03-14-2021, 10:31 PM | #1 |
Rep 1,353
17+ F85/86 + G series HKFM2 Trunk Soft Close
Hey there,
I have read everywhere that it is not possible to do the soft close on newer version trunk module. I digged in the situation and there is way to do alot smoother. Not the level of Feather Drop but i gained significant improvement over stock version. I would like to share here with the family so you can also test and share your opinion. If you need help i can do remotely. Here is what parameters to look for and change : ProfileCloseStopNode1PwmPlg: UNKNOWN [00 A0] ProfileCloseStopNode2PwmPlg: UNKNOWN [00 A0] ProfileCloseStopNode1PosPlg: wert00A0 [00 A0] ProfileCloseStopNode2PosPlg: UNKNOWN [00 A0] Let me know! Credit : Kuno24
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit Last edited by SaNGRia; 02-01-2022 at 05:58 PM.. |
03-15-2021, 11:48 AM | #3 |
Rep 1,353
Did you try 20 30 40 58 58 58 58 58 58?
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
03-15-2021, 06:04 PM | #5 | |
Rep 1,353
Please use the appreciate button if you like my solution
