      02-27-2019, 06:45 AM   #573
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Originally Posted by Mr.47 View Post
Acronym for
To
Long
Didn't
Read
Oh, not even coding related. Even better.
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      02-27-2019, 07:55 AM   #574
BimmerTy
///M
BimmerTy's Avatar
Drives: 2015 F15 X5 50i M Sport
When coding a BMW the thought of bricking a module due to me screwing up a process sends my anxiety thru the roof, so is good to be thorough just to be safe. When I read Alan L. coding guide, which was simple, i was totally lost lol!
Acronym for
To
Long
Didn't
Read
Acronym for
Too**
Long
Didn't
Read
2015 F15 X5 xDrive50i - M Sport - Space Grey Metallic - 21" 612M - Accelera Iota ST68's - Black Dakota - Leather Dash - Poplar Wood - Ceramic - Shawdowline - Anthracite - Adaptive M - Full LED - Executive - DA+ - Surround - HUD - Enhanced BT - Soft Close - B&O - ACC Stop & Go - Multi Contour - 4 Zone Climate - Comfort Seats - Cold Weather - Muffler Delete - Akrapovic Tips - F85 Grille - 35% Tint - BMW All Weather Mats -- Missing DHP, NV, Active Steering, Rear Entertainment, & Cooled Seats
      02-27-2019, 09:20 AM   #575
classic_erik
classic_erik's Avatar
Drives: 23' X7 40i M Sport
So my attempt to upgrade my F15 to the MPBK with F85 rotors continues to take shape.
My local dealership just came back to me stating that the F85 rear rotors would not be plug and play with the F15 out of the box without some machining work. Can anyone comment?
"The rotors for the F85 will fit the front of your vehicle but the rear will not. You would have to machine a hole in them for the rotor bolt and it also depends on what rear end you have in the vehicle. A standard diff ro what they would call QMVH."
      02-27-2019, 09:39 AM   #576
yewlock
yewlock's Avatar
Drives: X5
It is true.
      02-27-2019, 10:50 AM   #577
KillFox91
KillFox91's Avatar
83
Drives: 2014 BMW X35i
It is true.
True if you want the rotor to be attached to the vehicle by a screw. This is not necessarily required as most other automobile manufacturers do not attach rotors to the hub via a small screw like BMW. The wheel and lug bolts will keep the rotor centric and snug. IMO it's just for ease of use that they do this in the first place.
      02-27-2019, 09:24 PM   #578
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
It is true.
What he said.
'06 C55 AMG (sold)
'14 X5 50i (wife’s now)
      02-28-2019, 09:35 AM   #579
classic_erik
So are most people here opting to machine the additional rear screw hole or just bypassing and relying on the lug bolts?
Anyone have a picture of this bolt?
      02-28-2019, 09:45 AM   #580
pits200
Drives: 09 335i X-Drive Black Sapphire
It's not only the lug bolts, caliper housing/brakes will also keep it mostly square without the set screw.
It really isn't a big deal but you'll want to ensure when you put the tire on that you use a star pattern on the rotor doesn't get slightly angled especially being we don't have studs, this is more likely to happen.
      02-28-2019, 10:53 AM   #581
KillFox91
KillFox91's Avatar
83
It's literally like a 10mm bolt with an Allen head about 1 cm in length. It is there purely to hold the rotor in place while you reattach all your brake components.
As pits said; the brake components, lug bolts, and wheel all hold the rotor in place and the bolt holds almost zero value in the way of importance. IMO it would be a waste of money to machine a hole.
      03-03-2019, 08:41 AM   #582
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Just heard back from Tronic today. Apparently it's no longer the panamera rear caliper they use for the 4 pot fixed upgrade. It's a VW Touareg because it's cheaper. But the price hasn't changed sooo lol.
'06 C55 AMG (sold)
      03-03-2019, 10:15 AM   #583
HydroStream6
Drives: F15 X5 50i M-Sport
Any updates on rotor options? The only budget front rotor option I'm seeing is the Brakecentric.
Thanks!
      03-03-2019, 03:00 PM   #584
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks!
That's it man. It's sucks cuz others make em for the M5. You'd think someone would give this is 2 generations in a row with the same size rotors. Seems like a good market.
'06 C55 AMG (sold)
      03-03-2019, 05:11 PM   #585
pits200
Freeman makes the fronts and that's what I have on my x5. I'll be honest, I'm too lazy to look up the model rotors but they were like 150 each. They aren't slotted or drilled but the performance is fine.
      03-06-2019, 05:46 AM   #586
HydroStream6
Can anyone confirm what is needed for the rear brake conversion? Is it simply ordering the larger 385mm rotors and then moving th ecaliper out? NO bracket change needed?
My Brembo front calipers and 395mm rotors are on the way, so just need to get the rears figured out and then figure out what pads! Wish I could find more info on those Power Stop Z23s. I want something with some bite but little dust (best of both worlds, haha).
Thanks!
Adam
      03-06-2019, 11:56 AM   #587
mikew2069
mikew2069's Avatar
413
Thanks!
Adam
You need new rear brackets.
BM3/H&R/Borla
      03-07-2019, 08:34 AM   #588
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks!
Adam
Curious why you would think this? This thread is pretty thorough as to what is needed. Recommend starting at page 1. It has all the info there.
Now technically while the 50i caliper could fit on the 385mm rotor it would require spacers to lift the caliper up from the hub. But the 35i is not even an option. The braking surface is the same on the two size rotors. The M rotor just sits further from the hub. The piston is also larger on the 50i compared to the M caliper. Again all stated in this thread.
Honestly I wouldn't even waste the money on changing the rear caliper and rotor. Unless you go with an upgraded caliper such as a fixed 4pot brembo.
'06 C55 AMG (sold)
      03-07-2019, 08:57 AM   #589
pits200
I always wondered why the front was so much more important than the rear. Besides the asthetics of the brembos in front, going from the 50i 365mm fronts to 395 gains you 30mm in surface area. Ya, I know going to a 4 pot helps but that's more for feel and fade than braking power. The rear going from 345mm to 385 technically nets you more surface area albeit with a single pot but you could argue that the gains are still decent and not inconsequential.
Also, I think BMW biases their brakes to the rear more than a lot of other companies based on how evenly the front and rear pads wear. And I get that rear pads can wear more due to e-diff functionality.
OH well, just my two cents on the rears being important from a functional perspective despite the unsightly single pot calipers.
      03-07-2019, 11:42 AM   #590
HydroStream6
OP had posted earlier in this thread that the rears may not require a new bracket, hence the question.
Ordered stock size stuff for the rear. All in, I'm at about $1050 for used front calipers, new front rotors, new rear stock rotors, new Power Stop Z23 pads all around, new wear sensors. Not bad!!
Maverik2594140.00
      03-07-2019, 07:09 PM   #591
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Didn't go oem rotors I take it.
'06 C55 AMG (sold)
      03-07-2019, 07:40 PM   #592
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
My rotors are in..drill patterns are the same for F10/F85 but you get an extra drill with the massive 400 front
Fronts: 400x36
Rears: 385x24
      03-07-2019, 09:27 PM   #593
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Fronts: 400x36
Rears: 385x24
Nice. Although the F85 has 4 holes as well. I mean the F10 is only 2.5mm wider in braking surface. Really confusing why they even bothered with manufacturing costs for such a small difference to be honest.
'06 C55 AMG (sold)
pits200546.50
      03-08-2019, 06:45 AM   #594
fr_tz
fr_tz's Avatar
Drives: F90/G05 50e
2024 G05 50e  [9.50]
Fronts: 400x36
Rears: 385x24
Didn't notice you get 4 holes with the F85 fronts. Anywho, remember not only are the F10 fronts larger in diameter they're also 7 pounds lighter each than the 395s.
