      05-22-2018, 11:58 AM   #23
Florida-X3
Drives: '24 X3 x30i / '12 Infiniti M37
Originally Posted by CaboM4 View Post
Again ... for those with the issue described by the OP ... confirm the APIX settings in your NBT2 with ESYS or BimmerCode App to see if you received an OTA software update that has incorrectly changed these settings, thus causing the "No Signal" behavior of the CID
Thank you for the info, the correct settings are?
      05-22-2018, 01:40 PM   #24
puckybadger
Non-issue
      05-22-2018, 07:57 PM   #25
CaboM4
BMW Aficionado
1363
Drives: 23 i7,23 iX,24 Silverado
For the adults in the room:
CID_Touch --> aktiv
CID_APIX_MODE --> apix2
CID_COLOR_DEPTH --> 24
CID_COM_MODE --> mii
CID_DISPLAY_RES --> 1440_540
CID_DISPLAY_SIZE --> 10_25
      05-22-2018, 10:38 PM   #26
Florida-X3
CID_Touch --> aktiv
Thank you!
      02-22-2019, 10:27 PM   #27
turboawd
1636
Drives: 2015 X5 35i
Originally Posted by Florida-X5 View Post
This happened to me last night, didn't take 10 minutes to reboot. The "No Signal" message lasted about a minute or two, then went blank and signs of a reboot started about a minute later.
This just happened to me tonight. I was sitting in car for a while, engine off, stereo on. Started the car to leave then shortly after i got the no signal. A minute later idrive rebooted. Weird.
      02-22-2019, 11:24 PM   #28
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
CID_Touch --> aktiv
This has happened to me a few times. I'll check my settings 😜
HJ478.00
      02-23-2019, 01:53 AM   #29
alphaod
alphaod's Avatar
This happened to my iDrive a couple times. Last time while under warranty the dealer saw it so I got a replacement head unit. Never happened again.
I also had the older iDrive with USB problems that got resolved with a replacement unit.
2015 BMW X5 xDrive50i
BMW CCA 509766
HJ478.00
      02-23-2019, 01:19 PM   #30
jch1511
Drives: 50i,750i,650i,GL63
Yes, this is the only solution to the idrive crash problem, see my post above.
Don't let dealer feed you other BS, insist they replace the idrive if you are still under warranty, it's a known issue. Otherwise, it will happen more frequently.
HJ478.00
      02-23-2019, 01:22 PM   #31
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
You might be right, but my experience is different. I got that error couple times a year ago, but since then nothing - it's working perfectly. And I know for sure it was a low voltage issue as I had different battery at that time. Of course my single experience is not statistics.
HJ478.00
      02-23-2019, 01:48 PM   #32
turboawd
1636
Drives: 2015 X5 35i
This could be a possibility. I have a 14 with original batteries and I was sitting in car for a while beforehand with stereo on engine off.
Reading on other bmw forums with same no signal issue, they say bmw does a istep update to fix the issue. What is that?
HJ478.00
      02-23-2019, 02:19 PM   #33
jch1511
That makes sense because the HUD gets the data from idrive.
My issue was not the battery since mine was new and X5 was also hooked up to dealer power supply when they were trouble shooting.
It has been a year since they replaced the idrive, works flawlessly now.
