07-05-2018, 10:59 AM | #1 |
N00B
94
Rep 210
N63T Broken Hose!
Hi all!
I heard a whistling sound this morning when I started the X5 up and checked the ECU via torque and there were no errors. I checked the engine bay area and found the following hose broken. Can anyone identify it so I can replace it? Can the car be driven, can duct tape provide a temporary fix? Thanks
The owls are not what they seem!
07-05-2018, 12:15 PM | #3 |
Rep 2,388
Yes here's Maverick's post that he warned us about that hose (part# 11158647298) and advised to replace it: http://f15.bimmerpost.com/forums/sho...2&postcount=16
It's $110 from here: https://parts.bmwofsouthatlanta.com/...158647298.html As a temporary fix you can use a sturdy duct tape, while you are waiting for a replacement part. P.S. Not my business, but I almost had a seizure when I saw N63T. Already second post I'm seeing this. I initially thought it's some kind of a Euro spec engine version of our N63TU lol. Last edited by DuSh; 07-05-2018 at 12:23 PM.. |
07-05-2018, 12:49 PM | #4 |
Rep 7,160
Haha yep. Exactly what was broke on mine. See my post for all the info you need. Much cheaper if you order from a wholesale dealer than local dealer. Either way they're gonna have to order it most like and duct tape or better I would recommend electrical tape due to its playability and ability stretch. But be careful cuz it's very brittle stuff and will break again. Mine broke just by putting my hand under it to clean up the spilled oil.
07-05-2018, 12:52 PM | #5 |
Rep 844
07-05-2018, 06:36 PM | #8 |
N00B
94
Rep 210
Great stuff guys, thanks for the links! Does anyone know if I could wrap the new hose in heat tape to prevent it from turning to dust again?
Correction: I'll pick this one up from ECS tuning... its wrapped in rubber. https://www.ecstuning.com/b-genuine-...e/11158647298/
07-05-2018, 06:46 PM | #9 | ||
Rep 674
I would also like to know what can I warp it with to prevent cracking in the future? |
07-06-2018, 11:43 AM | #10 | |||
N00B
94
Rep 210
07-06-2018, 12:17 PM | #11 | ||||
Rep 674
Luckily my n55 crank case vent hose came quite cheap at $33.. best of luck with your car. |
07-06-2018, 12:57 PM | #12 | |
Rep 177
07-06-2018, 05:16 PM | #13 | |
482
Rep 317
My 2014 740li with N55 had the same problem the crankcase hose snapped off after when replacing my spark plug, i used heat shrink wrap and it was fixed. |
07-06-2018, 05:59 PM | #14 |
Rep 2,388
Yeah, that hose is made from hard thin plastic and is right above turbos. Cats heating up to 1700F are just couple inches below this hose. If it was made from thick rubber - then it would have lasted for almost eternity.
07-06-2018, 10:27 PM | #15 | |
Rep 7,160
BMW.
07-07-2018, 10:33 AM | #17 |
Rep 7,160
Looks good. Lucky you!
07-25-2018, 09:48 PM | #18 | ||||
N00B
94
Rep 210
DuSh2113.50 |
07-25-2018, 11:06 PM | #19 |
Rep 7,160
Glad to see they replaced both hose assemblies. Especially since the smaller one is about $300 for the part alone.
Did you tape yours back up and drive to the dealer? That's the only thing I was afraid of and opted to just eat the cost of the cheaper hose and I put in myself vice dealing with my extended warranty
07-26-2018, 11:23 AM | #20 | |
N00B
94
Rep 210
07-28-2018, 07:33 AM | #21 | |
78
Rep 360
2010 335i Rwd 6spd
MHD Wedge tune, VRSF Exhaust,FMIC, DP and CP, PR Inlets 2014 X5 50i BMS stage 1, Dinan intake, F85 Knee Bolsters |
07-28-2018, 11:20 AM | #22 | ||
Rep 7,160
