07-13-2019, 12:56 PM | #1 |
Rep 607
Soft Close Door Repair How To
Has anyone had to replace the motor in the soft close door? Mine is no longer working on the drivers side door. I can hear it trying to close the door, but it's not engaging.
2017 F86 X6M
2014 F10 M5 2015 F85 X5 M 2015 F86 X6 M (Retired) 2014 F10 M5 (Retired) 2010 E70 X5 M (Retired), 2010 E92 M3 MT (Retired) 2006 E60 M5 (Retired), 2000 E39 M5 MT (Retired) 1999 E39 328i (Retired), 1995 525i (Retired) 1987 325i (Totaled - that was fun!) |
07-13-2019, 03:09 PM | #2 |
Rep 638
First I've ever heard of it not working. Are you still under warranty?
07-13-2019, 04:28 PM | #3 |
1636
Rep 2,995
You can sometimes find them used on ebay for couple hundred. I wouldn't imagine it's too difficult to swap if you're mechanicaly inclined.
Does the door close all the way if you shut it normally? |
07-13-2019, 06:37 PM | #4 |
Rep 607
No warranty and the door closes. They tend to go at 50-60k miles. Yes I'm mechanically inclined for example I just installed a Dinan tuner myself. Checking Ebay is a good idea thanks
2017 F86 X6M
07-15-2019, 09:55 AM | #5 |
Rep 607
Does anyone know if the part called the door actuator? And does the issue extend to the door handle itself?
2017 F86 X6M
07-15-2019, 12:44 PM | #6 |
Rep 2,775
Drives: F95 X5MC
Yes, I had this issue on one of my doors, the dealer replaced the motor under the warranty.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
Logical212.50 |
07-15-2019, 12:53 PM | #7 |
Rep 607
Do you happen to have the part number of replacement part? My $tealer won't give out part numbers smh
2017 F86 X6M
07-16-2019, 06:41 AM | #9 |
Rep 2,775
Drives: F95 X5MC
I'll look for the service paperwork when I get home today.
Logical212.50 |
07-16-2019, 05:01 PM | #10 |
Rep 2,775
Drives: F95 X5MC
BMW replaced the soft close motor and cable
51-20-7-419-841 LOCK, BOWDEN CABLE, REAR
Logical212.50 |
07-16-2019, 09:26 PM | #11 |
Rep 114
sorry to hijack but i was wondering if taking out the motors would be okay? i've been looking for x5m's without the soft close door option and they all seem to have it. i'm not a big fan of the option
07-16-2019, 10:59 PM | #12 |
1636
Rep 2,995
You can just slam the doors shut like normal and they don't activate.
alby on boost31.00 X5M_RoOkIE68.00 |
08-26-2019, 06:42 PM | #13 |
Rep 89
not trying to hijack the thread either but I just bought a 17 F85 and the build sheet says I have the soft close doors but they definitely are not. Is there a way to turn them off or something?
08-26-2019, 07:10 PM | #14 |
Rep 607
No option to turn soft close on or off.
2017 F86 X6M
08-27-2019, 09:13 AM | #15 |
Rep 1,456
I was actually sitting in my car with the driver's side door closed and I heard a bang coming from inside the door. Oh no what was that? Got out looked around closed the door like I usually do and it wasn't catching. Went right to the dealer and they fixed it under warranty, no problems since.
08-29-2019, 05:10 PM | #16 |
Rep 142
Drives: 2016 BMW X5M & 2018 JLUR
i just had mine repaired on the drivers door. they found the door lock actuator to be faulty and replaced under warranty - Lock Assembly - BMW (51-21-7-281-945).
Current: 2016 X5 ///M Donington/Mugello Red
Previous: 2010 X5 ///M, 2006 X5 4.4i & 2003 X5 3.0i "BMW El Placer de Conducir" Last edited by Chile1; 08-29-2019 at 05:20 PM.. |
Logical212.50 |
09-02-2019, 03:40 AM | #18 |
Rep 90
Just had this repair done on mine under warranty. The soft close could be heard trying to pull the door but failing so the motor was fine. Dealer replaced the cable and it's good as new .. not sure about the part numbers because I haven't gotten my invoice yet
Logical212.50 |
10-04-2019, 02:03 AM | #19 |
Rep 193
Had my driver side front replaced a month or so ago under warranty, 17 registered x5m 24000 miles. If you attempt to the open the door whilst engaging i find this does it! Over time of course
Faith
09-06-2022, 10:31 AM | #20 | |
Rep 50
Help!
Do you think it’s that metal cable that stretches inside the door lock ? Is that what yours was? |
09-07-2022, 11:55 PM | #21 |
Rep 499
Double check your battery. Mine was doing something weird like that a while back and I took the car in to BMW. Turns out it was the car battery going bad. Replaced the battery and all was good there after.
2018 X5M- Black Sapphire Edition
09-08-2022, 05:25 PM | #22 |
Rep 50
