05-24-2021, 11:01 AM | #1 |
Rep 2
F15 X5 optional tire size 255/55/19
Hi everyone
Looking for some advice for my 2015 X5 x35i Stock tire size is 255/50/19 but wondering if I can safely do 255/55/19 instead? Last edited by BMWtorontoowner; 05-24-2021 at 01:32 PM.. |
05-24-2021, 02:46 PM | #3 | |
Rep 5,025
In the back I don't see why it would not work. |
05-24-2021, 03:34 PM | #4 | |
Rep 7,588
05-24-2021, 06:09 PM | #5 |
Rep 2
thanks for the tips. The website says there is only a 3% margin of error but i guess it technically doesn't say whether it can work or not. I will just have to measure and see. I got some free winter tires from a friend so its worth exploring.
05-24-2021, 08:36 PM | #6 |
Rep 104
You might also check https://www.rimsntires.com/specspro.jsp. It's still just an estimate. Your actual results may very.
05-25-2021, 01:15 PM | #7 | |
Rep 2,529
https://f15.bimmerpost.com/forums/sh....php?t=1210115 New transfer case might cost you way more. |
05-25-2021, 01:45 PM | #8 |
Rep 818
Drives: BMW X5 XDrive35i
255/55/19 should fit. The guy I bought my 20s from was running a Falken Wildpeak AT in that size on his. It'll clear the control arms from what I know.
12-20-2022, 01:15 PM | #9 |
Rep 1
Tire Size 255/55R19
I have the regular 255/50R19 tires on my X5 and I would like to put on some snow tires for an upcoming trip. I will use the tires only for few months and I dont want to buy the latest tires.
TireRack has the 255/55R19 on sale. Its an inch bigger on diameter, which translates to half an inch of clearance needed. Does anyone know if the 2015 X5 can handle the extra tire diameter? I plan on replacing all four to keep the travel the same and i dont mind the speedometer inaccuracy. Thanks for any advise. |
12-20-2022, 01:27 PM | #10 |
Rep 818
as far as I'm aware you shouldn't have any issues with clearance on a 255/55/19 tire.
