11-30-2019, 05:09 PM | #5061 | |
Rep 7,468
Again, if you have the app and adapter, just simply connect to the adapter and go to whichever of those modules you have...then scroll down to find it. On my 2013 F06, this codeable feature was found in the FEM...and didn't require going into EXPERT MODE...it was one of the easy selectable coding features. The app asks if you want the fogs off with high beam...if the answer for you is yes...then you select ACTIVE. If you answer no (I don't want the fogs off with high beams)...meaning that you want the fogs to remain ON with the high beams...then you change the coding to NOT ACTIVE.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-30-2019 at 05:31 PM.. |
12-05-2019, 08:18 AM | #5062 | |
Rep 1,354
Drives: 2022 X5 m50i
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
12-05-2019, 08:23 AM | #5063 | ||
Rep 176
Under BDC_BODY you should look for Mapping_..._Part_WL Let me know if you find that. You can PM me your BDC_BODY ncd file and I will find it for you. |
hufington3119.50 |
12-05-2019, 10:31 AM | #5064 |
Rep 1,354
Thanks. I will check in the afternoon.
2022 BMW X5 m50i
12-05-2019, 04:30 PM | #5065 |
Rep 1,354
I looked under BDC-Body and no such parameter... I guess cannot be coded with Bimmercode.
2022 BMW X5 m50i
12-05-2019, 04:57 PM | #5066 |
Rep 176
12-05-2019, 05:51 PM | #5067 | |
Rep 1,354
Where do I find the ncd file?
2022 BMW X5 m50i
12-05-2019, 06:21 PM | #5068 | ||
Rep 176
You can't do it for a 2018 x5 The ncd files are in c:\data\caf\ So you will see all the ncd files there and it depends on the ecu module you will select the ncd file. |
12-05-2019, 06:44 PM | #5069 |
Rep 1,354
Oh well. Thanks anyways. 2018 does not let you do many things I guess. I really miss the welcome home and adaptive headlights from my '16 550. Both have the same BMW Adaptive LEDs but 550 was offering more features.
2022 BMW X5 m50i
12-19-2019, 05:24 PM | #5071 |
2136
Rep 1,834
Drives: Many, BMW.
Does anyone know if Anti-Dazzle can be coded via Bimmercode?
12-19-2019, 05:51 PM | #5072 |
Rep 289
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
12-19-2019, 05:53 PM | #5073 | |
2136
Rep 1,834
Drives: Many, BMW.
12-19-2019, 11:08 PM | #5075 |
Rep 165
BMW Coding Thread
Can I code Sport plus on a luxury line using bimmercode? I read in this thread you could do it with E-Sys but I don't have that program, I only have Bimmercode expert.
12-20-2019, 08:46 AM | #5076 |
Rep 14
2014 X5 ambient lighting
I hope this belongs here.....
I recently deleted all profiles on iDrive and reset my preferences. I also made a few code changes to iDrive including video in motion. When I was finished I noticed the ambient lighting (orange/white/blue) and footwell lights werent on when the headlights were turned on and dark outside. They had been working fine until the coding changes and profile deletions. I did make sure they were set to be on with medium brightness in iDrive. Nothing in the coding I changed indicated anything about interior lighting or ambient lighting. Is it possible a fuse blown randomly that controls ambient and footwell lighting? Coded using Carly for BMW xDrive 3.5i US Model 2014 |
12-20-2019, 12:22 PM | #5077 | |
Rep 1,179
12-20-2019, 07:57 PM | #5078 |
Rep 14
01-20-2020, 03:59 PM | #5079 |
658
Rep 345
Hey anyone do coding in ny? I just want to disable the steering wheel from going up and down being tjat i just paid 1500 for a new steering column, thanks
01-20-2020, 04:56 PM | #5080 |
Rep 71
Are you talking about the steering wheel retracting when you exit/enter the vehicle? If so, I did it on mine and can help you out (free of charge). I’m located in Brooklyn. PM me.
Teufelshund152.50 |
01-25-2020, 01:20 PM | #5081 |
Rep 159
Need assist with trailer module activation
(2014 X5 3.5)
I have the latest version of ISTA+ (I am no expert by any stretch). I followed the OEM instructions for installing the hitch and module. All wiring is complete. I now have the activate the the AHM module. Can someone please provide a step by step or provide a link to an existing step by step. Any help is greatly appreciated. |
01-25-2020, 01:50 PM | #5082 | |
Rep 40,733
3AC Trailer Coupling for the electrically foldable model. Add 3AC to FA and VO Code HU_NBT and AHM. 235 Towing hitch, detachable is the detachable model. Add 235 to FA and VO Code HU_NBT and AHM. If not supported by FA (like Invisihitch), then use HO-Wort K235 Trailer Tow Hitch Removable instead.
