01-14-2019, 10:55 AM | #1 |
Rep 489
Drives: E39 M5/ E30 325is
X6M receiving some special treatment from Bimmer Performance Center
01-16-2019, 02:05 PM | #2 |
Rep 3,151
Looks great. Needs to be lowered a bit though. What wrap did you guys use on the DPs?
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
01-16-2019, 02:23 PM | #3 |
Rep 489
The X6M's and the X5M's look awesome lowered. This one could definitely use some lowering springs or coil overs.
I'm not sure on the brand but I know we use a titanium wrap so that it can hold up to the extreme heat and not flake off like traditional header wrap. The wrap isn't just for looks or reduce the heat under the hood it also helps reduce damage to the rear cylinders. We see that the aftermarket downpipes get too hot at times. This excessive heat can affect the rear cylinders creating issues. The stock downpipes are double walled which reduce heat transfer from the factory. |
0-60Motorsports790.50 |
01-17-2019, 06:03 PM | #4 |
Rep 736
Which downpipes did you guys use? Any problems after dp instal along with the flash? I'm having issues with catless dp and DME tune
www.mgruppe.org
01-17-2019, 10:48 PM | #5 |
568
Rep 380
01-18-2019, 07:33 AM | #6 |
Rep 489
I believe these were VRSF downpipes.
We haven't had an issue with our tunes and downpipes. We've tuned quite a few S63 powered vehicles with downpipes and so far everyone has been thoroughly pleased with the end results. |
01-19-2019, 12:53 PM | #7 |
Rep 736
So I have active downpipes and dme tune, having an issue when starting my X5m, rpm would fluctuate and stall
www.mgruppe.org
01-24-2019, 09:44 AM | #8 |
Rep 944
Heard this was common with catless and time. Running hfc dp and bm3 tune. Haven’t stalled once
My m4 with stock Downpipe’s runs into the stall issue sometimes. Kind of weird |
01-24-2019, 11:33 AM | #9 | |
Rep 736
www.mgruppe.org
