      04-01-2019, 11:14 AM   #617
Rydogg21
Drives: BMW X5 35D
Originally Posted by KillFox91 View Post
Well today was Install day!
Wow these things are huge...
Fronts went smooth as can be. The brakenetic rotors fit perfect and have the holes for the brake rotor retainer Allen head bolt. These brembos are giant!
Rears got a little complicated. I don't know if it's a 35i thing ; but my backing plates needed to be replaced. The existing ones are too small and had to be modified (for now) to accommodate the larger rotor. They would have rubbed and would have had to be bent back to accommodate the rotor sitting properly. I did not realize this before the project; so we ground down the lip on the backing plate for now. I will revisit this at a later time when the new ones come in.
The X5m brake calipers are the same size as the 35i ; but the pad is significantly more pronounced; it has more of a bite than the 35i. The bracket mounts directly like the old bracket but accommodates the larger rotor perfectly. Again, the retainer screws worked in the rear rotors too; using your existing screw. This was perfect on the front and rear; which was nice to be able to secure the rotor with the existing bolts and not have to fight them getting everything installed.
I painted my rears black to match the front brembos.
I pushed a liter and a half of fresh fluid through the system and got a really good bleed on the system. Pedal feels good; but seems a little weaker. I will go to the dealer next week and get them coded so this will stiffen up.
Did a spark plug and coil tune up at the same time; what a giant pain in the butt getting to the last three plugs... you have to remove quite a bit of stuff to get at them. Make sure you get your thin walled 14pt socket also; it's the only way to get the plugs out!
Can't wait to get my 599 wheels on in a couple weeks to better show these puppies off!
The brembos swallow up 99.9% of my stock 19 inch wheels; clearance is mere millimeters in most spots!
Do you mind posting a final picture with your 19"s? Just curious how it looks.
      04-01-2019, 04:58 PM   #618
KillFox91
KillFox91's Avatar
83
Drives: 2014 BMW X35i
Forgive the extremely dirty car; just got back from a long trip and haven't had time to give her a proper bath!
Appreciate 4
maDjzo861.50
82Nate7.00
      04-09-2019, 04:23 PM   #619
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
To those who bought a new complete M-sport Kit, what brake lines did you get with the kit, if any?
Were you able to use the OE brake lines with the calipers?
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      04-09-2019, 06:58 PM   #620
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Yes you can use oem brake lines. All brake lines are the same. Just differ in length. I got SS ones but it's not necessary by any means. For me it's just as easy to replace with it all being apart anyway.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
CHECKERED123.50
      04-11-2019, 12:21 PM   #621
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Oh ya forgot to add I got em from ECS
'06 C55 AMG (sold)
      04-11-2019, 12:38 PM   #622
CHECKERED
ex deus machina
CHECKERED's Avatar
The SS lines you got are from ECS, or did the brake kit from ECS come with lines?
      04-11-2019, 12:39 PM   #623
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Brake kit is from eBay. I bought ECS branded lines.
'06 C55 AMG (sold)
      04-23-2019, 03:10 PM   #624
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
Got a little side tracked with work but today is the day. [IMG][/IMG]
Appreciate 4
      04-28-2019, 11:50 AM   #625
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
Stopping power is just so aggressive. Happy with the results.
Appreciate 4
      04-28-2019, 12:33 PM   #626
cfm56d7b
Drives: 2017 440i Gran Coupe & 2015 X5
Great thread. This will be the next project.
iconoclast7265.50
      08-17-2019, 04:11 PM   #627
giustyle
Drives: Bmw F15 Msport 30D
Hi, I did found caliper (front + rear) from bmw X70 M for my F15 30d.
I will buy the rotors, do any of you know them?
Brake Disc ZIMMERMANN SPORT BRAKE DISC COAT ZCoated, High-carbon, Internally Vented, Perforated, Front Axle Right
Article №: 150.2948.52
Coated, High-carbon, Internally Vented, Perforated, Rear Axle
Article №: 150.2945.52
Also I need 2 bolt for front rotors, do i need anything else?
Thanks a lot.
      08-17-2019, 06:17 PM   #628
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks a lot.
Hmm didn't think Zimmerman makes rotors for the MP calipers. May want to double check that. The oem rotors are on the first page. And you don't need new screws as the ones on your car will work just fine on the new rotor hats.
'06 C55 AMG (sold)
      08-18-2019, 02:57 AM   #629
giustyle
Why other users needs a new screw to bolt the rotor to the hub (bmw part number 34211161806) ?
This is a rotors (the price is very low):
Front
https://m.onlinecarparts.co.uk/zimmermann-9009317.html
Rear
https://m.onlinecarparts.co.uk/zimmermann-9009310.html
Thanks for the help.
      08-18-2019, 03:51 AM   #630
giustyle
Can anyone recommend a paint for the original color of the Caliper (I think it is B05 blue monaco) and the related sticker // M?
ps. this is my f15
[IMG][/IMG]
[IMG][/IMG]
      08-18-2019, 07:46 AM   #631
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
IIRC the paint code is Monte Carlo Blue B05.
      08-18-2019, 12:33 PM   #632
giustyle
Yes Montecarlo
      08-19-2019, 08:49 AM   #633
giustyle
Sorry but I means bolt of front rotors (not rear). The bolts that I need are this?
Bmw 34111123072
      08-28-2019, 04:36 AM   #634
giustyle
Hi, i found this brakes kit (it was a X5M E70). It completed with rotors and pads (but I will order new rotors Zimmerman with hole and NEW pads)
The pad is better new?
The price for the kit 700 euro, is a good price?
Now I clean caliber and in the next day I will paint with blue Msport colour 😉.
Thank and I’m sorry to my English
upload photo sharing
      08-28-2019, 04:47 AM   #635
1230vani
1230vani's Avatar
653
Drives: G05 40i LCI
In my opinion I would get new pads as the old ones may squeak. I got mine in 2018 and they're squeak free. Perhaps E70 pads you bought are also squeak free. 700 eur for me sounds like a good deal
      08-28-2019, 05:43 AM   #636
giustyle
With other 700 euro i bought Rotors and Pads (System zimmermann Low dust brake pads)
1230vani652.50
      09-07-2019, 12:25 AM   #637
giustyle
The protection plates are different with my original brakes system (30d).
For the Front brakes, can I modified the actual plates or I should buy new plates?
      09-09-2019, 08:47 AM   #638
djrabbi
djrabbi's Avatar
Drives: G05 M50i
the original post has rotor price but I assume they have gone up? Can anyone confirm, which rotors are they using?
