09-01-2019, 01:34 PM | #1 |
Rep 423
'16 50i - last visit to dealer before warranty expires. What should I ask for?
My warranty expires in a few weeks and I am taking my 2016 X5 50i in for an oil change and a version of a PPI - but lets call it a pre end of warranty inspection. Have a great Service writer - that will address anything that needs attention. Things that I have read here that go wrong with this X5 are Air Bags, Control arms (already replaced), and crankcase breather (which I think is not an issue for '16's). Anything else to replace proactively of a 16 50i??Plugs? 47k miles now.
Thanks!
2023 330e, 2016 X5 50i Msport (SOLD), 2011 E90 M3 (SOLD),
BMCCA, F1 fan (Montreal every year) |
09-01-2019, 03:59 PM | #3 |
Rep 264
Here are a few things I brought up before my manufacturer warranty expired, even if working correctly. The more you can list the better.
Steering Column noise iDrive knob binding Power Seats function Power Locks Gasket/Seal (Oil pan/Transmission) Coil Packs Sun Roof function
2015 F15 XDrive 50i MSport
09-01-2019, 05:48 PM | #4 |
Rep 11,147
Definitely mention the panoramic sunroof. Although they functioned fine on both my 2011 and 2015 X5s, the cassette needed to be replaced on both.
09-02-2019, 09:03 AM | #6 |
1152
Rep 2,426
Check for oil leaks. Rear main seal, upper oil pan, transfer case.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
09-02-2019, 09:12 AM | #7 |
Rep 299
My engine went out less than a year after warranty. I didn't see the warning signs at the time but if yours hesitates (may or may not misfire) or has more carbon from the exhaust than usual then I would have them check cylinder compression. This is a sign of a cylinder leak and eventual failure.
As above, check for ANY oil leak. And finally cross your fingers and hope for the best. |
09-02-2019, 02:25 PM | #8 | |
Rep 1,434
2022 x5 m50i - Dravit grey
09-02-2019, 03:09 PM | #9 | |
Rep 299
BMW agreed to cover 75% Goodwill at their replacement costs. What ended up being a $25k repair came to just $3200 for me out of pocket. They used a brand new long block. |
CT335xi684.00 |
09-02-2019, 06:35 PM | #10 | |
Rep 1,434
09-02-2019, 09:07 PM | #11 | |
Rep 423
09-02-2019, 09:10 PM | #12 |
Rep 423
Thanks for the tip on the sunroof - it works with no issues currently.
09-03-2019, 03:05 PM | #13 | |
Rep 1,434
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport Last edited by CT335xi; 09-05-2019 at 07:44 PM.. |
09-07-2019, 04:01 AM | #15 |
Rep 536
