's the price you pay when living in Asia with these types of car
But you can DIY
I also tried the fuse method and it worked for only a day or two, then the same problem again so hence the diagnose and a new battery.
      01-16-2020, 09:12 PM   #8
ed116
slight update: got a quote from bmw they wanted between $790-$990 cad for a battery replacement 2 hours labor? ... called a local indy shop as recommended by BMWTN and got a quote at $360 for parts and labor
      01-17-2020, 06:57 AM   #9
SupersixM
SupersixM's Avatar
202
Drives: Bmw X6M
$790 - $360 = Attempted Robbery 2nd
Violator4587.50
Russmov1328.00
      01-17-2020, 08:04 AM   #10
Russmov
Russmov's Avatar
2015 BMW X5  [0.00]
Lmfao that dealership is the definition of stealership. Whichever dealer that is, stay away.
2016 BMW X4 xDrive 28i-Sold
2014 Lincoln MKX-Sold
      01-17-2020, 07:16 PM   #11
ed116
it was marnello bmw lol ... i called RMP Motors he seems good said hed use the OEM battery and code it all in $360 CAD
edit: so i just took out the fuses and ... 50 + 52 for about 3-4 minutes ... popped em in turned on the car ... and the HUD was back up and running thank god!
      01-20-2020, 05:57 PM   #12
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
But you can DIY
Did you post the correct thread for the DIY? The link in this thread the person took their x5 somewhere to have the battery replaced.
Is there anything required other than removing the old battery & putting in the new? Ie I’m hoping there is not anything the dealer has to do to tell the car the battery has been swapped out. I seem to recall the e90 folks required an extra step other than just replacing the battery. I had my f30 for 5+ years but never had to do anything with the battery.
      01-21-2020, 12:17 AM   #13
RED_Y_
Well that is not exactly step by step DIY thread but long story short you can buy new battery from Batteries Plus Bulbs or other retailer and replace it. You will also need to register the battery so it charges properly, you will need ISTA and the Enet cable or some other scanners (like described in the linked thread) also can help you with coding new battery.
      01-21-2020, 07:48 AM   #14
ed116
try removing the fuses first if HUD is your main concern. my battery shows no signs of dying (starts up no problems) im not sure why the fuse pulling fixed my issue ... could have been a caching issue on the computer
      01-21-2020, 08:25 AM   #15
Carpe_BM
Drives: EX-BMW (2019 BMW X5 xDrive40i)
Mine has been playing froggy for a bit where it actually shifts from time to time as to where it's projected on the windshield. I have to keep messing with the rotation and height. Took it to the dealer who said it's normal sometimes but SA and I are not happy with the response so took it back to the dealer for that issue again along with it intermittently fading in and out
Let's see what they can do this time...
      01-21-2020, 01:20 PM   #16
ed116
did you try to pull the fuses? might fix your issues
      01-21-2020, 02:51 PM   #17
Carpe_BM
Car is currently at the dealership so I can't but I will suggest that to the SA in case he is overridden by the foreman to say nothing is wrong.
      10-01-2023, 09:11 PM   #18
echothreezero
Drives: BMW F15 X5 M50d
Happened to me this morning. Pulled the fuses (50 &52) and it has reset and is fine. For now at least. I'll report back if it happens again.
Anyone know if there is a way to perform the reset using protool?
The reason I ask is that my car is RHD and access to the fuse box involves removing 2x panels below the steering wheel with a 10mm socket and a torx screwdriver. Rather than the 3x plastic tulhumbturns on the panel under the glovebox as on LHD cars.
